Question about Panasonic (UJDA750) CD-RW/DVD-ROM (Combo) Burner
DVD/CDRW drive not recognising any DVD's
I have a Toshiba Satellite A10 with a matshita ujda750 DVD/cdrw combo drive. For some unknown reason it does not recognise DVDs. Basicly when I insert a DVD it's as if there is no disc in the drive. Interesting enough I can still burn & player standard CD's. I have uninstalled the drivers and windows detects the drive & reinstalls the drivers, and this doesn't fix the problem.
Re: DVD/CDRW drive not recognising any DVD's
Hi people!!
This fixed my problem. Give it a go, I have access and am using my burner once more.
Good luck!!
Note: The solution provided requires editing of the registry.
  1. To begin the process, start the Registry Editor.
    • Click Start, click Run, type regedit, and then click OK.
    • On Vista machines, Run is accessible through Accessories.
    • Click the plus sign (+) next to the following folders in the left side of the window pane:
    • SYSTEM
    • CurrentControlSet
    • Control
    • Class
    • {4D36E965-E325-11CE-BFC1-08002BE10318}
  2. Look for any of the following names in the right side of the window pane:
    • UpperFilters
    • LowerFilters
  3. If any of the items above are listed, right-click on the item and select Delete.
  4. Be sure to restart your computer after you have deleted the files in the registry.
  5. Open My Computer (XP) or Computer (Vista) and check to see if your CD or DVD drives have returned.
  6. In some cases, you may need to reinstall some programs such as CD or DVD burning software, iTunes, or Nero
Posted on May 17, 2010
This is a software problem I believe since I have the same problem, but I was able to partially fix it.
I suddenly lost the recognition of the laptop built in Matshita UJDA760 CD drive, it was not recognized by in "my computer". I went to a forum and downloaded a file:"sa55audiox.exe" from
Now it recognizes my CD drive. I uploaded new audio drivers from Toshiba. I can now see my CD drive in My computer". read files off my CD drive but when I run Itunes or play music CD, I can see that the music is being played in grahic equalizer, but now sound. Well at least I got my CD drive recognized. Hope this helps at least half way.
Posted on Feb 02, 2009
  • 2,961 Answers
I am not 100% on this but in some drives there is a dual laser, one dvd the other cd, and the dvd laser may be worth tryng to clean with a cd cleaner, but, if yours only has the one, it maybe that the laser is faulty. The reason why it can read cd's is that the trackes are much wider apart and make it easier for the information to be read, but when it comes to DVD's the tracks are much closer and difficult for the laser to read, especially if missaligned.
Posted on Mar 23, 2007
0 characters
3 Points
My matshita ujda760 dvd/cdrw read and burn cd but can't read dvd rom. I uninstalled the drivers and reinstalled but the problem continue.
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Feb 04, 2011 | Panasonic (UJDA750) CD-RW/DVD-ROM (Combo)...
My disk drive is stuck and will not read the disk. How do I fix this?
make sure that the cdrw/dvd combo is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cdrw/dvd combo then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device ?
control panel admistrive tools,computer management,device manager scroll down cdrw/dvd drives?right click you can? you can update driver,roll back driver,or select properties general troubleshoot, select driver? click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Dec 01, 2010 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
Is the Matshita UJDA775 DVD/CDRW a DVD Writer ?
Download this little program DISCinfo 1.6.1. When you run it it will give you all the info you need about all your drives. It's good, I use it. Get if from here []
Mar 19, 2010 | Panasonic CD & DVD Burners
DVD writer of DELL Vostro 1400?
if it has a DVDRW drive the yes.........if CDRW/DVD then no.....but it can read dvds
Dec 29, 2009 | Dell Vostro 1400 / Inspiron 1420 - 24X...
Can this unit create (burn) DVD R?
No it is a CDRW which can only burn a CD! The kinf of drive you need is DVD+\CDRW. This drive will burn DVD and CD.
Dec 04, 2009 | Panasonic (UJDA750) CD-RW/DVD-ROM (Combo)...
The Laser Light Reader is out of adjustmjent or is very dusty. Manufactures will not fix the problem if the product in out of warranty. Your only choice is to consider it a CD-RW reader/writer only or buy a new one.
Jun 04, 2008 | CD & DVD Burners
Help!!!! I need a CDRW module for Aopen 1846 openbook
I think there are in stock 3 items Item No : MG433319 Price : $103.55
try this
Dec 26, 2007 | AOpen (60NJW37004) CD-RW/DVD-ROM (Combo)...
Data cd's not reading.
Laser dirty[ clean it with a cleaner disk] or burned out - replace drive.
May 19, 2007 | Panasonic UJDA730 CD-RW/DVD-ROM (Combo)...
Toshiba A30 - DVD-ROM CDRW
Wow, That's a weird malfunction. Only TDK??? What about other media types? Did you try a diffrent burning software?
May 12, 2006 | Toshiba (SD-R2412) for Satellite A10, A15,...
Panasonic (UJDA750) CD-RW/DVD-ROM (Combo) Burner Logo
3,241 people viewed this question
Top Panasonic CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Jose Cada
Jose Cada
Gareth Cockram
Gareth Cockram
Are you a Panasonic CD and DVD Burner Expert? Answer questions, earn points and help others
