Question about Coleman Powermate DuraBuilt 1400 PSI Pressure Washer
Need new gun and connection to gun
The part that connects to the gun is broken.  It leaks.  How do I get the part to buy? Where do I find a web page that sells the parts?
  • 3 more comments
  • rogermonroe Dec 25, 2008
    gun works - lost attachment to spray - looking for part
  • randyjay55 Jan 24, 2009
    Water comes out the handle when you squeeze the trigger.
  • Anonymous Apr 30, 2009
    The attatchment that connects to the handle has a leak and I've lost all water pressure
  • Anonymous May 14, 2009
    i need a new gun
  • chloerac May 21, 2009
    water leaks from the seams in the gun. model discontinued by durabuilt
  • 3 Answers
The DuraBuilt and Coleman pressure washers have a gun that tends to leak through the plastic clyinder wall that holds the plunger that moves with the trigger. You won't see the holes, but if you remove the upper half of the housing, hold the plastic tubes in place with one hand and turn on the water, not the motor, you will see water shooting through the wall.
Amazon sells an exact replacement gun and hose. FAIP PowerWasher Replacement Gun and Hose #80012. Mine does not leak at all and was $29 shipped.
Posted on Jun 27, 2009
I have not got an answer yet but will try somewhere else
Posted on Dec 15, 2008
Need to fix the trigger of a nail gun
Hi Nola:
Sounds like a project.
- WORK SAFE - Disconnect from air supply.
- Clean the tool
- Dis-assemble - Be organized - lay out the parts in sequence on an old towel or on your work bench. Clean each part as you go.
- Repair or replace broken part
- Check all other parts for wear or damage.
- Re-assemble - lubricate and check functions as you proceed.
- Connect to air
- Conduct powered function and safety check.
If it works, - GREAT
If it does not work, either do it over again
Or, go buy another gun.
Old guys like me with lots of time love to tinker with problem tools just to get them working right.
Others who are in "production" just buy the new tool.
Cheers.
Oct 13, 2015 | Tools & Hardware - Others
Broken handle on 1200 powerluber
This is a web site,a chat room
What could someone do for your broken
grease gun handle??
Call Lincoln & see if you can buy a new part
Aug 30, 2013 | Lincoln 14.4 Volt Cordless Grease Gun,...
Sns 41 as soon as i connect air hose, driver goes down and air comes out exhaust
May need cylinder seal # bc0438. When this seal fits loose or is cracked, air will leak past and push piston down to bottom of the cylinder. If the seal fits snuggly and looks in good order, suspect headvalve orings and cylinder spacer orings leaking. Order oring kit and seal. Use silicone paste lube on all the orings. Look carefully at the surfaces where orings make contact and remove scratches with 300 grit sandpaper(fine scratches will allow air to leak past new orings). To make the gun work with poor fitting orings. Clean inside of gun with diesel and apply plenty of silicone paste to orings (using same orings if not cut or broken). If gun works as normal, the silicone paste is temporarly sealing the orings. It may continue to work for a while untill you get new parts. Good luck with repair.
Aug 13, 2011 | Senco SNS41 16Ga Stapler 1" 2"
Water leak where the gun hose connects to the washer causing very low pressure 2200 psi model 020245
Simple fix, just disconnect house end from washer, buy a new rubber washer o ring, like what is used for garden hoses. Put back on make sure it is tight. If still leaks, then need to replace connection end fitting on preside washer, can get those at almost any hardware store, use plumbers tape on threads when putting new fitting on machine, then connect house and back to those honey do list :)
Jun 08, 2011 | Garden
I got air leaking out the barrel where the nail shoots from.
Without model number I cannot be more exact, however, air leaking from nose as soon as you connect the airline indicates that the cylinder spacer orings are leaking. The cylinder is usually sealed by a plastic or metal ring with an oring at the outer edge and seals against an oring installed at the cylinder. Broken oring or grit entering the gun will cause the orings to leak. A quantity of air leaking from the nose when you fire a nail indicates that the lower bumper is cracked or missing pieces. Air leaking from nose with driver being pushed to bottom of cylinder when you connect the airline indicates that the cylinder seal at top of cylinder is leaking. Parts are available at www.toolpartsdirect.com Good luck with your repair and post again with model number if you need more help.
Apr 19, 2011 | Stanley Bostitch Nail Gun
I have the 2 1/2 Hitachi for nailing siding. The nail gun had not been used for a couple of years, but now will only drive the nail half way in. Sounds like an air leak when driving the nail. I have...
Remove the nails and air supply. With side door open notice position of driver. Driver should be at top position with tip not visible. If driver is down and it moves within cylinder when you tilt nose up then down again, time to replace orings. If driver is down, it should extend past the nose about 1/4 inch (if driver is broken at the tip the end will look rough and nail will not drive in all the way). If driver extends past the nose more than 1/4 inch then lower bumper may be breaking up /cracked. Easy test for proper function. With nails removed and side door open, connect air to gun and dry fire gun against hard rubber or old coiled air-hose (with air connected and trigger depressed, no air should leak from trigger area, if air leaks when trigger is depressed, look for fault at trigger pin). Feeder should move back then forward in quick motion almost matching speed of driver and driver should not creep down between shots. No air should leak from nose of the gun (push nose against hard rubber and depress trigger and hold in this position, driver should stay down with very little or no air leaking out of nose, when you release trigger, driver will return). If air leaks out of nose while holding in this position, replace lower bumper. If a quantity of air leaks from valve in front of trigger, cylinder orings may need replacing or outer part of cylinder has fine scratches (remove scratches with 400 grit paper). Parts are available at www.toolpartsdirect.com. Good lucki
Apr 16, 2011 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
NRA833AA model. air is leaking out of trigger valve & will not fire. require manual to check operation.
Here is a link to hitachi web site listing for your gun. Look at the bottom of the page for pdf files of parts lists and manual.
http://www.hitachipowertools.com/store_item.php?iID=154&arrPath=1,9,43,p154,
There are two areas around trigger that can leak air. Spray soapy water on trigger stem and/or plunger valve. If leak is at trigger stem check vinyl ball. If leak is at plunger valve, most likely worn or broken oring inside of gun. Remove head and pull outer ring to reveal two orings. A worn outer oring will cause leak at plunger. If orings are ok on outer ring, pull cylinder and check for scratches where orings contact. If scratched, sand with 400 grit paper untill smooth and repack gun with oring kit. Good luck.
Jan 09, 2011 | Hitachi NR83AA3 3 1/4" Clipped Head...
Bostitch N60 finish gun - air leaks out of the trigger when the air hose is connected
There is an oring that is probably broke in half, It is referred to as a purple o ring. You can buy the whole trigger assembly but I think that just replacing the one will get you going. Let me know and I will try and help more
Jul 29, 2009 | Stanley Tools Staple/Brad Nail Gun
BOSTITCH AIR POWERED NAILER - AIR LEAK THRU TRIGGER
sounds like the rubber seals have dry rotted prob from not oiling it enough, but you should be able to go on the Bostitch web site and order new rubber seals for the gun
Sep 29, 2008 | Air Tools & Compressors
Coleman Powermate DuraBuilt 1400 PSI Pressure Washer Logo
1,023 people viewed this question
Top Coleman Garden Experts
John Trevino
Simon Flummox
Simon Flummox
Are you a Coleman Garden Expert? Answer questions, earn points and help others
