Question about Kohler Model 7202: Drain For Purist® Baths - Polished Chrome
Urinal won't flush
The model is sloan SLG 281861 royal optima G2 plus battery powered 1.0 GPF/ 3.8 LPF
SKU# SLN1086
i have already changed the batteries, and checked the water. when i press the button it makes the click noise and the sensor also makes the ckick noise when i move out of range??
    Scholar:
  • 44 Answers
Hi not being american it sounds as though its a solenoid problem, although the water supply is ok & the batteries are fine, if the solenoid is at fault then no water willpass, or possibly if there is a strainer in the water supply it may be blocked & needs cleaning out?
Hope this helps
Richie from the UK
Posted on Dec 15, 2008
AquaSource High-Efficiency 1.6; 1.1-GPF (6.06; 4.16-LPF) White WaterSense Dual-Flush Elongated Chair Height 2-Piece Toilet from Lowes that won't evacuate the bowl during a flush.
The flapper may be closing before the tank is dumped completely. You can verify this by observing flushing action with the tank open.
Apr 13, 2017 | Maximum Home
Put new valve in the urinal, flushes fine, but loud groaning noise in the wall after every flush, didn't happen until new valve put in. What can I do?
air chamber shock absorber ,wrong pressure take cap off adjusting screw and adjust.it the big silver cap on top just screws off.
May 26, 2015 | Sloan 180-1 Exposed Urinal Flushometer -...
Leaking urinal at base
Sometimes a normal wax seal is not enough. There are two alternate kinds. There are reinforced wax seals which is what I normally use and there are extra thick wax seals. Both should be available from your local Lowes, Home Depot, or Hardware store. When installing the new seal take special care to make sure it stays in the proper position. If it does not stay in position it will leak.
Jan 12, 2014 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Have a urinal flush valve which has insufficient water discharge. Unit is supposed to dispense 1 gallon, but I would estimate only about a half liter flush. Any suggestions?
The guts have worn and the hadle does not push the internal plunger far enough. Check your local plumbing supply house for a rebuild kit. The kit can be installed in a couple of minutes.
heatman101
Aug 20, 2010 | Sloan 3010100 110 Water Saver 3.5
I have a Sloan urinal that will not stop flushing. I have rebuilt it with a total rebuild kit. I cleaned the inside of all surfaces and I flushed the entire piping system to no avail. It will not stop...
The rubber vacuum relief needs to also be changed if you have not. It is located in the tube that runs down to the urinal from under the flush valve. The handle could be hanging up.....or there could still be sediment stopping the diaphragm from working properly.
Nov 21, 2009 | NRS 180-1.5 Sloan Exposed Urinal...
Urinal will flush, but will not stop.
You will need a sloan rebuild kit. They are inexpensive, and fairly easy to install. Check Sloan's website, or a plumbing supply house for the rebuild kit. You do not have to shut water off to the entire building to do this work. You will notice a chrome cover on the front portion of the line coming out from the wall. Remove this cover, and you will find a flat head screw. Turn the screw clockwise, and this will shut the flow of water off that is going to the area you will need to work on. The rebuild kit will come with instructions on the install. Again, it is relatively easy to replace. Just make sure you shut the water off, or BIG SURPRISES in your future.
Nov 20, 2009 | Sloan 180-1 Exposed Urinal Flushometer -...
I need a blue print on how a sloan urinal flush valve works and how the water flowes through it. if posable exactly how it works.
SLOAN FLUSH VALVES ARE SIMPLE. IT DEPENDES ON THE PROBLEM. IF THE VALVE KEPS RUNNING AFTER IT IS FLUSHED THE RUBBER DIAPHRAM IS DIRTY OR OLD AND THE RUBBER DIAPHRAM IS GETTING HARD. AND STICKING. THE VALVE WORKS ON A VACUME TO CLOSE THE DIAPHRAM TO STOP THE FLUSH PROCESS. WHEN YOU PULL ON THE FLUSH HANDLE YOU BREAK THE VACUME THAT FORM ON THE TOP OF THE DIAPHRAM WHICH ALLOWS THE WATER TO FLOW AS THE WATER FLOWS IT IS ALSO STARTING TO PULL A VACUME IN THE TOP OF THE DIAPHRAM TO CLOSE THE DIAPHRAM AND STOP THE FLUSH.
AS THE DIAPHRAM GET OLD AND WORN IT GETS HARD AND DOES NOT MOVE AS FREELY AND STICKS OPEN AND WON'T LET THE VACUME CLOSE THE DIAPHRAM AND THE URINAL WILL CONTINUE TO FLUSH. HOPE THIS ANSWERED YOU QUESTION
Oct 01, 2009 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Kohler Model 7202: Drain For Purist® Baths - Polished Chrome Logo
728 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
