Question about Panasonic KX-FLB756 Plain Paper Laser Fax
Sometimes two sheets feed in instead of one.
Most of the time it feeds in a single sheet, but, sometimes (about 1 in 10), it will feed a sheet and then another one comes in right after it and the print gets split between the two pages.
Is there a "separator" pad or some replacable part that will prevent more than one sheet being fed in?
    Sniper:
  • 66 Answers
Most faxes have a rubber separation pad which is designed to stop multi feeding. It is in the feed area.
They vary in size  but can be up to an inch square.
If they get dirty they can slip and allow more than one page to feed, if this happens you can clean it with a damp rag with a bit of detergent on it . If this does not work (give it three or four tries) you will have to replace the separation pad
Posted on Dec 14, 2008
Hi Canon LBP 1120 paper feed and paper jam problem: My Printer mostly take in multiple paper sheets instead of taking just one sheet. Sometimes the extra sheets are taken in while the printing sheet...
You need new pickup rollers
google search "LPB1120 pickup rollers" and find your nearest dealer. usualy quite easy to replace as long as your a "can do" person
Mar 18, 2011 | Canon LBP 1120 Laser Printer
It grabs several sheets of paper at one time
This is most likely a paper problem, the paper is basically sticking to the next sheet, Ensure the paper is stored in a cool dry place helps, dont load the paper with more than what you need for a couple of days and when loading the paper flick the pages to allow air between the pages
If this dosnt work try a different brand of paper
Sep 09, 2009 | Lexmark Optra E310 Laser Printer
Will not feed paper of any size. No jams ever.
clean the feed rollers with water and soft cloth.. try a stack of paper not a single loose sheet
Aug 15, 2009 | Epson Stylus 1400 InkJet Photo Printer
My HP C6180 sometimes pulls 2 sheets from the ADF instead of 1 at a time when copying multi-paged document.
Get some resin powder ( or similar) rub onto the feed in rollers  they get shiny and don't grip properly. Inkypete
Apr 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
Dell 922 All-in one ink jet printer paper feed
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | Dell 922 All-In-One InkJet Printer
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Brother HL 2070N red paper light blinks but won't print.
Just fixed my printer issue, had the same problem, Would load 1 sheet, then jam, sometimes it won't pull the paper out of the tray, sometimes it would pull the paper to the toner area, but never into the toner, opening and slamming the paper tray while it attempted to load would usually work, but who wants to slam the tray 50 times? I was using Walgreens generic paper, 20lb, took some higher-quality 24lb HP paper and VOILA! It works every time! EVERYONE WHO IS HAVING THIS PROBLEM, CHECK THAT YOU ARE USING 24LB PAPER!!! Brother says 20-24 is acceptible, but sneaking one sheet of 20lb paper about 15 sheets down in a 20 sheet print job and it will stop at it every time, You can feel the difference, less like toilet paper and more like real paper.
24 LB PAPER! USE IT NOW AND THANK ME LATER!
Jun 27, 2008 | Brother HL-2070N Laser Printer
Paper feed/jamming problem
suggest you bring your orinter to the nearest authorised repair center. There might be parts to be replace
Mar 23, 2008 | Brother HL-2040 Laser Printer
Printer HP-870CXI - Paper feeding
there is nothing wrong with the roller becoz it is picking up the single seet what you can do is you put bunch of paper while you placing the paper sheet dont put deep inside just insert like when feel resist leave it. give the print command it will automatcally pick up sheet one by one. bye
Sep 21, 2007 | HP DeskJet 870cxi InkJet Printer
Panasonic KX-FLB756 Plain Paper Laser Fax Logo
97 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
