Question about RCA R52WH76 Television
My tv has got to where the volume goes down on it's own, the menu screen pops up all the time, and the tv has turned it self on once.
    Genius:
  • 1,030 Answers
This is farely comon i see this all the time at the shop... you have two options replace the keyboard cuircit board. or disconnected and just use your remote to control tv. of coarse you can remove the board until you get a replacment
Posted on Apr 05, 2009
My 40 toshiba model # 42av5000 hd, lcd flat screen, my volume goes down by itself
hi select menu sound setting look for avl if it's on turn it off, if this don't work, you may need to to replace the mainboard, thanks
shaun
May 15, 2017 | Toshiba Televison & Video
My panasonic tv model TC32LX85 N has self check and wont go away?
To Exit Self-check Screen
  • Press and Hold Power button on the TV for 5 seconds [or] disconnect the AC cord from wall socket.
TV volume down and OK on the remote only does a basic IC self check. It do not rest the TV. It do not clear channel programmed settings, picture settings, channel labels, lock settings or password. Using this method, it shows the units' firmware version [Peaks 1.050 and GenX 1.00] and it checks the IC communications only. This is more useful to identify the firmware version, without having to decode the info in the setup menu about version/screen.
TO RESET THE UNIT
  • To make a reset to TV, turn it ON while pressing the [Volume-ve] button on the main unit, and press the 'Menu' button on the remote control for more than 3 seconds. The self check menu appear on the screen. Then disconnect the AC cord from the wall outlet. [ALL PROGRAMMED PARAMETERS WILL BE ERASED]
Jul 30, 2014 | Panasonic TC-32LX85 LCD TV
Menu pops on and off for about a minute when i first turn the tv on
the self diadnostic program in the tv is going bad.. may be time to replace the tv or dont shut it off completely
Jan 21, 2014 | Samsung LNT4665F 46inch 1080p LCD HDTV
FPA turned on and I have only a universal remote
In most ceases, you might have its original remote control to unlock it. Anyway, try this.
1.Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2.Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3.Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
4.Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
5.Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 21, 2013 | RCA TruFlat 27F520T 27" TV
My screen indicates hdmi 720p on the top right corner then the video menu pops up. it goes back and forth making watching tv unbarable. also the volume flashes when it is pressed i have a Hesense 32 inch...
The HDMI 720p pop up,because on the tv Menu setup OPTION,U pick YES on the tv Program Title Display option,pick NO should stop the pop up HDMI 720p indicator.The volume bar indicator pop up when it press the button to turn volume up or down it is mornal functions of the tv.
Apr 04, 2011 | Televison & Video
RCA HDTV MENU AND VOLUME CONTROL POPS ON AND OFF SCREEN.
My TV was doing the same thing. Someone told me to disconnect the front menu buttons and this worked for me. The board goes haywire. You have to take off the front black panel on the bottom first then the grey front panel where the controls are. Once you do this you will see where there is a plug from tv to the panel where the control buttons are. Just disconnect. You will only be able to use your remote for TV. Its a cheap and easy fix. Just lots of screws to get the panels off and on. Good luck!
Apr 09, 2009 | RCA HD52W58 52" TV
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
V-chip
if its a durabrand i went to the ORION website and called customer service cause i bought mine from a pawn shop and had the same problem mine is a dtv1907a so here is what you do... unplug any cable, ant, and so on from the back then find a channel that looks like snow where no pic is tryin to come in and then turn the volume all the way down.. hold the down volume down at the same time point the remote to the tv pushing the number "0" hold it till the menu pops up then relese the 2 and just let the menu clear off the screen once the menu clears off the screen the v chip has been reset.. real easy
Jul 07, 2008 | Durabrand DWT1304 13" TV
No Volume Unless
you might want to take it in to a repair station. The buttons on the front might need replacing.
Jan 25, 2007 | RCA F36668 36" TV
RCA R52WH76 Television Logo
78 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
