Question about Kenmore 63942 Dryer
Kenmore Gas Dryer
Dryer will not start. When you hit the start button, it makes a clicking noise, but it wll not start.
  • vrazz12 Dec 24, 2008
    Thanks but I think it is the motor. We cleaned it out and turned it to start. it worked for one load and quit again,
  • 71 Answers
Chech the thermal fuse located above the vevt outlet looks like a 2" white plastic capsule with 2 wires
Posted on Dec 20, 2008
When I hit the button to start the dryer it just makes a click sound like it did before but it won't start up
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Jan 06, 2011 | Kenmore 74602 Gas Dryer
Gas Dryer stopped
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 16, 2010 | Kenmore 74972 Gas Dryer
Kenmore 64112 dryer wont start when I hit the start button
Check house fuses or circuit breaker.
Pull 220V cord from wall outlet and inspect the gold prongs.
If you see any burnt areas on the prongs the outlet is bad.
If the unit makes no noise when you press the start button check the dryer door switch and make sure it clicks when depressed.
Sometimes the door switch arm can break off so when the door closes
the door switch cannot be activated.
If you hear a growl noise when you press the start button 2 things...
1. The motor is bad and needs replacing.
2. An object fell down the lint trap and is preventing the motor from turning.
Also if the dryer vent has been plugged causing the dryer to over heat a saftey fuse may have blown and needs replacement.
Jan 16, 2010 | Kenmore 64112 Electric Dryer
Kenmore 80 Series Gas Dryer won't run unless empty
MORE THAN LIKELY YOUR TENSION PULLEY IS SHOT WAS IT MAKING ANY SQUEEKING NOISES
Aug 26, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 series dryer doesn't turn
your dryer motor has just gone bad,it is no longer strong enough to turn over-sorry-mike
May 04, 2009 | Kenmore 73952 Gas Dryer
My Kenmore Soft Heat Dryer starts, then stops.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fsh
Dec 10, 2008 | Kenmore 74602 Gas Dryer
Kenmore gas dryer 97273100 was drying, but making a loud noise
You need a belt. Here's a link to a site with a good set of instructions if you want to try repairing it yourself. (You should DIY. You can save a bunch on the service call and the belt is only about $20.)
http://repair2000.com/wpoolbelt.htm
Dec 08, 2008 | Kenmore 72982 Gas Dryer
Won't start
IF ELECTRIC CHECK 220 VOLTS @PLUG MAKE SURE DOOR SWITCH IS FULLY ENGAGED
Nov 28, 2008 | Kenmore 73952 Gas Dryer
Kenmore 80 series dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
42 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
