Setting up my new Palm TX. I have a wireless router in my home so I thought for sure I could use the WiFi in the Palm TX in my home. Couldn't connect sucessfully, tried Palm Tech support. They informed me the router setting has to be either 802.11B or a 'mixed' setting where it has both B & G ???
Can I change the wireless router setting from my desktop?
if so, how? Will that change effect the other laptop users in my home that use this router?
thank you so much for your help!
-   I have the same problem when trying to connect to Linksys from my phone. I wanted to try to chance my Network settings from G ONLY to MIXED.
When I go to URL: 192.168.1.1 and try USERNAME admin PASWORD admin or USERNAME admin PASWORD [leaving it blank], the login pop-up just keeps coming back and I get a purple screen with the error message: "
401 Unauthorized!
Authorization required!"
Switching the wireless mode is easy, and, if you choose "mixed," the other computers in your home can continue to use the G mode unaffected. How you adjust the mode depends on the brand of router. Since Linksys is the most common, here is how it works on a Linksys router:
1) Open your web browser (IE, Mozilla, etc.) 2) Type the web address 192.168.1.1 (default for Linksys routers). 3) You should be asked for a username and password. The default for Linksys is username "admin" and password "admin" OR username "admin" and password [blank]. 4) You should then see the Linksys setup screen. The tabs across the top include Setup, Wireless, Security, etc. Click on Wireless. 5) Pull down the menu next to "Wireless Network Mode" (which shold be set to "G -Only" and choose "Mixed." Then click "Save Settings."
This should allow your B-capacle Palm to use the network without a password while still allowing your encryption-capable computers to use the G mode.
I hope this helps - please let me know if I can be of any further assistance. H2H
ok i installed the disc and the adapter icon does not come up and then i try to do the device manger...
(More)
ok i installed the disc and the adapter icon does not come up and then i try to do the device manger and go to adapters and it is not there but on my computer then program files it is there but when i click the little green thing it says error
