Question about Nikon Coolpix 3200 Digital Camera
Camera lens is out, but camera is off
I connected my camera to my computer to import some pictures, and when I was going to "safely remove hardware" from the bottom of windows, the camera USB did not show up, so I accidently pulled out the USB without shutting the camera off. Now the lens is open but the camera is off and won't turn on. Is there a way to fix this? Thank you.
  • Michael Garcia Mar 16, 2007
    Hey, thank you for the post. I tried what you said, I held the power button then pressed the other buttons twice and nothing happened. I also tried to push the lens in but it didn't budge and I didn't want to force it. Anyway, the lens is out as if the camera were on, except the camera is off. Screen is blank, etc.
  • Anonymous Dec 18, 2008
    I hav ethe exact same problem with the weird green light but i shall try your suggestions and i hope it works I know this camera is old but I really can't afford a new one right now.
    Novelist:
  • 198 Answers
First deconnect all batteries, usb cable anything from the camera. Leave it for about 1 hour and then without connecting batteries press and keep the the power button pressed for about 1min. Then press twice on every other button including the shuter, zoom or stuff like that. This should reset a microcontroller that remembers the last operation done. This doesn't reset the camera. After this, connect the batteries and try to power it again. IF this doesn't work. Try to push the lens back in using your fingers. Don't force them to much if they doesn't appear to go back. Use 2 fingers to press on the lens one on each side aplying equal pressure. You may hear a click noise when the lents start to go back. Again, don't force them to much. Try these at first and then if they doesn't work, please post back and specify what does the camera do. No led's no nothing or ..?
Posted on Mar 14, 2007
  • Motoi  Bogdan
    Motoi Bogdan Mar 17, 2007
    There aren't any other DiY solutions for these problem from what I know. You may have to go to a service center to have the camera examined by a person there. Maybe some sort of damage occured. The camera's firmware or the processing unit may have been altered. This shouldn't be an expensive repair, however you should ask for an estimate before they start the actual repair.
I have the same problem (camera stuck 'off' with lens out), except that with new batteries the green light flashes for a few seconds when I try to turn the camera on. Then nothing. The display remains dark.
In my case, the problem occurred after I let the batteries run down (over-night) while the camera was on and attached to the computer.
Posted on Aug 23, 2008
Safely remove hardware unknown error!
Unplug the camera if it's connected, then shut down and restart your computer.
In the future you might want to consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 06, 2012 | Canon EOS 400D Digital Camera
I dropped my canon camera and it says lens error restart again. i dont want to lose my picture but the lens dont go in. i can see my pictures but i cannot take a picture.
Any pictures you have taken in the past should be safely stored on the memory card. Make sure you copy them onto your computer to ensure you don't lose them while fiddling with your camera. You can use either an external card reader or you might be able to connect your camera to a computer using a USB cable.
A lens error is one that the average user can diagnose and fix. It usually requires a trained technician or worse (but sometimes cheaper), a replacement camera. You have already experienced that the camera will not take pictures with the lens error.
Good luck.
May 13, 2011 | Canon PowerShot A560 Digital Camera
When i try to upload pics, the camera displays PC "No Pics" and my computer displays its safe to remove hardware, How do I get it to display my pictures
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa ( http://picasa.google.com ).
May 10, 2011 | Konica Minolta DiMAGE A1 Digital Camera
I took a bunch of pictures and went to put them on my computer, when I inserted the memory stick into the computer it only showed half the pictures on the memory stick, so I put it back in my IR 500 and...
Removing the memory stick without using the "safely remove hardware" function is probably the cause cause of your problem. The pics are still there but you need a 3rd party machine to read them. Go to a Walmart and plug the card into one of their picture making machines. You can print the pics or even make a CD of them. Once you have them safely in your possession, format the card in the camera and in the future, don't forget to use the "safely remove hardware" function on your computer.
Jan 17, 2011 | Olympus i:robe IR-500 Digital Camera
I need to know how to get my pictures on to my computer from my camera. do i need a disk. my computer don't have a hole for the chip. i do have the wire to connect to the computer. how do i go about...
To import pictures and videos from a digital camera
  1. Connect the camera to your computer by using the camera's USB cable.
    samshameem_2.jpgConnecting a camera to a computer with a USB cable
  2. Turn on the camera.
  3. In the AutoPlay dialog box that appears, click Import pictures and videos using Windows.
  4. (Optional) To tag the pictures, type a tag name in the Tag these pictures (optional) box.
    By default, the folder name includes the date the pictures and videos are imported and the tag name.
  5. Click Import.
    A new window opens and shows the imported pictures and videos.
Jan 08, 2011 | Computers & Internet
When I review my pictures on my camera there are blank pages and the camera freezes up when I get to a blank spot. some pics have come through but not all. when I try to import to my computer everything...
Try to download your pictures to the computer. First make sure the camera has enough power to download the images without stopping. Connect the USB cable to the computer make sure the camera is off when you connect the mini USB end to the camera, then turn the camera on and depending on your computer operating system an icon will show on your desktop or in system preferences and an external hard drive. Once you have the pictures safely on your computer Hard Drive "eject" or click the icon to close and wait for safe to remove device )depends on system) then format the memory card always format the card or delete pictures in the camera not the computer.
Dec 28, 2010 | Sony DSC-S930 Digital Camera
When I plug the camera into the computer to upload pictures the lens comes out as if I was going to take pictures. I do not get a message on the computer screen asking me what I want to do & the lens...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Sep 03, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Camera is stuck between on and off
You should have use the "safely remove hardware" function.
May 19, 2010 | Kodak Easyshare C813 Digital Camera
Downloading pictures to my computer
Are you saying that you turn your camera on and the lens emerges, and then you plug in a live (5volts DC) USB cable, and the lens retracts? If this is the case, then that sounds fairly normal. Your camera has turned itself off in response to you hot plugging the cable. You only need to turn your camera back on. The lens probably doesn't emerge because the camera is in download mode, not shooting mode. In this case there is nothing wrong with your camera, and therefore nothing to fix. If you have tried all this, and your computer still cannot see the camera, try plugging the camera in to other USB ports on your computer. You should have between 4 and 8 to try. Also make sure the plugs and ports are all clean on bothe the computer and the camera. Another thing you can do Lizzie is to get a USB card reader (SD or multi or whatever card your camera uses) for $2 Reject Shop to $10 most camera shops. You put your camera card into the card reader and then plug in the card reader. MOST IMPORTANT! Make sure your camera is off when removing the card, and use the SAFELY REMOVE HARDWARE icon when removing your card from your computer.
May 05, 2008 | Casio Exilim EX-S500 Digital Camera
Uploading Doesn't Work
ok
Do you have any disk or software package of your camera? you need to install it to the computer. It serves as driver for your camera.
to import your pictures in the camera i suggest that use your memory card if you have a card reader to transfer files.
Jan 17, 2008 | Nikon COOLPIX P4 Digital Camera
Nikon Coolpix 3200 Digital Camera Logo
109 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
