Question about HP Photosmart 2610 All-In-One InkJet Printer
Printer keeps blinking error 0x886a6b72
Had a storm and the power was knocked everything surged power surer click off and now can't reset or use the printer in any capacity
    Guru:
  • 1,463 Answers
HI.
have a look on here HP Photosmart 2610 All-in-One Printer
if you need the drivers they can be found on here as well
hope this helps
riz.
Posted on Dec 20, 2008
I have a D52GW12 tv. During a storm a couple days ago there must have been a power surge. I have managed to get the TV's power light to blink but it won't turn on. How do I reset the Tv or fix the...
Unplug from the wall and hit the power button on the tv. The light may come on dim then fade out or you hear a click. This means it has built in surge protection. Plug it back into the wall and you should be good to go if nothing burnt up.
Jun 21, 2011 | Televison & Video
My Brother HL-2140 Went out in a storm. All three lights just keep blinking no matter what I do. Held down on the blue light button a number of time, restarted computer, turned off printer, reloaded ink...
You can find the usre's manual here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hl2140_all&dlid=&flang=English&type2=-1
1) If the LARGE BLUE BUTTON is blinking:
Data remaining in memory
There is remaining print data in the printer memory. If the Ready LED is blinking for
a long time and nothing has printed, press the Go button to print the remaining data
in the memory.
2) If the TONER LED is blinking:
Toner low
Indicates that the toner cartridge is nearly empty. Buy a new toner cartridge and have
it ready for when Toner life end is indicated.
The Toner LED will turn on for 2 seconds and off for 3 seconds.
3) If the DRUM LED is blinking:
Drum life end soon
The drum unit is near the end of its life. We recommend that you get a new drum unit
to replace the current one. See Replacing the drum unit on page 69.
The Drum LED will turn on for 2 seconds and off for 3 seconds.
4) If the RED ERROR LED is blinking:
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document.
Mar 26, 2010 | Brother HL 2140 Laser Printer
Blinking standby light, dead dvd player
Hello illeanaceres,
I'm sorry to hear about the bad news, I had something similar happen to me around a month ago.
Honestly there is not much you can do if it is damaged due to a power surge. Resetting it would be the normal procedure.
Surge protectors only protect equipment up to a certain amount of joules. Basically if the lightning is powerful enough it can damage electronics with that initial surge. You should replace your surge protectors every few years if it is 2-3 years old then it may not be as effective.
Post back if you have anymore questions or comments. Thank you for choosing Fixya!
Jul 13, 2009 | GPX D1816 DVD Player
I have the same problem error message 0x886a789e
The surge has blown up the chipset that produces the signals required for faxes.
If you have a surge protector fitted then the maker should repair or replace the printer under their terms of warranty.
If they sell you protection then they have to offer it
Jun 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Power issue
Sounds like your power supply may be shot on your computer. You can get a power supply tester and check it. Not sure what to do about the printer. If you had a surge protector in between your computer and ac. Plug the computer and printer back in to the AC outlet directly and see if that helps. Hopefully only your surge protector is damaged.
Please rate, Thanks.
Feb 09, 2009 | HP PSC 950 All-In-One InkJet Printer
Onkyo TX SV7M Knocked out by Power Surge
Try pulling the plug out of the wall for 5 min or more,give the unit a chance to reset.Hopefully you didn't get a power surge that might have blown the protection circuits.
Jan 03, 2009 | Onkyo TX-SR705 Receiver
Problem with HP Photosmart 2610
You need to reset the printer.. Unplug it from the power.
Then please remove the USB Cable from your PC completely.
Restart your PC without connecting USB cable back to your PC.
Now connect the USB Cable into the USB Jack from both ends and start your PC.
After doing above steps please reboot your PC finally.
And push the power button for 4 times and then power on .
Let me know the result, so I can further investigate the problem.
Oct 14, 2008 | HP Photosmart 2610 All-In-One InkJet...
Error message 83C00009 on HP L7680
I had the same error and I just did the following and it reset the printer back to defaults and things are working once again.
1) Turn printer off (pull power cord)
2) Press Cancel button on top of printer
3) Turn power back on (plug in power connector)
4) Keep pressing Cancel button untill it looks like it reset
Jul 30, 2008 | Office Equipment & Supplies
Error Message Error 0x886a6b72
I contacted www.hp.com and after a while we decided it is fried.
Lightening had hit my cable box and must have got the printer too.
All it will do is flash even after trying to reset to factory settings.
Thanks for the offer
Jun 25, 2008 | HP Photosmart 2610 All-In-One InkJet...
Mits 65" wont power on
set could have a short and be in shut-down mode ...making just a blinking green light on the front.
remember your standby circuit is always on waiting for a remote command and can be damaged by surges in the line from storms.
please add a surge protector in future after you found the failure.
May 11, 2008 | Mitsubishi WD-62725 62" Rear Projection...
HP Photosmart 2610 All-In-One InkJet Printer Logo
753 people viewed this question
Ben Johnson
