Question about HP Photosmart C5180 All-In-One InkJet Printer
Hp 7280c if i start it after the PC boots it remains diconnected
I have a HP 7280c set up wirelessly, however It needs to be started and connected to the wireless router before I actually boot and start my PC for it talk to the PC. If I start it after the PC boots than it remains disconnected from the network although the network recongises it and you can spool to it.It doent print.. I then need to reboot the PC with the printer on to have it work properly..any ideas please...???
  • Curtis Richner May 11, 2010
    Have you actually installed the printer on the PC or is it showing as 'Auto'? If Auto it needs to be installed on the PC for this to work.
Hi Cappwal,
Please assign a static IP Address for your HP 7280c. This should resolve the issue.
Posted on Dec 16, 2008
HP Photosmart 5520 wont print when pc is connected to router through ethernet and printer wireless
Have you tried a cold re-boot on printer PC and router worth a try first then check all are on-line and communicating Can you use the PC without the Ethernet cable or a direct cable to the printer just to set it up (Re-set up).
Regards David, more info may help all the bests.
Ps. my old HP is a pig at time but I never have to use the cable which is a good job as I can never find the thing...
Dec 25, 2017 | HP Photosmart 5520 e-All-in-One -...
Iam trying to set up a photosmart D7360 to work in my home for all PCs so I'd like to set it up wireless. I'm currently using a router. How do I start? I have a brand ne HP lap top and the photosmart is in...
HP Photosmart D7360 is Not completely Wireless Capable, However if you want to make it Wireless, You will have to use HP bt450 Bluetooth Wireless.
However since this printer has Ethernet Port, you can still make this printer wireless.
You will have to connect this printer thru Ethernet cable ( network cable ) to Router ( this is called wired networking )
Once you have connected the printer to Router, insert the disk in CD Drive and start the installation process, It will prompt you to choose the type of Connection, Choose Wired/Wireless Network and continue with further installation to complete.
How this works,
With any PC that is connected Wireless to Router, You will be able to print wireless from the PC to Printer.
Jul 03, 2010 | HP Photosmart D7360 All-In-One InkJet...
The screen remains black when computer is turned
maybe a hardware problem, on booting the pc, move the screen to every angle to see if there is a connection problem.
If so, then use your warranty if you have one.
Jun 13, 2010 | HP Pavilion dv1000 Notebook
Hello. I am Ali. I am from Iran. I have a HP pavilion dv9000 laptop.It had work very well till 2 weeks ago But my wifi doesn't work any more.I changed my OS and I re-installed my drivers and after that I...
I would first try to get into HP wireless assitant which you can do through Control Panel (Start >> Control Panel or Start >> Settings >> Control Panel). In there you can turn your wireless on and off. Be sure to make sure the wireless switch at the front is turned on also. If the light near the wireless switch still remains orange, then you will need to get the motherboard repaired or replaced as this is a known issue. If you still have warranty, HP will repair this free of charge. Otherwise contact a repair company such as www.revivemylaptop.com
Jun 09, 2010 | HP Pavilion dv9000t 17" Notebook Laptop PC...
Need help getting wireless laptop connected to internet
1. Go to Start, Control Panel, syetm.hardware, device manager. Under network adapters make sure your wireless is there. Note: there is a recall for HP laptops including the DV9000 because they eractically lose their wireless settings. If this is the case call HP tech support.
2. Assuming your wireless card is listed (not the 1394) and there are no red or yellow check marks we can now go back to control panel, network connections.
3. If wireless connection is not listed then click the task Create a new connection. This brings up Welcome to new connection wizard. At this point you should see a line that says to connect to a wireless network in range . . . If this line is there click this then select your SSID (network name). If this line is not there and you're sure the network switch is on and turned blue then you'll need to call HP.
Mar 23, 2009 | HP Pavilion dv9000z Notebook
On my HP Pavilion I set the BIOS to change the boot order from the CD drive first. Then I intalled Fedora 9 and when I tried to reboot the machine will not boot. I have tried booting with the Win XP cd in...
try resetting all the connections and also disconnect the power cable from the back of the computer and hold down the button for 10 seconds and start the system that should work
Feb 01, 2009 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
My hp wireless assistant is not working
Go to HP folder where the installation was made, and try to start the assistant from there.
Anyways you don't need the asistant to see the status of your wireless connection.
To check it out just
Go to Start >> Control panel >> wireless connections >> and check your status there.
Oct 07, 2008 | HP Computers & Internet
HP Photosmart C5180 All-In-One InkJet Printer Logo
158 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
