Question about Microsoft Xbox 360 Console
My X-box single red light goes off when I unplug my AV cables.
My X-Box error 74, one red light goes off when i unplug my AV cables does this mean my AV cables are bad.
    Problem Solver:
  • 6 Answers
I just sended it to microsoft today 12/13/08 no worries as long u have the serial number and the recipt u have a gurantee 3 year warnente
Posted on Dec 14, 2008
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
One red light flashing bottom right , what is wrong .
A single flashing light can mean a hardware failure. Did you get an error code? EXX where XX is a number...like 74 for instance? Please, let me know, and try this.
Power off the system and unplug everything from it..controllers, memory cards, av connection, power cord, and hard drive. Also unplug power cord from socket and the short cord from the power brick. Then reattach everything making sure the connections are firm and power back on your system. If this did not resolve the problem.
Apr 02, 2010 | Microsoft Xbox Console
I start up my xbox and it goes into a screen that says error e74
the e74 error is a problem with your AV cable or the HANA scaler chip on the board, but the one red flashing light means you have a general hardware failure in others words its buggered, luckily this error has a 3 year free replacement warranty on it so just send it back to microsoft for a free replacement
Jan 21, 2010 | Microsoft Xbox 360 Console
It say e 74 the light is red
The single Red Light and the E74 error code means that there is a I/0 Hardware Error. This error code can mean a few things but the most common is that there is a problem with the scalar chip.
The Error could also indicate a problem with the AV cable so you may want to check this first before attempting a repair.
Microsoft cover this in their 3 Year warranty so if your console is not modded and in its 3 Year warranty contact them first.
The error can be sometimes be fixed with the X-clamp fix but this is a rare working fix.
Nov 25, 2009 | Microsoft Xbox 360 Console
E 74 error message on my xbox 360
thats because that error message means your AV cable has died or the chip inside has cooked, if the error goes away wen you remove the cable its the cable you need to purchase a new one
Oct 26, 2009 | Microsoft Xbox 360 Console
360 error 74 message
The cause of E-74 with one red light Error might be overheating of your console and for avoiding such error in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling of console such as cooling the machine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Either you can send your Xbox to Microsoft (Please note that microsoft is no longer providing extended warranty for E74 with one red lightError) and wait for 3-4 weeks. If you don't want to wait for a month, you can also fix E74 with one red light problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours.
Mar 28, 2009 | Microsoft Xbox 360 Console
E74 xbox 360 AV cable?
to fix the E 74 problem, i sudgest going to http://llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm. they have a step by step solution for both the red rings of death(3, and 1) or the E 74 error. i sudgest buying the kit they sudgest, its $29.99 or so. then just follow the step by step instructions when your kit gets to your house
Feb 24, 2009 | Microsoft Xbox 360 Console
My xbox360 has a red blinking light
There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement. Also try this take the AV cable, plug it out and plug it in, if it still doesn't work unplug it, wipe the metal part with a soft cloth then plug it in. That might help.
Feb 18, 2009 | Microsoft Xbox 360 Console
Error 74
error code 74 is
74: AV cable Error - There is a problem with the AV cable, try using a different AV cable.
hope this solves your problem
Maxicube
Feb 10, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
