Question about Gemini SA-600 II Turntable
Ground and power cord replacement
Need to know where I can get replacement power cords and grounds for 2 Gemini SA 600 II turntables.
  • 319 Answers
SOURCE: cable conector with ground from turntable to receveir
aaaaaaaaand...........what's your point?
Posted on Feb 12, 2008
gotgeek2
  • 565 Answers
SOURCE: what all can I attach a turntable ground wire to?
Connecting to another piece of equipment besides the mixer introduces the possibility of creating a ground loop, which, of course, is not desirable.
Just make a splice using Stakons (crimper). Just cut off the existing connector and crimp a (red) round crimp to the existing ground wire. Then take a length of same gauge and crimp a round a (red) spade Stakon on the other end. Then take a nut and bolt and connect the 2 round connectors and tape with good black tape (Scotch 33 or similar). That will get you through the Gig.
Posted on Feb 10, 2009
SOURCE: cant get my turntables turned on and there
if there is a slot for a power cord on the turntables them selves then yes you need the power cords
Posted on Apr 22, 2009
STYLUSCITY
  • 271 Answers
SOURCE: How can i connect my Gemini Turntable which has a
Hi, slip the ground cable in the side of the rca connection to the device without earth point.It makes no difference if it goes in the left or right jacks. styluscity@gmail.com
Posted on Sep 13, 2010
How to fix flutter & wow on a Gemini 500 XLii direct drive turntable
Direct drive turntables have electronically controlled speed. If the records you are playing are warped (not flat) that will cause wow & flutter. If that's not the problem then you might try connecting the turntable to a different power outlet using a long extension cord. Failing that, the turntable needs repair.
Jul 30, 2014 | Philips gemini XL-500 II Turntable
My technics 1200 hums when connected to the amp even when the power cord is disconnected.
Is the ground wire from the deck connected to the mixer?.
If everything is connected ok then the ground wire or phono cord could be faulty - look here for replacements :-
http://stores.ebay.co.uk/methleykev
Could also be a "ground loop" - try a ground loop isolator.
Jun 26, 2010 | Technics SL-1200 Turntable
Needle for vinyle and were to buy one
Contact this company, tell them the make of your turntable and the model.
Note; take out the <remove> from the link?
service<remove>@turntableneedles.com
Oct 15, 2009 | Gemini SA-600 II Turntable
Cant get my turntables turned on and there connected to my mixer do i need the power cords for the turntables????
Apr 21, 2009 | Gemini XL-500 Turntable
Gemini cdt-05 hybrid grounding noise
Well, number #1 - it's a Gemini. So, you can rest assured that the craftsmanship is not the greatest. It's hit or miss with this company.
#2, if the issue you are having is a ground issue, then perhaps the internal ground wire might have come loose, or there is some sort of interference somewhere. Do you have your turntables next to anything that draws alot of power? Such as air conditioner, or a microwave, fridge, etc? Also, connecting to the same power outlet with something that draws alot of electricity might have the same effect. Try a different power outlet. One that is not being used if possible. If you use a power strip or extension cord, try a new one.
There could be many issues which cause feedback.. the main thing is to determine what is NOT causing the problem. So, you know it's NOT your mixer. Great. Now, move on to the next step. Check your cartridges also. Try swapping them out, see if the problem follows. Many times the tonearms aren't grounded properly. There are 5 wires coming out from the tonearm - L+, L-, R+, R- and GROUND. If the ground came off during transport, or movement, this might be your problem.
- Davis
We are the Turntable Experts!
DIGITAL ANALOG THERAPY
Aug 08, 2008 | Philips gemini CDT-05 Turntable
Gemini SA-600 II Turntable Logo
135 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Don Hart
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
