Question about Casio AW80-1AV Wrist Watch
Setting analog time
Need to set analog time
  • paul parker Mar 17, 2007
    thanks so much pauly07
  • 944 Answers
Go to; http://world.casio.com/wat/download/en/manual/ and enter the module number code on the back of your watch - hopefully will tell you what you need to know. Hope this helps :)
Posted on Mar 13, 2007
Press adjust 2 or 3 times u will set that time is blinking press search............. minute hand will move accordingly u will adjust the time
Posted on Aug 16, 2007
While time is shown in digital clock press and hold ADJUST, and then press SEARCH.
Posted on Oct 28, 2007
  • 2501 Answers
SOURCE: analog time setting
On the assumption that my Casio watch works the same as yours, press the mode button (lower left), until "HS"appears, then use the buttons on the right to advance or ****** the hands.
If this does not do the trick, then go to the Casio web site "casio.com" select "support"then "manuals"; accept terms and conditions and the select "watch manual archive"
Insert the required number off the back of your watch and download the instructions.
Posted on Jan 30, 2010
escapement
  • 2338 Answers
SOURCE: how to set analog time on casio fishing gear watch
Follow this link and get manual:
Rate me, please.
Posted on Mar 15, 2009
smartr10U
  • 1305 Answers
SOURCE: Cannot set the analog time on the Casio 2747.
Here is a link for the manual download for this casio... click here
the manual should download to your computer ...there is a page that shows detailed instructions on how to set the analog... involves pressing a button six times... the diagrams in the manual will help ya..
let me know if you are successful!
k
Posted on May 28, 2009
  • 9 Answers
throw it away all ready! that fixes all of my problems!
  • 2501 Answers
SOURCE: need to set the time on my casio g-shock g300 i
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Posted on Jan 08, 2011
How to set analog time for casio SGW 400 h please help
Analog time follows the digital time on Casio watches.If this is not happening,try the hands "set to 0" procedure using the manual.
Mar 31, 2013 | Casio Watches
To adjust the analog time for ga-110hc-1a
Analog time follows digital time.Correctly set your local time and analog time will come up correctly as well.If not, try to run the hands alignment procedure (H-SET) following manual instructions.
Mar 02, 2013 | Casio G-Shock GW500A-1V Wrist Watch
How to set the time and analog time of CASIO ILLUMINATOR0 SGW 400 h
set the digital time: press and hold upper left button, then the seconds blinks use the lower left button to choose what are you going to set ( the one that blinks is the one that can be set ), use the upper right button to set. when your done. press the upper left button once.; set the analog time: from the time mode of the digital press mode until you see the "H.SET" , then the time of the digital appears, then use the upper right button to set the analog time, when your done just press the upper left button once and use the lower left button to bring back the time mode. i hope this will help you a lot.
Aug 13, 2011 | Watches
How do I set the time and how do I get a user manual.
1. set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date
2. if off sync between analog and digital clock happen. You need to resyn
step 1: follow the instruction 1 to set digital clock to 12:00.
step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync mode.
step 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.
step 4: push the pusher at 3:00 to exit the sync mode.
step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Jun 18, 2011 | ESQ 07301132 Aerodyne watch
I have a casio ediface 5033 80W-M10008 how do I set the analog time
Thank you for contacting FixYa.
To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Best regards. Jewel
Sep 15, 2010 | Casio Edifice EFA109-7AV Wrist Watch
I accidentaly reset time & date on my square arnette watch and i need help to set it
    Set Digital Watch
  1. Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
  2. Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
  3. Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
  4. Set Analog Watch
  5. Pull out the watch crown on the right side of your Arnette analog watch.
  6. Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
  7. Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
Best regards. Jewel
Sep 09, 2010 | Watches
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Aug 21, 2010 | Casio Watches
Setting time day date in ESQ Aerodyne
2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Jul 26, 2010 | ESQ 07301132 Aerodyne watch
In timekeeping mode press bottom left button 6x to enter setting mode.
Then hold down top left button until digital time flashes, which indicates your in analog time setting mode. press bottom right button to set the time.
If you hold down bottom right, it will set time at a faster speed.
Hope this helps
May 25, 2009 | Casio AW80-7AV Wrist Watch
I cant set analogue time on casio hd wrist
Follow this link:
Rate, please.
Mar 30, 2009 | Casio WVA430A-1AV Wrist Watch
Casio AW80-1AV Wrist Watch Logo
844 people viewed this question
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
