Question about Panasonic PV-DF2704 27 in. TV/VCR/DVD Combo
Panasonic pv-df2704 27in. green light indicator flashing
I do not have my remote and my tv is "locked" in record mode. Can I get a universal remote to "unlock" and utilize my tv again?
    Sergeant:
  • 291 Answers
Best bet for now is to unplug the tv from the a/c and let it sit for at lease a full day...no kidding... then replug and play the tv again.
Posted on Dec 14, 2008
How do u program a phillips universal remote to a panosonic fm radio model # pv-c1320
Philips Universal Remote control Instructions
  1. Turn on the device (TV, DVR, etc.) you wish to operate.
  2. Press and hold the SETUP button until the red light indicator remains lit, then release the SETUP button.
  3. Press and release the desired mode button (TV, DVR, etc.).
More items...
Philips Universal Remote control codes for TV, VCR, Set-top Box ...
www.directutor.com/.../philips-sru210327-universal-remote-control-codes-tv-vcr-set-top... How to setup phillips universal remote to panasonic tv Google Search ..not sure if it will help you out but have a look.
Nov 29, 2016 | Universal Televison & Video
How to setup phillips universal remote to a panasonic tv
More items...
Nov 29, 2016 | Panasonic Televison & Video
What is the TV remote controller code for a Panasonic Model # PV-C1320?
Hello
Universal remote codes for Panasonic TV/VCR combo are:-
0374 0381
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Mar 04, 2011 | Panasonic PV-C1320 13 in. TV/VCR Combo
I need a remote 4 it
Hello
Just select a PHILIPS CL034 UNIVERSAL REMOTE CONTROL. Panasonic is listed in its codes. Codes are
............ 0718 0416 0007
........................... 0618 0807 0039 0739
........................... 0345 0696 0901 0608
Direct Code Entry
1. Press and hold the CODE SEARCH
on, then release the CODE SEARCH
button.
flashes.
OK.
Feb 07, 2011 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Need the remote code for this model tv
Hello
Three digit universal remote code for Panasonic are:-
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit universal remote code for Panasonic are:-
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Direct Code Entry
Note: Switch OFF and switch ON your TV with its front panel power control switch [Main power control] each time before proceeding for an other code.
OK.
Jan 20, 2011 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
What is the tv//dvd/vhs remote code for pv-m2799 treple play como unit?
Hello
Four digit universal remote code for tv/vcr/dvd combo is
0437
Direct Code Entry
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. OK.
Dec 09, 2010 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Need remote control code
Hello
Three digit universal remote control code for Panasonic are:-
Four digit universal remote control codes for Panasonic are:-
Four digit unversal remote control code for Panasonic TV/DVD/VCR combo is
0437
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR/DVD. Otherwise just the one code operates both the TV and the VCR/DVD.
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Dec 02, 2010 | Panasonic PV-DM2792 Triple Play 27 in....
We just purchased a Panasonic VCR/TV Universal remote for our PV-V4021 VCR and find we no longer have a user guide. How can we set the VCR to record at a later time, such as later in the evening? Where...
The problem with universal remotes is that unless you enter the correct code for that model not all functions will operate. You need to try every Panasonic code in the code book, untill you find one that works the guide function. Otherwise the only real solution is to get the original remote.
Aug 21, 2010 | Panasonic PV-V4021 S-VHS VCR
Panasonic pv-df2704 remote control does not work
if you have a mobile phone with a camera on it put it into video mode to record a video and point your remote control at the lens of the camera at arms length so you can see the remote through the screen on the phone then press any buttons on the remote control and that will tell you weather it is working or not, you should see a light flashing on your remote control that is not visable to the human eye (the camera on your phone can see it but you cannot) you will see it via your phone camera, change batteries on remote control if you dont see the flashing light emmiting diode on your remote control. (infra red) otherwise take your tv to a repair shop,
Mar 28, 2009 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Tv Combo will not work with replacement remote
my panasonic tv model no. PV-DF2704, program light is blinking and I don't know how to cut it off. It is causing my tv to cut off. My remote control will not work. I bought it second hand. I program a universal remote and it works for a little while, but I can not set my tv for cable. Please help me if you can.
deborah from Louisville
Nov 12, 2007 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Panasonic PV-DF2704 27 in. TV/VCR/DVD Combo Logo
179 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
