Question about Yamaha HTR-5790 Receiver
"Check Speaker Wire" error on my Yamaha Receiver
Whenever I attempt to watch a movie or TV in any type of surround sound, the receiver makes a clicking sound and then shuts off. When you turn it back on it gives you the "Check Speaker Wire" error. I have checked all of my connections of the wire to the receiver and all of the connections to the speakers. Nothing is touching and the wires aren't even exposed. I made sure the impedence is set at 8 ohms and ran all of the various troubleshooting tips in the back of the user manual. IT works fine when in the "straight" mode, but will shut off if switched to any of the surround modes. It also works fine when the Xbox 360 is playing trough it, but the sound is only running the the front L and R channels. I have tried with A on and B off, B on and A off, and both off. Ultimately the result is always a little clicking sound with a shut off, followed by "Check Speaker Wire" error. I reset the receiver to the original factory settings, also with no positive result. This is a new receiver and worked just fine for the first month or two, and then just randomly started shutting off in surround mode. I am out of ideas, so any help or solutions you might have would be appreciated.
  • 9 more comments
  • Anonymous Dec 17, 2007
    i'm having the same issue. What's the deal?
  • BJQuilts Dec 27, 2007
    The Receiver turns off and when turned back on gives message "Check SP Wire"
  • fluxtail Jan 02, 2008
    I also have the same problem
  • Anonymous Mar 17, 2008
    Goday. I have been having problems with my receiver for some time it shuts down when watching a movie.I purchace a new one a Yahama HTR-5940. It started doing the same thing,after trying a new speaker swaping out one at a time. I found I had a defective speaker.
    Once that was repaired about two months it started again, this time a broken speaker wire was at fault.Afer about two months it started AGAIN.
    I found out it was my DVD player was not set to Dobly Digital in 5:1 mode.
    Once this was done I watch the last Star wars as loud as possible.It worked like a charm.
    Then I was watching the Movie 300 it worked justed fine for the first hour.
    Then it quit again and it comes up with check speaker wire error.I have purchase the best wire money can buy and the polarty is correct.
    I am out of ideas.
    Any help would be great!
    Vince
  • Anonymous Mar 23, 2008
    I have the same problem with my 5790 and have disconnected all the wires except the power in. I turn the unit on and it goes into standby mode in about 5 seconds. I got the unit to stay on by hitting the a/b/c/d/e button on the front panel at the same time as the tuner up button to the right before I hit the power on button.
    All the stuff that comes up on the display has no meaning to me so I am stuck.
  • hokiejane Jun 07, 2008
    Having the same problem here only everything worked fine for 5 or 6 years. I guess I have to go through and systematicall disconnect every speaker from the system and hope I find an offending one. Otherwise is it safe to assume that the receiver has just gone bad?
  • Anonymous Oct 16, 2008
    I have the same issue with an HTR-5830. No idea what to do. It just gives that 'check sp wires' and shuts off. Some of the speaker connections don't even work initially, either. I've changed up the wires, tried speakers one by one--nothing
  • Anonymous Dec 28, 2008
    I have the same system with the same problem... My system is about 3-4 years old. Somebody HELP.......
  • jbfromwp Apr 15, 2009
    I have the same problem with my RX-V663. It's less then a year old. This is horrible.
    I have the same issue with my RX-V633. It's less then a year old. This is horrible.
  • John Cunningham
    John Cunningham Dec 28, 2018
    I visited this website earlier
    I got some compressed air can and blew mine out and that cured the speaker wire thing. Thank you.
Found the source of the problem with "Check SP Wires"! to solve it is necessary to check each speaker connected to the device Yamaha on the rear panel (red and black) using the device for determining the number of ohms, which shall not be less than 4 ohms, in large passive speakers experienced in Amfitone AU-027, the result showed that left at 0.45 (7) ohms, and the right-hand column, as such, no.
The successful test ... and good music!
Posted on May 20, 2010
  • 4LIFE4 May 20, 2010
    found the source of the problem with "Check SP Wires"! to solve it is necessary to check each speaker connected to the device Yamaha on the rear panel (red and black) using the device for determining the number of ohms, which shall not be less than 4 ohms, in large passive speakers experienced in Amfitone AU-027, the result showed that left at 0.45 (7) ohms, and the right-hand column, as such, no.
Mine says it with no speaker wires hooked up to it.
Posted on Dec 28, 2018
I have the solution because i artificcially created this problem when improved my Yamaha rx v367 ,check the connection of all internal wires,i mean all of them
Posted on Mar 23, 2011
Has anyone come up with a solution? I am having the same issues with the htr-5830
Posted on Jan 02, 2010
Hello, I just bought HTR 6080 and I'm having same problem. When I turn up the volume, receiver will shut off by itself. When I turn it back on "Check SP Wire" message is displayed on receiver front panel. I tried eliminating one speaker at a time and tried two front main speaker only. Yes, did check speaker setting to 8OHM and I tried to program receiver in "Auto Setup" mode. While receiver setting itself in "Auto Setup" mode, it will shut off by itself. I remember I had old receiver and it had same problem. I did swap it at the store but still same problem. I have no idea what could I be doing wrong. As other mentioned, I have checked speaker wires OHMs, nothing I can find wrong with setup or hardware. I'm going to call Yamaha technical support if I can find there phone number. Think is getting me mad, and if this is not resolved soon I going with Harman Kardon.
Posted on Jun 16, 2008
Get rid of this piece of junk..i get the same error.. sounds like a Yamaha screw up.....
Posted on May 05, 2008
Are you using the bose speaker wires or after market speaker wires?
Posted on Apr 13, 2008
I undid all my speaker wires and reconnected them. I haven't had the problem since.
Posted on Jan 03, 2010
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: speaker impedance and the Yamaha RXV 463
You risk to crash a set of speakers. In any case this will have a detrimental effect on the sound
Posted on Aug 04, 2008
  • 3 Answers
SOURCE: can I mix 6 and 8 ohm speakers?
Most Yamaha HTR's are high current receivers so setting the receiver to 8 ohms and running the 6 ohm speakers shouldn't be a huge problem. I wouldn't crank the volume though if i were you but at a decent level you should be fine.
Posted on Feb 28, 2010
I have a JVC TH-S3 surround sound system and would like to know if I can l watch television in surround sound as i can watch dvd's and listen to the radio in surround sound. thanks
Yes you can get simulated 5.1 surround sound from your TV as well as radio. Just switch the JVC surround mode to Pro Logic II movies or music In some systems it will display only PLII.
Just connect the TV audio out to the JVC Aux input at the back ( red and white sockets ).
Apr 26, 2011 | Audio Players & Recorders
I would like to know if my ht 3913 will work thru the TV sound, I have no problem with it working when I'm using the DVD player to watch movies, but I would like to hear the TV thru surround sound
Directly , no, since the tv sound is always just on 2 channels. But you can convert it in the receiver to surround by activating either the SRS Surround or the DolbyProLogicII options on your receiver.
Aug 19, 2010 | Audio Players & Recorders
YAMAHA HTR 5560 KEEPS TURNING OFF
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Jul 25, 2009 | Yamaha HTR-5560 Receiver
No sound coming through
If the DVD player is seperate from the surround system and hooked up to the tv. You should have a wire from audio out on the tv to the audio in on surround sound. Some tv require you to turn off tv speakers inorder for it to be routed to the audio out. In which case you can do this in the menu.
Mar 14, 2009 | Audio Players & Recorders
Rx-v563 backround music much louder than people when watching tv
I would check your center speaker wiring and setting. Then switch to a different audio setting (pro logic, theater...)
Jan 12, 2009 | Yamaha RX-V563 Receiver
Can't get Surround Sound with Movie
hiya
do you get full 5.1 when watching a movie from the dvd player...........??
as when u watch tv the reciever must be set to pro logic to enable 5.1 upmix as its only a stereo feed....
Dec 15, 2008 | Technics SA-DX1050 Receiver
Center speaker still not working :(
all your speaker channels are working so your problem lies with a setup fault. when you watch tv you are only feeding a stereo signal into the amp. you need to select the internal surround sound generator. you need to select either the movie or surround function. the unit will convert the stereo signal to 5.1 channel surround.
May 26, 2008 | Yamaha RX-V595A Receiver
Denon AVR 2802 - Unit Turning Off
If DIGITAL sign blink, this mean DSP board is defective. It will cut the sound on the AMP section. DSp is maybe defective.
Jan 12, 2008 | Denon AVR-2802
Yamaha HTR-5790 Receiver Logo
9,286 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
