Question about Protron PD-800 DVD Player
SET PLAYER to p-scan HOW TO SET IT BACK
I stupidly set the player to YUV P-SCAN mode to try it. Apparently my TV doesn't support p-scan. So now all I get is a solid blue screen with sound. So now I can't even see the on screen display to try to set it back to the original default setting. Does anyone know how to reset the player chip defaults or have any ideas?
  • joe smith Mar 13, 2007
    NEVERMIND PEOPLE. I CAN'T BELIEVE I'M THIS STUPID. BUT THERE IS AN ACTUAL BUTTON ON THE REMOTE THAT TOGGLES P-SCAN ON OR OFF. I JUST DIDN'T SEE IT AND IT WASN'T MENTIONED ANYWHERE IN THE MANUAL. DUH.
    Guru:
  • 104 Answers
Open the user manual see how to change the mode. Try to do wihtout seeing, its some kind of a challenge.
Posted on Mar 13, 2007
I was playing with settings on my Zenith xbv342 and set the menu to progressive scan. I now have a blue screen with the words "progressive scan mode" I cannot get a picture and it is stuck in this m
Progressive scan mode is used by DVD players to artificially scale standard resolution DVDs to HD resolution, usually 720i. Is your set capable of receiving HD resolution? If not, that is probably why you are getting the blue screen.
Dec 18, 2014 | Zenith XBV342 DVD Player/VCR
I was messing around with my remote and the settings on my dvd player when i went into the setup and switched the setting to YUV and now my screen has rapid diaganol lines across the screen and i cant see...
Hey, Try seeing is this helps. I am not sure what your remote looks like. Normally you can just unplug the unit for say 5 minutes to give a full clear reset, then plug back in the wall. This should give a hard-reset, but if not, try:
(Only if your TVset doesn't support YUV P-Scan input feature will this above problem happen.)
Step1: Close this DVD player. (make sure there is no disc inside it)
Step2: Press CLEAR button on the remote control,and the system will reset to the default setting.
Hope this helps!
Aug 23, 2011 | Video Game Consoles & Games
Cannot turn off progressive scan mode on blue screen to play dvd
If you have not already seen this or done it - it worked for us:
On page 18 of the user manual under Progressive scan there is a Caution which says - If you set Progressive Scan to On in error, you must reset the unit. 1) Remove any disc from the unit and close the disc tray. See that "dISC " is displayed on the display window. 2) Press STOP (9) and hold it for more than five seconds before releasing it. The video output will be restored to the standard setting and a picture once again be visible on a conventional analog TV or monitor.
May 20, 2009 | Zenith XBV442 DVD Player/VCR
Connecting DVD to TV
P-scan is used for traditional television screens.
YUV encodes a color image or video taking human perception into account.
S video should be used with an S video cable and standard rca's for sound
Jan 20, 2009 | Televison & Video
How to Connect my Cyberhome CH-DVD 300 from my TV that has SCART interface to Component Out on the DVD player
You have not mentioned the t.v/ dvd model, normaly all latest t.v will have A.V. input , try to connect in a.v. out of d.v.d to a.v. input to t.v and bring t.v. into a.v. mode.
Jun 15, 2008 | Cyberhome CH-DVD 300 DVD Player
Split Screen
Go into SETUP
GENERAL SETUP PAGE
Go to VIDEO OUTPUT (can't see through error message, but it is the second one down - If you are on the right one, you will see S-Video, YUV Interlace and YUV Progress. as choices)
Change setting from YUV Progress to YUV Interlace
Mine was set on YUV Progress. and when I changed it, the problem disappeared.
Mar 06, 2008 | RCA DRC200N
DVD player
unplug it and plug it back in and press the progressive button to turn it off, should work. Yeah that blue screen sucks, i would have thought you can get to the menu no matter what but that's sanyo for you, well most other brands also...
Jul 21, 2007 | Sanyo DVW-5000 DVD Player/VCR
MY DVD / VCR PLAYER MADE BY GOLDSTAR IS STUCK IN A MODE THAT SAYS PROGRESSIVE SCAN MODE ,HOW CA I GET OUT OF THIS MODE I HAVE A GOLDSTAR MDL #GBV441 THANKS
Stuck in Progressive Scan Mode??? Remove the disc(s) from the changer, make sure TV is on Blue Screen...should say "Progressive Scan Mode".......Simply press and hold the stop button for 5-10 seconds and it will reset.
Apr 29, 2007 | Goldstar GBV241 DVD Player/VCR
Stuck in progressive scan mode
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Aug 29, 2006 | NexxTech ESDVD100 System
No picture but has sound
Hi If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service. Good Luck!
Aug 14, 2006 | Zenith DVB312 DVD Player
Protron PD-800 DVD Player Logo
79 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
