Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Plastic piece that raises and lowers the bowl
Is this piece that is inside the stand that connects to the handle and in turn raises and lowers the bowl called a planetary
    Problem Solver:
  • 5 Answers
Planetary is the mixining action which was started by kenwood on there mixers in the 50s
Posted on Dec 17, 2008
My kitchen aid stand mixer startnig making noise and wobbling. I noticed that the pin attaching the top to the base has been pushed out halfway and I can't push it back. Any solutions?
Remove the bowl, turn it upside down on a towel, look up inside the pedestal. Right in the middle where the hinge pin goes through there is a screw, unscrew it a little, push the hinge pin back to where it belongs and then tighten the screw up tight. Turn mixer up the right way, raise head up, fit bowl & flat paddle. Lower head & turn machine on low, listen for paddle tinging on bowl, if it is touching turn off and raise the head. Look into hinge area from the front, that screw is the head height adjustment. Clockwise to lower paddle in bowl, anti clockwise to raise. You want to lower it until you hear the paddle tinging on the bowl & then raise it enough to clear without tinging. You don't wind the screw in & out huge amounts, 1/4 to 1/2 a turn at a time is plenty.
Dec 14, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
How do i adjust the bowl height on an ksmc5os?
I'm not familiar with your model but on stand mixers with crank handle bowl lift there are 2 places for it to be. With bowl lift down there can be s screw straight in from the front on the pedestal just above the bowl lift sliding bracket, the full range of adjustment is half a turn, anti clockwise to raise, clockwise to lower. The other one is a small screw sticking down from under the gear case where the bracket that carries trhe bowl slides up and down. Clockwise to lower, anti clockwise to raise.
Aug 19, 2014 | KitchenAid KSMC50S Commercial Stand Mixer
I just bought a new Kitchenaid KP26M1XCV. However, when it was delivered, I found some platic piece which broke and came out from the inside of the stand where the handle (to raise the bowl up and down)...
first of all it is warrantied by Kitchenaid. Call them and describe the problem. they will send you a new mixer and a paid UPS return slip for the old one. If you want to fix it yourself:
look at item 18 on this diagram:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10157992.pdf
also check to see if any of the other parts are broken. bent or missing.
I found item 18 online for 7 bucks:
http://www.smallappliance.com/product.asp?pid=15733&cur=USD&cam=partscatalog
Bob
Feb 14, 2011 | KitchenAid KP2671 Professional 6 Series...
Handle is very difficult to move to get bowl to raise and lower. Any suggestions on repairing this?
thats because there debris between the bowl yoke and ways. use wd-40 to loosen up you might even need some heat to aid youkeepmoving and spraying, after yoke is freed, use a food grade grease on the ways to prevent binding. dont forget to vote
Feb 06, 2010 | Hobart A200 Stand Mixer
Hobart HZ (h600?) Raising handle is acting up
You will need to confirm the model number. An H600 or L800 have a wheel to manually turn to raise and lower the bowl. The M802 and V1401 hav a belt driven bowl lift clutch, operated by a lever. When you push the lever up or down, you are engaging a small transmission between the motor and main housing. You would need to remove the top cover and see what's happenning. It may be there is something other than the proper spiral pin joining the lift lever to the clutch input shaft, giving alot of backlash and insufficient selector movement.
Aug 18, 2009 | Hobart H600 Stand Mixer
Bowl Lift Mixer does not lift!
well first you shoul read the menual to repair and then call the company and u can replace it.
Jul 23, 2009 | KitchenAid KP26M1X Stand Mixer
Can't get the screw adjustment to change the height of the bowl
I had a similar problem with mine - the problem turned out to be that I hadn't clicked the bowl into place corectly. If you find the bowl is tilting forward slightly then you probably need to push it into the clip at the back.
May 17, 2009 | KitchenAid KP26M1X Stand Mixer
Loud and throws flour all over
Do you find the motor running too fast at the lowest setting? Then you need to bring it to someone to adjust the low speed setting. If you are preparing double batches you are over loading the mixer and/or using too fast a speed setting to mix. Don't try to double recipes just because the bowl can handle the volume, the motor cannot and will not last very long if stressed mixing dough frequently.
Nov 13, 2008 | Betty Crocker 340 Watts BCF1250 Stand...
Incomplete mixing
You need to raise the bowl just a little less than the thickness of the layer presently being left behind. Too much and the beaters will touch the bowl .
Jan 31, 2007 | Bosch 700 Watts MUM7010 Concept Series...
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
94 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
