Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
Burner ignitor will not turn off after the burner lights Viking
This is a Viking 30" range. Three burners and the oven work fine. When the right rear burner is lit (which is seldom) the ignitor continues to spark as well as all the other three ignitors. I assume that it is normal for all ignitors to work simultaneously.
Questions:
What causes the ignitors to stop after the burner lights.
How do I fix my problem.
Rob
  • Anonymous Mar 24, 2014
    Some sealed burners ignite normally. Some will ignite occasionally. The right hand two burners ignite normally. The center front ignites normally. The other three burners ignite occasionally. I always hear sparking but do not see it at the stubborn burners.
    Habit-Forming:
  • 171 Answers
Replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
Posted on Dec 14, 2008
New ignitors in Viking range oven do not heat up
You will need to measure for 110 VAC at the control switch located on the thermostat. Pleazer Appliance...
Apr 15, 2014 | Viking Kitchen Ranges
Viking gas oven model # VGIC3656BSS, serial #022404-2919 takes FOREVER to preheat up. Sometimes in excess of 40 minutes. Been a problem for a while. Looks like flames at bottom do not increase when oven...
When increasing the temp. on a gas range the oven's burners do not increase flame size as the cooktop burners do. It just keeps the burner lighted for a longer amount of time.
First if you can see the burners do they light within about a min. or less. If no you probably have bad igniters which are not lighting the burners as quickly as they should or they are "opening up" (stops working) when they get too hot. In this case replacement of the igniters should solve the problem.
Second if it lights quickly but still takes a while to heat; you want to look at the burners to ensure that the flames are down both sides of the burner tube and not dancing around too much. If only part of the two sides of the burner tubes are lighted then a pluged orifice or burner tube is the most likely cause. Once cleaned it should work fine.
As with anything mechanical there are numurous possiblities for something not working correctly and above are the two most popular reasons that come to my mind.
May 17, 2011 | Viking VGRC485-6 Gas Kitchen Range
My oven is not working The Broiler works and the stove top works fine but the oven will not heat and when you turn it on no gas comes out I tried turning it on and using a lighter but nothing happens
You gave us good clues in information!-- Thanks!
Most modern gas ovens have a device called a Glow Ignitor to light the burner.
If this ignitor has filed, it will NOT left the gas valve open-- (Good thing, right? :-) )
You say the broiler lights fine-- so let's observe something when the Broiler lights:
Do you see a bright glow near the Broiler burner?
(Usually toward the top rear of the oven--)
Well, you should see a similar bright glowing near the BOTTOM rear of your oven, for the main burner to light off-- If you do NOT see this glowing-- then you need a new ignitor-
You can remove the bottom burner cover, and dig deeper into the repair if you like-
But a new ignitor needs to be exactly like the failed one-- the safety circuit is very fussy about the exact same ignitor-- or it will not allow lighting-- even with a new 'generic' installed.
How deep do you want to go into this repair?-- Maybe it is time to call the service people into do the job?-- You can tell them that you think the ignitor needs replacing-- and approx. what will they charge you for the service call and the ignitor?
I hope this helped.
Mack B
Jan 27, 2011 | GE 30 In Freestanding Gas Range ...
Viking model vdsc4874gss small oven works fine large oven element on bottom only gets hot in cleaniong mode, fan comes on when dial is turned to convection but no heat power is on light works
One thing that you can check is make sure that you have 220 volts at the plug. Leave the unit unplugged and check continuity on the burners. You should have continuity on the burners.
Oct 18, 2010 | Viking 48" 6 Burner, Grill Professional...
One of the oven ignitors does not work
Most likely replacing the ignitor will fix it. I usually replace Viking ignitors with Maytag ones, part number 12400035 (you'll need splice wires and use included wire nuts to connect those, though). Those have a little shorter base, which does not affect anything. Replace both bake ignitors if you can, otherwise, one of the burners will ignite slower and shut off faster, resulting in uneven bake.
Jul 17, 2010 | Viking VGSC306-4B Gas Kitchen Range
Oven out/flat top has hot spot/burners ticking everywhere
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 11, 2009 | Viking VGRC605-6 Gas Kitchen Range
Viking 30" Range - Igniter works - but NO FLAME in oven or ranges
No pilot light need to be ignited. You may need a new ignitor. It might not be catching. If you pull the bottom oven plate off you can see the ignitor on the side of the burner and see if it is in its place or broken or just plain old. It is a simple fix. You can buy a universal ignitor or contact Viking and they will sell it to you. Its only two wires and can do it yourself if you are somewhat technical. Good luck.
Jan 09, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Ignitor sometimes clicks, sometime not
You will need the ignition bird located il under the cooktop
Mar 28, 2017 | Kitchen Ranges
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
893 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
