Question about HP W1707 LCD Monitor
I reloaded win xp get lowest res. cant get higher res
Every time i try to change to a hifher resolution i get and error on monitor that says its not at the right resolution input.
  • 71 Answers
Sounds like you need a driver for you video card go to
Posted on Dec 14, 2008
Input out of range
The problem is likely to be screen resolution too high in windows 8. Boot it to safe mode, (which should be at a lower resolution) and reduce it down to the lowest setting. Reboot to normal mode and then adjust your resolution to a higher setting that works. Alternatively get (beg, borrow or ... otherwise obtain) a monitor with a higher resolution and make adjustments required.
If it does turn out to be a driver problem, you should also be able to fix this from safe mode.
Jan 02, 2014 | ATI Computers & Internet
When i try to change to res it says out of range. it stays at 800 x 600.
Max Sync Rate (V x H) 76 Hz x 83 KHz
Max Resolution 1280 x 1024 / 60 Hz
Try changing the Hz to get it to accept a higher res.
Dec 02, 2010 | HP vp17 Monitor
How do I reduce the screen size? Everything is appearing too big, especially in my web browser.
Your screen resolution might be set to a lower setting.To make the content on your screen
smaller,you need to set a higher screen resolution.Please follow the instructions on the following link to
do that.
Nov 27, 2010 | Compaq FP 7317 17" LCD Monitor
I just reloade Windows XP Home and my E15LCD1 get out of range
when the computer turns on , keep pressing f8 or f12 to give u a boot options, choose safe mode. when windows xp loads up right click on desktop and goto properties, then click settings, then addvance, then click on the monitor tab, and lower the screen refresh rate down to its lowest and then restart pc. hope this helps. if u cant change these options in safe mode use a normal monitor and lower them down to 60 hertz and then put back in your lcd. hope this helps.
Nov 30, 2009 | Liquid Video E15LCD1 15"
Some games need 1440x900 resolution to play but when i go to the display settings to change it, its not there just 1360x768, 1600x1200 and lower ones. I need help????
Hi there. If you're able to get 1600x1200 on the monitor, that should suffice--anything equaling or larger than the game's required res is ok...the picture will have a little bit of border on the edges because of the higher resolution but shouldn't be a hinderance at all. Remember this...the higher the resolution, the harder the graphics card has to work to maintain proper movement of the images in the game. Use the exact res if possible. However a close, higher res is fine, too.---Rick
Oct 03, 2009 | HP Compaq WF1907 Monitor
My samsung syncmaster 2233sw shows multiple displayes when i take it to its max res. i use win xp sp2 and have nvidia 8600gt gfx card. the monitor works well on lower res but only shows this problem when i...
Typically this is a driver issue on the host (PC) side. DVI or VGA connection? Update the video driver. Some video drivers (especially older laptops) can't correctly send that resolution.
Jun 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Screen resolution on powerpoint cannot be locked at high res. Changes when connected to my projector. Monitor screen res. also changes everytime the projector is plugged in, In power point display (2nd...
I just checked the specs on your Benq PB 6110, which has a native resolution of 800X600 and will simulate 1280X1024. When you connect it to your computer, the computer goes to 800X600, right? That is the resolution of the BenQ. How high a resolution do you want? THe highest I have seen in projectors is 1024X760, which is not that much higher. Projectors seem to lag behind monitors and Plasma/LCD/LED TVs for resolution. They must have a very small market share therefore low developement.
May 07, 2009 | Microsoft Office PowerPoint Home and...
Out of rang vw193t
Pls temporarily install a older monitor then check the display sttings ,set it to the lowest resolution apply and then check whether its working on the old monitor.Then shut down and connect the new monitor and power on the monitor should work
Jan 24, 2009 | ASUS VW193T Monitor
Out of frequency LG500g
15"LG Studioworks500g Monitor Supports Up to 1024by768pixel resiolution.
First U can check UR system res is High and than Go to Enable VGA mode on ur system.
Sep 20, 2008 | Computers & Internet
HP W1707 LCD Monitor Logo
64 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
