Question about Maytag SDE2606 Electric Dryer
Electric maytag stack dryer not heating...
Model number LSE9900. The dryer drum is turning but no heat is coming out of unit. Thanks for any help.
  • 145 Answers
That dryer is made by Speed Queen. A common failure part is the thermal overload, mounted on the heater box. Items 4 and 6 in the picture Iposted are possiblities.
Posted on Dec 14, 2008
Maytag Epic Dryer Model MED9700SQ0, everything lights up, power is on, but drum will not turn and no heat.
Can you tell if the motor comes on? If it does, then it could be a broken belt.
Sep 01, 2012 | Dryers
The dryer will run and the drum will turn but no heat. Maytag gas dryer model number: mdg9606aww
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 10, 2011 | Dryers
Drum still turns but no heat where do i find the heater
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 12, 2010 | Maytag PYE2300AY Electric Dryer
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
Model PYE2300 AYW the dryer turns on and provides heat but the drum does not spin
your belt has come off the drum or has broken. Take the model and serial number to parts house for replacement. The belt should be accessed through the back of the dryer. Good Luck on your repair. Make sure to disconnect electricty before removal of back.
Dave
Aug 05, 2009 | Maytag PYE2300AY Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Apr 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
MAYTAG ELECTRIC DRYER DOESNT HEAT. CAN YOU HELP ME?
Without seeing it, and very little info to go on, let me ask this, does the drum turn?
If there is no heat, go outside and check the exhaust, do you feel air blowing out?
If you do, then the heating element may be bad or the switch that sends power to the element may be bad. If no air blowing out, then I do not know any further. At any rate, a service man must come.
Nov 16, 2008 | Maytag PYE2300AY Electric Dryer
Dryer model LSE9900
FIRST THING TO CHECK IS THE DRYER VENT HOSE ,MAKE SURE IT'S CLEAR,THEN THE VENT WALL HOLE,STICK YOUR HAND UP IN THERE AND PULL ANY LENT OUT THEN GET A SHOP VAC PULL IT IN THERE WITH A RAG AROUND IT TO MAKE A TIGHT SEAL AND **** IT OUT,IF THIS DOENT DO IT YOUR HEATER BOX IS BAD,CALL A APPLIANCE REPAIR PERSON(NOT SEARS$105 JUST TO COME OUT)THANKS-MIKE
Jul 22, 2008 | Dryers
Maytag haevy duty stack washer dryer unit model # SE1000 series 06
I hope you got this fixed by now but if not I'll put in my 2 cents.. I assume that your dryer is electric and not gas. Assuming that is true then you probably have an open heater element.. similar to this used in electric stoves... There may also be other components that could have failed and in so doing, disabled power to that element. Could be a contactor or temp switch/thermistor.. Hope this helps and that you've already solved the problem...
Jul 05, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag SDE2606 Electric Dryer Logo
198 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
