Question about Garmin Forerunner 305 GPS Receiver
My Garmin forerunner 305 will not turn on.
It is only a year old.
  • 3 more comments
  • pinion Dec 14, 2008
    I "stored" the 305 on the charger about 3 months ago. the charger which was plugged in. When I tried to use it, I could not get it to start and it doesn't appear to be charging from either a wall plug or from my USC port
  • jambatri Jan 02, 2009
    same problem my forerunner 305 will not turn on.  I tried to do the reset and hook it up to the computer but nothing works.
  • Anonymous Jan 25, 2009
    Used it yesterday on a bike ride. Went to transfer the data this morning and it won't turn on.
    Used it yesterday on a bike ride. Went to turn it on this morning to transfer the data, and nothing. Will not turn on, will not charge. Expensive watch to be crapping out like this.
  • javiery Mar 21, 2009
    I have the same problem. I left the Forerunner 305 plugged to the usb cradle for a while (10 hours or so), then when I tried to check if it was still charging the display was blank. Hooked it and unhooked it from the cradle and nothing happened: no sound, blank screen. It didnt turn on. I left it unplugged for one night and the day after it turned on (luckily).
    But it happened again, and I've tried the "soft" reset (holding mode and reset for 10 seconds) and it worked fine!
I have had the same problem. To fix it, I simultaneously hold down the "mode" and "reset" buttons for about 10 seconds. After releasing the buttons I power it up as normal. This has worked both times it has happened, and I got this fix from the Garmin website. My mileage totals are still in the history.
Posted on Feb 26, 2009
  • 2 more comments
  • Rob Wilson Sep 30, 2012
    1st time in 5 years that my forerunner had let me down. tried this and it worked in a flash. thanks
  • emiledavis
    emiledavis Oct 12, 2012
    Like Rob posted above, I followed these steps, hit the power button and closed my eyes...Bingo! Thanks! But any idea why this solution works?
  • victoradlc
    victoradlc Oct 30, 2012
    i have to do this everytime to turn it back on. It will not download to dailymile or garmin. have downloaded to them for two years now. any suggestions.? thanks
  • margaretlyba
    margaretlyba Feb 24, 2013
    Thanks RunnerGirl - Your fix totally worked!!
Try to perform the hard reset, it worked for me. http://wiki.motionbased.com/mb/Hard_Reset
Posted on Feb 18, 2009
SOURCE: GARMIN 305 Forerunner wont transfer data to PC
For Pc users:
Go to Garmin website Updates & Downloads, Training Centre for Windows software version 3.4.1, click on download.
I previously deleted all saved couses on Training Centre, but don't know if this is relevant.
Posted on Jun 02, 2008
  • 3 Answers
SOURCE: garmin forerunner 305 won't turn
You can reset the unit by pressing the and holding the mode and lap buttons simultaneously. This will power it off.
Posted on Jul 27, 2009
SOURCE: opening forerunner 305
Hi
I have a problem with my 305 whereby the mode button stopped working so semi pulled mine apart.
If you look at the 305 from the side you can see where the rubber bit covers the buttons. The bottom of the rubber bit is attached to the rear of the forerunner - don't try to detach it - I munted mine a bit detaching it. At the top of the rubber, nearest the face you'll see a small gap. Follow the gap anti clockwise from the power button down to bottom left corner of the face near where the wrist strap pin is. Here you'll see the gap is plastic on plastic on plastic. I believe a thumbnail or similar in here and worked around carefully will let you pry the face off. I stuck my thumbnail in there and got the face to lift 1-2mm before I backed off. Note I didn't go any further than that.
For my problem by the time I had munted the rubber cover and was able to operate the mode button with a paperclip I new it was dead so didn't bother going any further as I could still use the 305 in reduced mode without mode changing.
Posted on May 03, 2009
KingDWS
  • 1606 Answers
SOURCE: Garmin Forerunner 305 won't turn on and won't
You need a new battery. There is a small chance there is a hardware problem but about 99.9% of the time its just the battery giving up.
Posted on Apr 01, 2010
Testimonial: "Just what I needed to know. "
  • 638 Answers
SOURCE: Forerunner 305 GPS Receiver: How can I change my Garmin 305 from miles to kilom...
Page 48 of your manual, Changing Units of Measure. Settings > General > Units
Posted on May 20, 2010
I have bought a new computer, windows 7. I cannot install driver for forerunner 305.
Glad to HELP YOU!
It's a well-known issue between Windows 7 and Garmin Forerunner.
Garmin company says it's a compatibility issue concerning the USB connection between the computer and the device and usually they recommend to be an Intel Chipset.
Try to download and install using the latest drivers available on their site on WIN 7 and Forerunner 305.m You have them ALL here and the USB driver was released this year and it's the last one on that list.
GOOD LUCK!
Mar 26, 2011 | Garmin Forerunner 305 GPS Receiver
May 17, 2010 | Garmin Forerunner 305 GPS Receiver
Forerunner 305 GPS Receiver: Is it possible to change the battery in a Garmin F...
Yes you can. Go to the Garmin Website and simply email them asking for the price of the battery and instructions on how to replace your specific model and serial number as they changed in mid year many times.
May 03, 2010 | GPS
Garmin Forerunner 305 won't turn on and won't charge. Is there a fix or is this it for the device?
Look at
"http://www.activesplit.com/my-garmin-forerunner-305-doesnt-power-on-its-just-dead-solutions/"
You can soft reset or hard reset the device. Hard reset deletes all data.
Apr 01, 2010 | Garmin Forerunner 305 GPS Receiver
Garmin 305 forerunner
you can't. If it is getting softer and softer the speaker may be on it's way out.
See this link for a possible reason (bottom of the page).
http://ctorunner.googlepages.com/dismantleforerunner205
Sep 01, 2009 | Garmin Forerunner 305 GPS Receiver
My Garmin 305 has stopped working. It is 1 1/2
If it won't start, try connecting it to your computer and see if you can get a firmware update to turn it on. Otherwise I would send it into garmin since there aren't replaceable parts for consumers.
Benjamin
Jul 17, 2009 | Garmin Forerunner 305 GPS Receiver
My garmin 305
Press and hold the mode and lap buttons for 10 seconds, then release. Most of the time, that will fix it. Garmin has a sort of sleep mode programmed in for certain situations. If that doesn't work, I have had wonderful success with Garmin tech support.
May 16, 2009 | Heartbeat Garmin Forerunner 305 Gps...
Garmin Forerunner 305 usb cable won't be read
The problem is probably not with the USB cable if the GPS wont even turn on. The older firmware of the Forerunner 205 and 305 have a problem with locking up. This causes the Forerunner to look completely dead. There is a reset procedure: push the mode and reset button at the same time and then let go and hit the power on button. If it powers on that is the problem. Go to the Garmin site and load the newest rev. of firmware into the Forerunner. Fixed mine and a few friends with the same problem.
I do however have a cable problem. Sometimes my PC will come up with unrecognized USB device and my 305 wont talk to the PC, it does charge. It is the cable or dock for sure, because I have tried a different cable/dock and the 305 has no problem. This is the reason I ended up here. I hope the lock fix works for those with the above problem.
Dec 16, 2007 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
5,872 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
