Question about Proview PL913S 19" Flat Panel LCD Monitor
Blue Overlay On Screen
  I Have 2 Proview PL926WBi, bought them the same day at the same place however on has a DVI and one dosent.  In any case I have them hooked to a Radeon X1050 one DVI one VGA. The VGA one though has a dark blue overlay so everything that i place on the screen turnes blue.  I have hooked other monitors to the card and no problems. UI and ReInstalled Drivers with no sucess. Can anyone tell me whats wrong?
  • 2,404 Answers
The monitor has to be the problem if you hooked others up with success. Get the monitor replaced.
Posted on Jul 03, 2009
My proview pl 926wbi comes on with a black screen and a no signal message then shuts off.
Check that the cable is firmly connected and plugged into the right connection on the computer. Make sure that the monitor is reading from the right input, (i.e. if it's a blue connection it should be set to VGA/Analog, if white then it should be DVI/Digital) or at least set to Automatic.
This can be configured on the monitor by pressing its' Menu button.
Feb 28, 2011 | Proview PL926WBi 19" LCD Monitor
Pl926wbi 19"proview monitor,screen goes black every 3 seconds,
Bad capacitors on the pcb boards internally unsoldering ad replacement is indicated.
Feb 17, 2009 | Proview PL926WBi 19" LCD Monitor
I have a 19 Proview Monitor PL926WBI and it has no D-Sub cable or power cord, where can I get them realllll cheap?
Public sales or auctions from corporations or schools are the best places to get computer cables for very very cheap.
If you are looking to purchase new cables places like
http://www.pricewatch.com list competitive prices for the cables you are needing.
Jan 15, 2009 | Proview PL926WBi 19" LCD Monitor
ProView PL926WBi
bad capacitors on the board, replace these and the inverters should get there power.
Dec 01, 2008 | Proview PL926WBi 19" LCD Monitor
Proview 926 wbi monitor
have a look at the board open up the monitor and remove the boards and you have to look for doomed or colored caps, they will be obvious compared to the good flat caps on the board. replacing these will most likely repair your issues.
Oct 28, 2008 | Proview PL926WBi 19" LCD Monitor
I NEED HELP PLEASE!!!!!!! PROVIEW 19" MONITER.
Does the led on front of the monitor stay blue or does it become amber ?
If it becomes amber, then you are not getting a signal.
No harm in trying this : You can try to see if it is a contact problem.
With the monitor unplugged.
Use a small paper clip to run in and out of the blue vga plug holes a few times each to make sure they are not plugged or gummed up.
If that doesn't help and you know that your video cord is good, then I am afraid to say that more than likely there is a problem with yor video card.
If it stays blue then the signal is there but the screen isn't fully lighting up, leading to a failing power-inverter board or a bad bulb.
powerseller
bammbammfran
Oct 12, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926Wbi
unsoldering is the only way to UN-mount capacitors the board needs to be out of the casing. a solder iron and some electronic solder wire can be bought at radio shack or any other electronics store.
procedures are all over the internet
Sep 30, 2008 | Proview PL926WBi 19" LCD Monitor
Proview 19# model PL926Wbi
thers Sounds like the problem I'm having /had exactly. When I opened the case I found that like others the 470mf capacitors on the power board had gone bad. (See the post from Delphiuser)
The capacitors are probably from a Chinese company called Xandu and I'm currently looking for a replacement capacitor to fit the circuit. Its a 470 mf cap with a 25 volt rating .
May 01, 2008 | Proview PL926WBi 19" LCD Monitor
Blank screen with message "mode not supported"
Hi
How have you connected the monitor to the computer?
Is it through the vga or the dvi port?
Pls press the monitor menu button and change the mode to vga or dvi depending on the connection that you have now.
You might also get a vga to dvi adapter and connect the monitor to the computer.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Proview 900w
this prob is memory is in monitor so contact sevice engg of proview
Dec 11, 2007 | Proview PL926WBi 19" LCD Monitor
Proview PL913S 19" Flat Panel LCD Monitor Logo
155 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
