Question about RCA R52WM24 52" HDTV Projection Television
Concave screen colors in 3d
Its an rca r52wh74
  • 1 more comment
  • rnlsaint Dec 23, 2008
    same problem, tv was on it trned off then powered back on its own then creen concave looks like this but side ways )( and now picture looks like 3D image blue and red
  • brian lee johnson Dec 26, 2008
    I know why mine is concave. a large ball hit the outer screen and i am wondering if this can be replaced rather cheaply.
  • Anonymous Jan 03, 2009
    have the same problem how long ago did you buy yours
I have the same tv and just had mine repaired for the same problem just got it back yesterday turned out to be the fl231 fuse blown and the flyback transformer solder points have rings in them. It cost me $211.00 to get it fixed and they said it's common problem and most repair shops should have the part in stock and fix it in a couple of days.
Posted on Jan 17, 2009
I have a rca Model R52WH74 which the picture resolution is given out. Please tell me what can I do to fix this issue? It look like the picture is in 3D
Jun 25, 2010 | Televison & Video
Red color in left bottom of screen and left side has 3d look. letters on guide in this area are concaved also
try to do a convergence adjustment. If that doesnt work the convergence power supply board is the usual culprit, if the convergence option hasnt disapeared from the menu.
Jun 15, 2009 | RCA D61W20 61" Rear Projection Television
I have an RCA 52inch rear projection tv model No#R52wh74 when i turned on the set the screen went into some concave mode and the color is al distorted what do i need to fix this
DO you have convergence in the customer setup menu? if you do not then check out the article fl231 problem in the tips and tricks section
Apr 28, 2009 | RCA R52WH73 Projection Television
Where is the convergance amp?
Accros the top of the chassi.conv power supply is to the left
Apr 23, 2009 | RCA HD52W58 52" TV
Problem with my rca projection television
my RCA R52WH74 HDTV IS STARTING TO LOOK BLURRY. ALSOMY SCREEN LOOKS LIKE IT STRETCHING MY TV PROGRAMS....... CAN U GIVE ME A SOLUTION
Mar 16, 2009 | RCA HD52W59 HDTV Projection Television
RCA R52WH74 Picture is sagging, looks 3d, and double picture
Go to menu then setup look for convergence if you do not see convergence then you have A open FUSE It will be on right side of FBT flyback transfomer there is 3 of them in a roll they are small brown rectrangler looking caps but ARE FUSES it will be the one in the middle. Replace it and you have a FIXYA.
Feb 19, 2009 | RCA R52WH73 Projection Television
RCA R52WH74 52 in Blue & red in picture are shadowy Picture concave/convex
try goin to your menu and find settings ,,go to convergence,,if u got it ,,it may fix it,,it realines the colors,,good luck with that
Oct 06, 2008 | Televison & Video
R52WH74 problems
Which chip did you buy as your model doesnt use Convergence Ics. Also how many colors are out of alignment? Is it one or are all 3 colors out. Your model has a convergence board and a convergence power supply board and depending on how many colors are out will determine which board you require.
Sep 03, 2008 | Televison & Video
52 rca concave pic and bad colors
concave and colors off indicate the convergence cuircit is bad. which can be one of three boards. sorry
Dec 08, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA R52WM24 52" HDTV Projection Television Logo
124 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
