Question about Technics SL-1210 Turntable
Removing platter I have a technics turntable model SL B300 which I haven't been able to find any information about it.I picked it up from a friend don't know much about it.Platter turns very slow.How do I remove platter to check belt. This must be an old model hope you can help me.It didn't recognize the model in the 'What product is it about' I put a different model its the only why I could send the email. Thank You Robert
  • wolf545 Dec 14, 2008
    I found out how to remove platter. THANKS WOLF545
I removed the rubber pad from platter.There is two round holes in platter lift platter by grasping these
holes. wolf545
Posted on Dec 14, 2008
Fuse location of technics SL 1200M3 turntable
Hi, you need to remove the platter and then unscrew the under platter cover to access fuses. Cheers john, Stylus City
Apr 01, 2014 | Technics SL-1200M3D Turntable
How do I remove the platter on a sl-bd22 Technics turntable?
You will have to lift off the cloth on the platter section to expose two rather large holes in the plattr. Insert your thumb and forefinger, and pull up.
Jul 12, 2010 | Technics SL-BD22 Turntable
SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from styluscity@gmail.com
May 16, 2010 | Technics SL-1200 Turntable
How do you install the belt in a Technics LP SL-B300
assuming that you have the correct size belt, remove the platter and place the belt onto the platter (bottom side). Replace the platter and using a pencil, grab the belt and place it around the motor hub. The slot in the platter should give you enough room to do this. Dan
Jun 07, 2009 | Technics Audio Players & Recorders
Removing the platter to oil the motor shaft
hi .... get any object ( like hammer, or handle or wood) tap slight on the middle spindle of your turntable until become loose,...
May 28, 2009 | Technics SL-1200MK2 Turntable
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
Technics SL-D303 motor noise
CHECK TONEARM GROUND TO SIGNAL GROUND WIRE OR SOCKET FOR CONT.
Mar 13, 2009 | Technics SL-1200MK2 Turntable
How to replace drive belt for model.# SL-BD22 ?
Nope, very simple...
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Feb 28, 2009 | Technics SL-BD22 Turntable
I need to put new turntable belt on a Technics SL-B200
The belt goes underneath the turntable platter. First you attach to the lip on the bottom of the turntable platter, then you put the platter on the turntable. You'll see some holes on the platter, after you put it on, just rotate the platter, until you see the motor shaft, then pinch the belt around the motor shaft.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Jan 01, 2009 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
286 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
