Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
My refrigerator isn't cooling but the freezer works fine.
The fan is working and there is a slight build-up of frost on the back wall of the freezer.
  • 145 Answers
Hello and welcome.
Check the defrost terminator thermostat and the defrost heater. One or the other has likely failed.They are located behind the freezer panel.
Posted on Dec 14, 2008
My jcd2389des freezer is working fine but the refrigerator isn't cooling properly
Hello Sharleen,
The leading problem when freezer works yet the refrig. section doesn't get cold is going to a problem with a automatic defrost system defect. Do ya see a bunch of frost inside of the freezer on the back wall?? if yes ya do see that frost build up ist defiently not defrosting and this tip i wrote covers what to check when it doesn't defrost http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Oct 03, 2011 | Jenn-Air JCD2389G Side by Side...
I have a kenmore model refrigerator freezer model #70982991. It has a top freezer and the mfg. date is 10-00. Right now the freezer part is working but the refrigerator is not. It is used in my unheated...
Lack of freon isn't an issue. Check the internal fan between the freezer and fridge. It is usually located behind the back panel in the freezer. If not there, check upper back of fridge. The internal fan blows the cold air from the freezer to the fridge. When it goes out, the freezer will freeze but the fridge won't cool.
Sep 04, 2011 | Refrigerators
Motor in the backs works lights works small fan inside the cool side is not working when pluged in problem will not cool
the fan in the freezer is supposed to circulate the air through out the entire box both ref/freezer. If you take back wall off the freezer and their is frost build up, the compressor and all associated parts that make it cold are working fine but that fan isn't blowing the air and the fan needs to be replaced.
Gene
Aug 06, 2011 | Amana Refrigerators
Freezer is cold but refrigerator side is barely cooling. turned off and water leaking out of door on the freezer side
Hello Roxanne,
what the problem most likely is a failed part of the defrost system Do you see a bunch of frost built up on the back wall of the freezer? If you do frost build up,i would take off the back wall of the freezer and replace the deforst heater and defrost termination. A hair dryer could be used to melt the built up frost from the coil behind the back wall. Another part that will cause frost build up is the defrost control, that isn't the freezer behind the back wall but instead in the fresh food compartment in the control panel where the thermostat is. I would replace heater/defrost termination first though since they are the most likely to fail parts.
I hope my answer will help you to fix your refrigerator,
Gene
Aug 05, 2011 | Maytag MZD2766GES Side by Side...
A couple of days ago the refrigerator stopped cooling thought the freezer works fine... both temp comtrols are set to 9 the coldest setting ... ever since we got it , it would make an odd loud clicking...
The most common cause of that is a malfunction of the automatic defrost system. Do you see a bunch of frost on back wall of freezer? if yes it's not defrosting or perhaps the fan in the freezer that circulates air into fresh food compartment has failed,no frost build up if it's the fan, do you hear the fan?
Gene
Jul 30, 2011 | Frigidaire FRS26H5AS Side by Side...
Top section not working
If there is a lot of frost build up on the back wall of the freezer section you are having a defrost problem and the coils behind that wall are filling up with ice restricting air flow and letting fan blades hit it. If not a lot of frost the evap fan motor is going bad which is also located behind the freezer wall. Good luck.
Feb 24, 2010 | Refrigerators
Fridge not cooling
Check and see if your evaporator fan motor is working in the freezer. Also, if your defrost system is not working and your evaporator coil is frosted up, you will not get any cold air to the refrigerator section. You should see alot of frost on the back wall of the freezer where the evaporator coil is located. If your evaporator fan motor is working and there is no frost build up on the coil, the air diffuser to the refrigerator section may be the problem. Put your hand in front of it when the evaporator fan motor is running and feel if any air is coming thru. There are a number of conditions that can cause your problem. This should get you started! Visit me on Ebay as username: themackshack. Good luck! Mack
Mar 23, 2008 | Refrigerators
Kenmore Trio 596.75509400
Generally speaking if the refrigerator does not cool and you have frost on the back wall of the freezer it suggests a defrost problem.
However since the refrigerator started working by itself it would point to an air circulation problem from the fan in the freezer compartment failing to operate. The frost on the back wall without the fan operating would cause frost buildup because the heat is still trying to get to the coil through the back wall. If your refrigerator freezer has a door fan light switch something holding the door partly open would cause the fan not to operate. Look for a button or toggle and manually push it in. You should hear the fan turn on and the light will go off.
Mar 12, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool top freezer problem
Check for frost build-up behind back wall in freezer. If there is a heavy frost build-up, it's not defrosting. This will restrict airflow to refigerator section and can stop fan. If fan is stuck again and it's not because of frost, replace evaporator fan motor.
Nov 12, 2007 | Whirlpool ET1FHTXM Top Freezer...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
216 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
