Question about Copystar CS-1500 Copier
Have a copy star copier and is showing Error c-6
Need to know what a fuser unit or a thermofuse is?
  • Turner219 Jan 22, 2009
    I have the same problem c-6  400 how do i fix it or what dose that mean
    Sniper:
  • 66 Answers
On the key pad dial in 1087 1087 enter. then type in 163 enter and the thermistor error should go away
Posted on Dec 14, 2008
Image runner 210s error code E000. What to do?
Your problem in the fuser unit.Check and clean the fuser unit component parts:thermistors,thermofuses,verify the continuity of the heater lamp,and verify the upper and lower fuser roller mechanical.
Nov 24, 2009 | Canon imageRUNNER 210S Copier
What is code H or 4 which stops copying
Your problem in the fuser unit.Please check and clean the fuser lamp,fuser thermistor and thermofuses.Verify the continuity the fuser unit parts( 6-7 Ohm).
Nov 17, 2009 | Sharp AR-5320 Black and White Copier
I have a RICOH FT 4022 copier and it displays E 5 error code. It does not allow copying. I have checked the fuser unit and its ok. What could be the problem? Do I need a reset code to solve it and where do...
The E5 code is the fuser malfunction error.
E52 fusing lamp warm up error.Possible causes thermistor open,heater lamp open,thermofuse open.
E53 fusing lamp overheat.Thermistor in shortcircuit
E55 fusing thermistor open
When service call E5 conditions occur they cannot be cleared by turning OFF/ON the power switch.To reset turn ON the main switch,turn DIP switch 101-1 ON and OFF(the DIP switch is located in rear part under main supply board).,and turn the main switch OFF and ON.
Nov 11, 2009 | Office Equipment & Supplies
Showing error code C-0500 on a minolta model D1450, what's wrong?
Fuser unit malfunction code.Verify the fuser heatre lamp continuity,clean and check the thermistors and thermofuse continuity.Open the front door,press the service reset button close the front door.
Oct 30, 2009 | Minolta Office Equipment & Supplies
I just received an E003 error when running my Image Class 860 copier. Any suggestions? Thank you so much!!!
Please clean the fuser unit thermistors and thermofuses and verify the continuity the fuser heater lamp.
Sep 28, 2009 | Canon ImageClass D880 Copier
Error code SC 542 on my Gestetner Dsm622sp
Fusing unit problem.Verify the heater lamps,thermistor and thermofuse continuity.Enter in the SP mode turn OFF the main switch,unplugged the machine wait 10 sec.,plugged and turn ON the copier.
Sep 24, 2009 | Gestetner Office Equipment & Supplies
Copier won't fire up
your fuser unit is not working .open and see your thermofuse, thermistor or your heater lamp is out. if there is dirty between your thermostart & your fuser roller, clean . check for continiuty on your thermofuse & fuser lamp. thanks
Nov 12, 2008 | Office Equipment & Supplies
C6 error
Error C-6 appears on photocopier
Nov 06, 2008 | Copystar CS-1500 Copier
C7 Eror Code
C7 Fusing unit not warming up properly. It can be the fuser is not in correctly, fuser connector not making good contact, defective thermistor, fusing lamp or thermofuse.
Hope that helps...
Jun 17, 2008 | Toshiba 6560 Copier
Copystar CS-1500 Copier Logo
96 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
