Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Shaky/Unstable Picture I have an Akai PDP4298ED1 that is 3 1/2 yrs old. This afternoon when I turned on the TV, the picture was shaky. I turned off the cable box and the DVD and checked the TV only...still shaky. Now we've been messing with it for about 30 minutes, and the picture has slowly stablized. Any ideas?
  • jim9795 Jan 05, 2009
    We have the same problem...after about 1-2 hrs on...picture shakey ...we turn off for 1/2 hr and works fine for a while...???
This is power supply issue, one or more of your filter capacitors either bursted and/Or over heats (this is why it becomes better when system cools down after turning it off for 1/2 hour..You have two choices.1. buy a replacement power supply may set you back a couple hundred dollars but it will be plug and play. 2nd you can replace these filter capacitors make sure the can handle 105 deg celsius not the 85 deg. celsius, if you know how to trace the bad ones and desolder and solder new ones on the power supply board, or hire a techinician to replace them for you. Good Luck...
Posted on Feb 06, 2009
Dusted the bulb box. then when i turnd tv on, picture is unstable
Make sure you put everyting back correctly. It can be that you forgot to tighten the allen bolt and the cage is moving.
Jun 01, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Shaky picture AKAI PDP4298ED1
THERE MAY BE SOME CONDENCER LEKAGE SOMEWHERE IN THE HORIZONTAL SECTION
Mar 23, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Shaky distorted picture first 5 minutes when tv turned on.
Those have a problem with the capacitors going bad in power supply. Yes, it's worth having checked out because a GOOD shop will be able to fix the problem and not have to change a board. Very common problem with these sets. Mine did the same thing until I fixed it. Just do your homework when finding a shop. Call around and talk to other people in the area to see who they use etc.. Good luck. Could be a very simple repair. Have it checked.
Dec 03, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Shaky hand symbol and bad quality photos
good day,
to disable/enable the "shaky hand" symbol of your camera, just select the Picture Stabilization icon on the dial on top of the FinePix F30.
i hope this helps.
Oct 12, 2008 | Fuji FinePix F30 Digital Camera
Picture on email is unstable looks shaky.
if u have graphics card means jus remove it and connect it in the ordinary pin
Jul 03, 2008 | E-Machines eMachines Desktop PC
Shaky Picture only during Advertisement or... Mitsubishi SC 27403
If you have cable then put the cable wire directly in the TV, bypassing the cable box. If the pix is Ok it proves that the problem is the cable box. If the problem is still there then it proves the the TV needs parts inside.
Mar 24, 2008 | Televison & Video
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
345 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
