Question about Dell Inspiron 2200 Notebook
Bios how do you get into the bios on insiprion 2200 tried F8 thanks in advance
  • 136 Answers
Reboot and press the F2 key, not the F8.
Posted on Dec 14, 2008
    President:
  • 2,110 Answers
TRY TO PRESS F2 OR DEL WHILE BOOTING..
How do I remove the Motherboard Battery?
Even if the battery was totally flat, you will still be able to load the BIOS and boot the pc.
Try F8 just before it tries to boot.
May 25, 2014 | Samsung R519-53S Notebook
My computer wont boot correctly
won't boot at all?
it's probably the BIOS settings
go to the BIOS settings by pressing F8 or DEL
go to advanced settings
look for "boot device priority" or something like that
set the first priority device as your harddisk
save & exit,restart,happy computing
the "boot device priority" maybe not placed on advanced setting,each BIOS has different interfaces,just look for something like that,it's easy
Aug 22, 2012 | Gateway NV53A24u Laptop
BIOS Password Reset
if ti is a bios password the only thing you can try is to open it up and remove the bios battery for a minute or so ..and see if it works..It does not work for all models but usually for most desktops works and for some laptops..It basically cutting bios power and make it forget all settings including the password..After that just reinstall the operation system ..
If you are not sure if it is a bios setting ..just try to reinstall using a boot-able disk with the operation system ..and if the boot order is not set to boot first from CD ..just try to press f12 to engage the boot menu and select it manually ..and press enter ..
Another way to fool it ..is to try and remove the hard disk ...and force it to boot from the disk cause the disk is the next inline ..and after it starts just plug the hard disk again ..and you have a chance to go on with the installing in this time ..
let me know what you have tried and what worked..
Dec 23, 2011 | Dell Inspiron 2200 PC Notebook
How can reset bios user password
Its very simple process..
1)open BIOS setup by pressing F2
2)go to advance option
3)go to security and reset master password
If your problem not solved then clear CMOS memory by suitable jumper on motherboard.
or format your computer if no any way is remaining..
Thank you for giving me opportunity to solve your problem.
please give me your Ratings!!
Jun 17, 2011 | Dell Inspiron 2200 Notebook
Disable on-board VGA
you have to get into bios setting to disable On board VGA card man, just restart your system , on the time system getting on press f8 or delete key or any equivalent key to enter BIOS mode , because different manufacture used to have different key to enter into BIOS mode. After you get into Bios mode just look over and go to advance setting to disable On board VGA card.
Good luck ! if you think your problem solved don't forget to rate
Jan 03, 2011 | Mercury P4VM800M7 Motherboard
Hello! How can I reset the bios on my Dell Inspiron 2200. My cousin changed the password and now we are frustrated typing in variations of what he tought it was without success.
Start your computer, tap on the F8 key, choose SAFE MODE, once the computer boots up go to CONTROL PANEL and choose USER ACCOUNTS you should be able to change your passwords from there and just re-boot the system and use your new pass word.
Oct 30, 2010 | Dell Inspiron 2200 Notebook
Hi, I have an advent laptop that only loads to windows when i tap the f8 button. If i switch the laptop on, it stops at the 'advent' logo and won't boot to windows unless i tap the f8 button. Can you...
try adjusting the boot sequence or at least enabling a different priority in the boot sequence ,,press F2 to get to the bios and learn how to navigate these pages
Sep 10, 2010 | Advent Netbook
Computer will not start up completely.
You could have a problem created by whatever you wer doing last. Try hitting F8 repeatidly until it gives you get the "Advanced Options Menu" Then select "Last Known Good Configuration" and hit ENTER.
Good Luck
Apr 30, 2010 | HP Compaq Presario 2200 Notebook
Note book freezing after fan change
This is just an easy problem... what you'll have to do is follow this steps
Step 1: If you have manual of your computer it is better.. restart your notebook, press and hold the key to boot in BIOS setup... try pressing this key F1, F2, Delete or F8, because some laptop and notebooks have different method of going to BIOS.. you will know if it is BIOS Configuration because it has a BIOS Settings at the Title of the screen.. now go to Power Management or Power Monitoring.. you can find the Fan option there.. because you change the fan of your notebook, it detects that the Fan that you installed is not standard with the note book.. go to step 2.
Step 2: Now when you find the fan option try to set to ignore the fan RPM and The Voltage that is uses... if there is... then save your settings by pressing F10 key and wait for the notebook to start normally.. if the notebook won't start normally, then go to step 3.
Step 3: In this step you'll have to Start in Safe Mode.Restart your notebook, while booting press the F8 key then a boot menu will show in your screen.. if there is drive selection, choose the hard disk drive.. if none then proceed in selecting the Safe Mode menu.. wait until its done booting your windows in safe mode.. after have complete run in safe mode.. properly restart your notebook by going to Start>Turn Off Computer> Restart, and it will boot in windows normally...
Hope I Can Help
CLCTECH
Nov 23, 2008 | HP Compaq Presario 2200 Notebook
User profile
Hello
the user profile is corrupted
try to login on a other account.
if you dont have a account try to login in safe mode
press F8 before windows starts(after bios screen)
and login to your account.
in safe mode try to create a new account and restart your computer.
what os does he have?
good luck
Oct 13, 2008 | HP Compaq Presario 2200 Notebook
Dell Inspiron 2200 Notebook Logo
53 people viewed this question
Alun Cox
