Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
I was told to tighten the screw that holds the hinge pin in place.
What other options do I have ???
This was a friends mixer and she said kitchenaid told her it sounded like an adjustment problem
My mixer started wobbling a while ago and has now gotten so bad that it wore the paint off the paddle. I had tried tightening the screw,. which worked but only temporarily. Any suggestions??
This may have a simple solution: This sounds like an issue of beater to
bowl adjustment, which can come out of alignment naturally over time
and with use of the machine.
If
the flat beater is striking the bottom of your bowl, this may cause the
locking mechanism to loosen and may cause the mixing head to "bounce"
during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
If the beater to bowl adjustment quickly comes out of alignment, you may need to seek service. You may find a Kitchenaid certified service location locally at the following website:
http://caservice.kitchenaid.com/
Posted on Jul 08, 2009
SOURCE: Kitchenaid Mixer head wobbles bad
The solution provided by luannej is useful only if your mixing attachment is striking the surface of the bowl. By adjusting the screw located at the junction of the head and base, you are actually controlling how far the head is allowed to tilt forward and, thus, the height of the attachment above the bottom of the bowl. Although the attachment striking the bottom of the bowl will lead to wobble (and noise!), it isn't usually the root cause of the wobble. In fact, the wobble may be causing the bowl strikes and adjusting the head height only hides the problem.
The head of the mixer is secured to the base by a large steel pin. Any play between the head and base comes from this hinge and its resulting tolerances. To "tighten" the sloppy tolerances causing your wobble, follow these steps: 1) Lock the mixer's head down and turn the entire mixer upside down. 2) Looking deep into the hollow base, find the small slotted set screw. This screw actually presses against the pin and takes up the slop between the head and pin. Note that this screw is not the large slotted screw I mentioned earlier visible when you tilt the head back. 3)Tighten the small set screw as much as you can. Your wobble should be greatly reduced or eliminated now. 4) Lastly, you may want to readjust the large screw controlling the head's tilt to optimize the distance between attachment and bowl. Hope this helps.
Posted on May 24, 2009
SOURCE: Kitchenaid Classic -Mixer Head wobbles or shakes back and forth
Lay the mixer on its side and look up through the base. You willnotice a small set screw. This holds the pin tight. If the set screw gets loose the pin willl begin to move out and the head will wobble. Simply tighten the set screw. I just did this to my Kitchenaid mixer 10 minutes ago and it now works fine.
Posted on Jan 13, 2011
SOURCE: My wife's kitchenaid classic 250 watt mixer wobbles on the base
It sounds like your mixer likes to take a beating, ive never dropped one and for good reason, they weigh quite a bit. first check to see if all the rubber legs on the bottom are still there. if they are the only possible solution to fix it after being bent or warped is to either re-shape the part using a tool strong enough to do the job, or to replace the parts needed. the hinge pin part number is 16910. is the base is bent the part number is 240151-1. If the lower portion of the mixer itself is bent or warped this is a serious problem and will require you to dissassemble the entire unit. part number for the lower gearcase is 240350-4 Please not that all the parts list are white in colour. hope this helps.
Thanks
Posted on Oct 12, 2009
SOURCE: KitchenAid wobbles when mixing
The "wobbling" sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Also, leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Feb 28, 2016 | KitchenAid Food Mixers
Dec 14, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
May 09, 2014 | KitchenAid Food Mixers
Nov 30, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Nov 21, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Feb 06, 2013 | KitchenAid Artisan Series Tilt-Head Stand...
Dec 11, 2012 | KitchenAid K45SS Classic Stand Mixer
Feb 18, 2011 | KitchenAid Classic Stand Mixer
Jan 28, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Jan 24, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
3,424 people viewed this question
