Question about Dell UltraSharp 2001FP 20.1" LCD Monitor
Vertical Lines Dell Ultrasharp 2001fp
My Dell monitor has 2 vertical lines of discoloration, both approximately 1 to 1.5 inches wide. One has a red coloration to it and is located on the left side of the screen the other is green in color and is located on the right side of the screen. These discoloration bands are present even when the monitor has just been turned on. Is there anything i can do???
3 Suggested Answers
SOURCE:
SOURCE: vertical lines LCD Dell 2001fp
I had the same problem until I decided to go in to figure out what was happening. I am not a technician but I'm a pretty handy engineer...anyway I opened up the panel and separated the big bulky electronics board which is encased in a metal enclosure from the LCD panel itself. After carefully doing so you will find that the electronics which actually control the LCD is covered by a long and thin aluminum plate. This cover can be easily removed by unscrewing 3 or 4 screws. Now here is where the problem arises. I believe that there is one chip (the biggest one you will see) that gets very hot. I measured temperatures in excess of 110 degrees F. It makes sense that temperature is the problem since the lines begin after the panel has been on for some time. My simple solution to this was placing a fan right over this chip. In doing so you wont be able to place back the thin aluminum cover but that's a small price to pay in getting your screen back to normal. The fan should also be small enough for you to put the LCD Panel back together (without this thin aluminum cover). You can hardwire the fan to the Speaker voltage output. I made this fix to my LCD panel about 2 weeks ago and since I haven't seen the lines again. In my opinion Dell knew that this would be a flaw in the LCD because if you notice the power supply for the panel is external which is uncommon in my opinion. The power supply tends to get really hot so in an effort to prolong the life of the panel they made this an external attachment. Well this obviously didn't solve the problem and they went ahead and put it out into the market. If you would like more details send me an email at Mike28ML(at)optonline.net Good luck, with this issue cus I know it way annoying the hell out of me.
Posted on Oct 02, 2009
viziks
  • 220 Answers
SOURCE: I have 2 inch wide
Seems to be a problem of LCD panel? Cannot be cost effectively repaired. Samir
Posted on Feb 17, 2011
I have a Dell 1908Fp Monitor that was given to me and it has vertical faint lines about every 2 inches. I know its not the computer cuase no other monitors do this. I am considering that its a issue witht...
I had a Dell monitor that had two faint vertical lines in the centre of the screen. Tech support told me this was 'normal' for that monitor! I sold it.
Jul 27, 2011 | Dell UltraSharp 1908FP Monitor
Dell UltraSharp 2001FP (Gray) 20.1"
This monitor uses a power supply not just a cord . You can get one on e-bay very cheat . Just type out 2001fp an choose the person you want to get it from .
Feb 09, 2011 | Dell UltraSharp 2001FP 20.1" LCD Monitor
I have a 2001FP Dell LCD monitor with an intermittent 2" wide gray stripe down the middle (you can see through it) that I was told was a back light failure. Is that true? If so, what is the correct...
Bad lamps will either does not light up or have pinkish color. More likely to be T-CON board, check out the connection between the T-CON board and the Logic board. If the lines are vertical lines from the top of the screen to the botom of the screen, then that will be bad T-CON board and not much you can do, new LCD panel will be needed.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 23, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001FP vertical band issue
I'm having the same problem... there's also going to be about 5 years of dust sitting in there, so I hoping it might just be a failure of convective cooling. My first attempt to remove the bezel was unsuccessful, so I wasn't able to go in and look for any swollen capacitors or such. I have blown canned air in the sides, and it's actually doing a little better right now. Probably won't last... having a rather warm summer.
Jan 22, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Vertical band of green pixels 1-2" wide when monitor heats up
Sounds like you have some pixals going bad.
It could be heat related check to see if its under warrantee. Most screens have a 3 year on them.
Not sure about Dells.
Aug 21, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Connect Digital and Analog cables at the same time.Any use?
does not help. keep dvi connector (white one) on computer and in the back of monitor.
and surely it will not take away those vertical stripes.
those vert stripes... hmm... your monitor might have a problem which you can't fix by your own.
Feb 22, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Vertical lines on left half of screen
The problem is the driver tabs that go from the panel controller board to the panel itself.
This is normally a fatal failure since having it repaired is extremely expensive.
Mar 17, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Verticle blue lines, left side
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new one.
Mar 07, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell UltraSharp 2001FP 20.1" LCD Monitor Logo
196 people viewed this question
Ekse
Clive
Clive
