Question about Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive
I have a Max 9nt2a4-500 external drive can not format .
I have a Max 9nt2a4-500 external drive. It is a hand me down. I have Window XP on my laptop. I try to format the disk using 'quick format'. and it says "window was unable to complete the format". and I deselected 'quick format' and click "start', but it take forever. Please let me know what is going, how do I format this hard drive? Nancy
  • Maxtor Master
  • 27,725 Answers
you have to be the computers administrator to change any values on any computer hardware
and you must fall full control of your hard drives
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
If you are running a Windows XP OS then you might be able to:
click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps
Posted on Jul 27, 2012
SOURCE:
  • 4 Answers
SOURCE: my hard drive shows only 1.5 GB instead of 100
is it correct that you installed XP from an "upgrade" pack?
when you installed XP did you convert the file system to NTFS?
Posted on Dec 27, 2007
Bubbabear64
  • 2794 Answers
SOURCE: Maxtor External Hard drive not compatible with Mac
I would check Maxtors website to see if there is compatibility issue using that particular drive on a Mac.
Posted on Jun 10, 2008
WeListen2You
  • 538 Answers
SOURCE: Maxtor 3100 will not work on Desktop with Windows XP Home version
actually telephone numbers are not available through this service...perhaps you will consider a premium or chat investment of your resources.
Posted on Oct 20, 2008
SOURCE: Maxtor One Touch II - installation Software
I have a disk that worked for me and I am running windows xp. I also have the website address that is supposed to have the 98 drivers which could work perhaps. http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Maxtor_OneTouch_Drive_USB/Win98SE_Driver&vgnextoid=b07d8b9c4a8ff010VgnVCM100000dd04090aRCRD
Guess you could try them first and if that doesnt work I could perhaps make a backup of the disk/package/mail/ worth anything?
Posted on Apr 02, 2009
joecoolvette
  • 5660 Answers
SOURCE: Data disappeared overnight
I've seen a lot of flack about these puppies lately. It's usually due to the external enclosure, the harddrive is in, and not the harddrive itself.
It is for this reason, that I suggest that you take the harddrive out of this enclosure, and install it into a decent, affordable, new external enclosure.
External enclosures are relatively cheap!
The harddrive inside the Maxtor One Touch II is a desktop size harddrive. It's a 3.5 inch one.
(3 and a half inches across in width)
It is a Sata harddrive.
These are examples of external enclosures for a Sata 3.5 inch harddrive,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(My recommendation would be the Vantec NexStar 3 NST-360 Su-BL)
This external enclosure has instructions, is easy to install the harddrive, and uses a USB cable just like your old one.
Posted on May 14, 2009
External hard drive cant format into ntfs but only exfat
The propriety NTFS file format is used by the Windows operating system to format internal as well as external hard drives. You can format an external hard drive with the NTFS format using the built-in program included with the Windows operating system. The procedure is straightforward and does not require any additional software. An NTFS-formatted external hard drive can then be used with any PC running a version of Windows that is later than Windows 3.
Plug the cable attached to the external hard drive into a USB port on the PC. Right-click on the "My Computer" icon on the desktop. Select "Manage" from the drop-down menu. Click on "Device Manager" in the left column of the window that appears. Click on the "+" icon next to "Disk drives" that is in the column to the right of "Device Manager." Right-click on the icon of the external hard drive. Select "Properties" from the pop-up window. Click the "Polices" tab at the top of the window that has replaced the pop-up window. Click the "Optimize for performance" button below "Policies." Click "OK" to close the window. Right-click on the icon of the external hard drive in the center column of the window that is still open. Select "Format" from the pop-up menu. Select "NTFS from the "File system" drop-down menu in the new window that appears. Click the "Start" button at the bottom of the window. Wait as a progress bar appears at the bottom of the window and fills in from left to right. Click the red "X" at the right corner of the window once the progress bar has completely filled in. format usb memory stick to ntfs http://www.online-tech-tips.com/computer-tips/format-usb-ntfs/
Overview and history of ntfs format http://www.pcguide.com/ref/hdd/file/ntfs/over-c.html
Apr 02, 2013 | Maxtor OneTouch III Mini Edition 120GB...
Good day. I bought this Netbook with Windows 7 installed. I need to format and reload Windows XP as I have software that I need to use that only works with XP, I have an external "USB CD Drive"...
Hi neil720...
Installing the external CD Player...
You will go and start up and install Windows XP by doing he following:
Plug in your external CD drive, and let windows install it into the system...
Once the CD is ready to go, shut down the computer.
You will first need to format your hard drive, I will give you instructions on how to do that.
1...To format your hard drive and install XP:
To set you computer back to factory fresh settings you will need to format the hard drive and install the XP operating system and the drivers.
1.Format the hard drive:
You do this by double left clicking on "My Computer",then double left click the main drive (normally C drive).
When the window pops open, you will choose "Format"
Keep in mind that once you format your hard drive you will loose all your files,programs,pictures,etc that you installed since the computer was new.
So make your back up on a portable hard drive,thumb drive,etc.
2. Once the formatting of the hard drive is complete you will need to install the XP operating system along with the drivers.
You will now insert the CD's into your external CD player starting with #1 first and continuing until all has been installed.
After all has been installed, shut your computer off and restart.
That will bring your computer back to Windows XP factory new condition as far as operating is concerned.
Please take time to rate me
Sep 15, 2011 | Acer Aspire One D255-2670
I have a iprodrive external hard drive and my laptop does not reconize it any more. the last time i used it i did not disconnect properly. is there a way to reset it
Here a step by step guide i found as i surf the net last week. Read along.
  1. Step 1 Log in to your computer as the administrator.
  2. Step 2 Install the external drive software from the CD that comes with your external hard drive.
  3. Step 3 Use the USB cable that came with your external hard drive and plug one end of the cable into your hard drive and the other into the USB port in your computer.
  4. Step 4 Give Windows a moment to recognize the external drive and to assign it a drive letter.
  5. Step 5 Go to the "My Computer" icon and double-click on it.
  6. Step 6 Choose the newly created external drive letter in the right-hand explorer window.
  7. Step 7 Right-click on the external drive letter and choose "format" from the drop-down box.
  8. Step 8 Choose "quick format" from the format options section from the next pop-up box.
  9. Step 9 Click the "Start" button.
  10. Step 10 Click the "OK" button in the Format warning box.
  11. Step 11 Click the "OK" button in the "format complete box" to finish the process.
Should you have any questions regarding this post feel free to post it here.
  • Step 2 Install the external drive software from the CD that comes with your external hard drive.
  • Step 3 Use the USB cable that came with your external hard drive and plug one end of the cable into your hard drive and the other into the USB port in your computer.
  • Step 4 Give Windows a moment to recognize the external drive and to assign it a drive letter.
  • Step 5 Go to the "My Computer" icon and double-click on it.
  • Step 6 Choose the newly created external drive letter in the right-hand explorer window.
  • Step 7 Right-click on the external drive letter and choose "format" from the drop-down box.
  • Step 8 Choose "quick format" from the format options section from the next pop-up box.
  • Step 9 Click the "Start" button.
  • Step 10 Click the "OK" button in the Format warning box.
  • Step 11 Click the "OK" button in the "format complete box" to finish the process.
  • Read more: How to Reset an External Hard Drive | eHow.com http://www.ehow.com/how_4840145_reset-external-hard-drive.html#ixzz0YYmAf0Ra
    Jul 24, 2010 | Computers & Internet
    Installing 1tb External Hardrive from Freeagent onto Macbook Pro
    I would be tempted to format the drive using the disk utility whch can be found under applications and then utilities once opened choose your drive in the left hand window and on the right hand side click on erase. If you are using the Seagate drive for the Mac only, format it as a Mac OS Extended (journaled) Choose your volume format and name and then erase. Hope this helps.
    Dec 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
    Can't boot from USB (No CD Drive) for fresh install
    Tricky one, ive you have a external usb cdrom drive , maybe, or if you can take hardrive out and set it up on another laptop install your xp and also place copy of all drivers required onto it, then put back into the toshiba., dont know what else could help you here. hope this helps in some way.
    Dec 05, 2009 | Toshiba Portege 7100 Notebook
    Installation of window xp
    Remove the HDD and put it on an external HDD and format it on a different PC.
    Now fix the HDD back and install XP. Please note that after XP installation you need to down load (XP) drivers from HP website and install them.
    All the best!
    Jul 28, 2009 | HP Computers & Internet
    Acer laptop aspire 4710z config my notebook have problem
    Dear, first make it format again & make it clear that not a single file will lose. it will definately help you.
    Bhaiko_bhai
    Mar 02, 2009 | Acer Aspire 4720 Notebook
    Laptop Won't Recognize External HD
    You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
    Then replug the drive again, and it should reinstall the drivers.
    Jules
    Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
    Do you know ho to format a toshiba satellite pro 4300
    What operating system are you using? If windows xp then just right click on the icon of the hard drive in "My Computer", select "format" and follow the instructions with all the default settings. Be aware that if you do this you will have to have your windows xp cd or a cd for a different operating system in order to be able to restart the laptop. You will have to reinstall the OS and then all the necessary drivers for the laptop and any software you are running. What exactly is causing you to wish to format? Usually there is an easier way to solve HDD problems. Please post back with more info
    Aug 17, 2007 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
    Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive Logo
    87 people viewed this question
    Top Maxtor Computers & Internet Experts
    Phil Whisenant
    Phil Whisenant
    Alun Cox
    Norman Al-Anbar
    Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
