Question about Bowflex Treadmill Series 7
Tread will not move, shows a L 5 error code
Shows a L 5 error code
  • 2 more comments
  • luvcynee Dec 18, 2008
    i have the same problem... I was told it is a speed sensor and you can either try to calibrate the machine, or open that machine cover and see if there IS a loose wire by the flywheel... (I have tried to calibrate it, and that didnt work... I am nto home to see about the wire yet... ) This is info from Nautillus
  • faye90 Dec 30, 2008
    Nautilus told me to take the cover off and check the placement of the wires, compared to the belt. Everything looks fine, but I am no mechanic either. How did you find out it was the Lower Control Board?
    Mine will power up, but will not start moving, I get the ERR L5 message, my treadmill is a series 5.
  • Anonymous Feb 11, 2009
    I have a nautilus ntr 800. It will power up and u can choose ur settings but as soon as u press start l5 error shows up and shuts everything down and makes a click noise in switch board.
  • akyadayada Mar 26, 2009
    I have replaced the lower control board and that did not fix the problem. I have also replace all of the electronics in the lower end of the treadmill including the speed sensor.
You need a new lower control board. 225.00 from nautilus.
Posted on Dec 30, 2008
  • truell Aug 28, 2011
    I got the same error code LS, had lower control board replace. 12 months later, I got the same error again. This is a piece of $#@#%. Never buy a treadmill again.
TAKE YOUR MACHINE OUT OF YOUR BASEMENT PEOPLE
IT WILL RUN IN THE BASEMENT FOR A FEW MONTHS, POSSIBLY LONGER. I DOES NOT MATTER IF YOU THINK YOUR BASEMENT IS WIRED LIKE THE REST OF YOUR HOUSE. YOU WOULD NOT BE HAVING THIS PROBLEM IF IT TRULY WAS.
OUT
OF
THE
BASEMENT
Posted on Jul 27, 2009
How to correct Tread climber TC5500 error code NIPP COMM (Belt Shut Down).
If you wiah to get some details about treadmill error codes and solutions then check the following link
http://electro-medical.blogspot.com/
Oct 02, 2016 | Bowflex TreadClimber TC5500
I have a fuel fitness tread FT94 and an errow code keeps coming up E6. What does this code mean and how can it be fixed ? tread mill will not start up
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.Check for treadmill error code
Mar 08, 2016 | Exercise & Fitness
I have it all set up..programmed a work out...it starts to work..but the tread itself that you walk on wont run..what do I do?
From the User manual....here
http://servicedocuments.com/pdfs/_0005_SOLE/_0005_SOLE_01_Treadmills/003_OwnersManuals/2010_2011_SOLE/F63_F65_OM_810.pdf
'1.If the belt moves, but stops after a short time and
thedisplay shows "LS", run calibration. (on next page)
2.If you press start and the belt never moves, then
the display shows LS, contact service.
Sep 14, 2014 | Sole Fitness F63 Treadmill
Tread ajustment
under the shroud cover there is a bolt that loosens the tension on the belt...be sure the belt sensor "sees" the belt as that is why you have an E-1 error code
Dec 03, 2013 | Exercise & Fitness
How the error e02 on fit king treadmill be repaired
Dear sir,
I am having a treadmill of Fitking model no. W590 it is showing error code e02.
Kindly suggest what to do. I am eagerly waiting for ur response
Rgds
Yash Pal
Jul 15, 2013 | Exercise & Fitness
What does code 22 mean?
Error 22 - No Motor Pulses at Start Up
Description
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either
manual or program control, and the monitoring system has not received any response from the
speed sensing system indicating that the drive motor has started.
Possible Causes
1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the
speed sensor and the speed sensor target is obstructed.
2. Drive motor brushes are bad.
3. The speed sensor position relative to the speed sensor target is incorrect.
4. The speed sensor potentiometer adjustment is incorrect (when equipped).
5. The speed sensor is inoperative.
6. The lower PCA is bad.
7. The lower PCA to upper PCA interconnect cable is bad.
8. The upper PCA is bad
Jan 18, 2010 | Precor 9.21 Treadmill
Scanner motor move failed error code 6202
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Nov 07, 2009 | Kodak ESP 5 Printer
Error code E5-5
I didn't use mine for several years then just started again. It stopped after 15 minutes so I read the manual and used a silcone lubricant on/under the treads as recommended. That definitely helped and it was working again quite well for about a week or two. Now I get the error 5 again. Wondering if I needed to add MORE lubricant the first time so I am going to do it again tonight. Maybe it is the roller pully that needs the lubricant. Who knows. I just want it to work!! I am determined. :)
-becky
Feb 08, 2009 | Bowflex TC3000 Treadclimber
My Panasonic DP-2330 .... Is Showing Error Code E04-02
How enter to service mode in panasonic DP2330 copier.
Dec 01, 2008 | Panasonic WORKiO DP-2330 Copier
Bowflex Treadmill Series 7 Logo
1,963 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Shehu Pro
Shehu Pro
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
