42' polaroid tv wont show screen still
Brand new tv wont show the screen after it is turned on. The TV goes to polaroid screen for 2seconds, then goes black. After 10min still black and the power light is solid blue. Is this a problem I can fix or defect? Model polaroid TLX-04244B
  • casper40 Dec 14, 2008
    screen still black...
  • Anonymous Jan 28, 2009
    Some times the screen will go black whilw watrching then when you turn it back on it will start then turn black again, The volume however is still on.
  • 4 Answers
Well if the light stays blue , that means its still on ...what you may need to do is go to your menue and select the setup selection and then go to tuning band.....i belive it will be on page 32 of you manual, under customising the setup settings....in order for the tv to start working it needs to be able to scan for channels.....if you are useing a cable company like comcast or direct tv...depending on how you pluged it into the tv ,(like using the input 1 or 2 , s-vidio, cable , ectra,)...you need to push the input button thats on the lower right side of your remote and select the propper input area as to how you hooked up your cable box
Posted on Dec 14, 2008
It is a manufacturing defect. Mine had it. My advice is to never buy polaroid tvs. but anyway, here is a link on how to fix the problem...
http://www.fixya.com/support/p443928-polaroid_flm_3732_television/tips
Posted on Dec 29, 2008
Polaroid LCD tv - model TLX-04244b . Flashes the blue polaroid screen then goes black ,I hear a buzz coming from the inverter board. I have replaced both inverter boards and the same problems exisis .
I just changed out the invertor boards and mine was fixed. I had the same problem. Im not a TV repair man but replace the board thats buzzing and it will work again.
Jun 23, 2012 | Polaroid 4226TLMB 42 in. LCD TV
I have a Polaroid 42" TV and the screen does not
if its a hd tv try viewing a true hd source and the grey areas should go away. you might have and resolution button on the remote that will toggle between screen modes. look for that button and give it a whirl and also make sure yoiu view a true hd program
Dec 24, 2010 | Polaroid Televison & Video
Everytime i turn on my lcd tv it turns on and the pictur goes off
there are flourescent tubes inside that can be replaced, they help to alluminate the screen. There are these other boards inside that can malfunction too, best to take the unit to a technician.
Dec 13, 2009 | Polaroid 4226TLMB 42 in. LCD TV
I have a 42 Polaroid TV that has shadowning some
It is probably problem with the screen. Go here to find the answer
polaroid tv parts
Nov 12, 2009 | Televison & Video
Polaroid 4241-TLXB wont stay on
I think I may have just solved this issue. Remove the back covers and turn the tv on until it the screen goes black. There will be a little red led that will light up when the screen goes black. right above that light there is 4 little swiches, the bottom one is labled BURN. Switch that one to the opposite direction. I don't know how but mine has been working for a couple days now with no issues. GOOD LUCK!
Jul 05, 2009 | Polaroid 4241-TLXB 42 in. LCD Television
42 IN CH POLAROID HDMI BLACK SCREEN
i had the same problem. i opened the panel in the back of the tv (3 screws) and opened the aluminum panel (3 screws). there's a red led light located at the bottom left corner of the top board. to the right of the led light, you will find this thing with 4 switches. i turned the two bottom switches "burn" and "epmw" to on. so far tv have been working.
Jun 12, 2009 | Polaroid FLM-2632 Television
Poloaroid 42' LCD tv wont come on
well if you get a screen that shows the polaroid logo with a bright ble screen then goes to black...some q's to answer for me ....does the power indicator on the lower right front of the tv go red,stays blue,or goes out completly??
Dec 13, 2008 | Televison & Video
No picture
if nobody will repair the tv, then your probably better off buy a new one. yours could have the bulbs blow, there could be something wrong with the board or the power supply. i don't recommend working on a tv because they are very easy to mess up and do even more damage. for your next tv, get a higher rated brand like samsung or sony. they tend to be more reliable and are easier to fix/find somebody to fix
Oct 21, 2008 | Polaroid FLM-4201 42 in. LCD Television
Televison & Video Logo
1,003 people viewed this question
Top Televison & Video Experts
Electro Med Services...
