Question about Amana AOGD2750 Gas Double Oven
I need to know if the "self-clean" feature is fully automatic on the Amana ARG7301LL range and will it shut itself off?
  • rnewhouse662 Dec 14, 2008
    Thank You worked a-ok
    Genius:
  • 2,920 Answers
It should be fully automatic
Posted on Dec 14, 2008
How do i use the self cleaning feature
Hello Veronica Candeleria - I located the manual on the Frigidaire website. Here is the manufacturer link and hope you find all the information that you need. If for any reason you have difficulties pulling up the requested information, I recommend taking off the last letter of the model number so you can pull up the data
Feb 14, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
My electric Amana Range with self cleaning oven model Art6100 or Art6000 approx. 11 years old will not work on the clean cycle. Burners and oven work fine. We had the door off and apart to clean a few days...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
How do you use the self cleaning opiton
take the racks out,hit the clean button, then the start button, you may have a manual lock lever right above the door, some are automatic, but the door must be locked for the clean feature to work
Oct 29, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I have Jenn Air 30 inch slide in dual fuel oven JDS8860BDP I used the self cleaning feature on my oven 2 days ago and it has had a very strange odor ever since. A chemical oily smell within a few feet...
The self destruct or self clean feature has burnt the wiring inside your range... do not use that feature it causes the range to get too hot...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 15, 2010 | Ovens
My wall oven wont self clean because the automatic door lock wont lock what part do i change
Hi- The automatic door lock is a safety feature designed to prevent opening of oven door during 'self-clean', or as techs call it: 'self-destruct'. A previous full-power cycle has affected or destroyed a circuit or switch. The most common failures are the door switch, affecting the operation of door motor, or the control itself. - - -Start by replacing the door switch- available locally at an app. parts store. The electronic controls can also get 'cooked', causing a variety of faults, but these controls are expensive.------ On site diagnostics is needed many times. Remember---'self-clean' destroys circuits and controls eventually--every time. Don't let the salesman fool ya... Let me know if this info helps- have more if needed.  Thanks- Ed
Mar 16, 2010 | GE Ovens
I inherited an older Amana Gas oven that is self
Here is an older manual with instructions on self clean and everything else. Hope it helps!
http://shop.amana.com/assets/pdfs/literature/30946503.PDF
Jan 29, 2010 | Ovens
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Self Cleaning not working
What does it do when you put it into a self clean, any error codes, and have you ever used the self clean function before?
Apr 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Amana AOGD2750 Gas Double Oven Logo
103 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
john mabry
Are you an Amana Oven Expert? Answer questions, earn points and help others
