Question about Lexmark Z735 InkJet Printer
After my Z735 lexmark printer prints the first line it showsan error message that "Something is blocking the catridge" .
  • sudharanjit Dec 14, 2008
    No there's nothing stuck to it, It also had a message "To check whether the catridge is snapped in" .Everything is okay but still the printer doesnt print more than one sentence n the catridge goes to the right side of the printer with a little lound sound.
    Problem Solver:
  • 33 Answers
The same thing happened to me once. Try looking near the cartridges, there might be an item stuck which makes it hard to print. When that happened to me, i noticed that there was a pencil stuck in mine. I ended taking it all apart in the end, but that is only because someone forced it in there. In the end, it worked!
Hope you get your working soon! =]
Posted on Dec 14, 2008
Carriage slams into left side
In this case unplug the power supply from the Printer........... 1. Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........ Good Luck......
Feb 22, 2013 | Lexmark Z600 InkJet Printer
I cant print and get error message 1203 on my lexmark p315 model:any idea wat that error message is?
t's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
Too bad that I also cound not find out how to reset the ink indicator. It's annoying to hit the OK button every time you want to print.
Try and see if it's work for you. Good luck......
Dec 22, 2010 | Office Equipment & Supplies
I have a lexmark printer model 5495,it tells me that the right cartridge is incorrect, i just put in new cartridges in . the cartridges 28-black/29-color, it still tell me the samething
Hi, The Right Cartridge Incorrect error message generally indicates a communication error between the All-In-One and the cartridge. This can be due to a faulty cartridge or to a simple interruption in the communication between the cartridge and the All-In-One. The procedures below will help you identify the cause and resolve the issue.Lexmark uses, at least they used to, a chip in the ink catridges that verifies that the ink catridge is Lexmark and hasn't been refilled. There are ways around it, which is why third party cartridges work. Yours may not have been reset or damaged when refilled. Follow the below steps: 1) Disconnect the power from the printer.
2) Remove the black power brick/block from the rear of the machine. (It may be a little tough to pull it out the first time you remove it.
3) Open the top of the printer/multi-function unit.
4) Gently pull the ribbon in order to center the printer cartridge carrier.
5) Open either the left or right side and remove the cartridge. (Depends on which side the error is occurring on, black on the left, color on the right)
6) Verify that all of the plastic strip that covered the new contacts on the cartridge have in fact been removed.
7) Wipe both the cartridge and printer contacts with a dry, lint free cloth.
8) Wipe the bottom of the cartridge with a damp, lint free cloth in order to verify that the ink is flowing and looks correct.
9) Make sure there is no water remaining on the cartridge.
10) Re-insert the cartridge into the carrier and make sure that it is bottomed and inserted all the way to the rear of the carrier slot.
11) Re-insert the power brick/block.
12) Re-connect the printer power cable.
13) Power on the printer and the error should be resolved.
14) Run the print alignment and print or copy several pages to insure the problem has been resolved.
IF YOU NEED TO BE WITH THE ORIGINAL CATRIDGES PLASE FOLLOW THE BELOW STEPS.
ALWAYS PREFER LEXMARK CATRIDGES FOR LONG LIFE OF PRINTER
  1. Remove the indicated print cartridge.
  2. Disconnect the power cord from the electrical outlet.
  3. Reconnect the power cord to the electrical outlet.
  4. If the button_power_0.jpg button is not lit, press button_power_0.jpg.
  5. Reinsert the print cartridge.
  6. If the error:
    • Does not reappear, the problem has been corrected.
    • Reappears, replace the print cartridge with a new one.
      BESTWISHES.....
Dec 19, 2010 | Office Equipment & Supplies
My lexmark 7170 printer has error message : right cartridge incorrect. I pulled the brick. Waited a few minutes, replaced but error still appears. Turned off and on etc. Lexmark quide was not helpful. any...
You are trying to put the wrong catridge into right hand side,. the catridge you have put is incorrect. try removing the catridge and put the right catridge back
Jan 09, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark Z35: Problem Communicating with the
Installing like this Lexmark are Plug in Play, Windows automatically detected such devices connected on it. If not then try to use another USB Connector to see which is the problem occur or might be your printer too...
Oct 04, 2009 | Lexmark Z735 InkJet Printer
Wats the cartrige number for lexmark Z735 printer
Follow this link to Lexmark's website. There is an extensive list of cartridges available for this printer and you gave no indication as to what you needed. http://www.lexmark.com/lexmark/product/home/725/0,6970,204816596_653399455_483733205_en,00.html?tabId=7 Don
Jun 12, 2009 | Lexmark Z735 InkJet Printer
My x5470 won't print and error message says
Hi
Please do the following:
1) open the printer
2)remove the cartridge.
The problem is in scheme from printer that touches the cartridge from behind. You must clean this scheme from ink with a soft cloth dipped in spirit/kleannex.
Use the klennex/spirit and clean off those contact on the holder and printer will work again.
Then before you print anything, you should run cartridge alignment from control panel- printers and faxes-> right click on default printer-> properties-> printing prefrences(general tab) and also print a test page. Align the catridge and then run clean catridges a couple times.
Be sure not to leave any debris of klennex/spirit on those holder contact panel
Please ask for further assistance and Do rate the solution as "FixYa" if you found it useful.
Thanks
Rylee
Mar 17, 2009 | Lexmark X5470 All-In-One InkJet Printer
I have a carrier Jam!? It a lexmark x5320 I have tryed everything nothing works.
In this case unplug the Power Supply from the Printer...............
Take Out both the catridges from the Printer.................
Move the Catridge Carrier which holds the Catridges inside the Printer from left to right and from right to left for about 20 Times.......................
now insert both the catridges inside the Printer and Plug in the Power Supply and see whether you get the error message again.................
If u still have that error message please Call lexmark:
1-800-LEXMARK (539-6275)
Just call this number because the Enchoder strip has to be replaced........
Good Luck
Jan 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
click here to download vista version:
  • Download the above software.
  • Un-install your previous deriver.
  • Turn off your PC.
  • Remove all connection of printer from system.
  • Install new downloaded driver.
  • Don't connect the printer to PC untill setup says to connect or setup finished.
Thanks
Iqbal
Apr 29, 2008 | Lexmark Z735 InkJet Printer
Lexmark Z735 InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
