Question about Linksys (WMP54GS) 802.11g/b Wireless Adapter
Need to change Linkys 802.11G to a 'mixed' 802.11B
Setting up my new Palm TX. I have a wireless router in my home so I thought for sure I could use the WiFi in the Palm TX in my home. Couldn't connect sucessfully, tried Palm Tech support. They informed me the router setting has to be either 802.11B or a 'mixed' setting where it has both B & G ???
Can I change the wireless router setting from my desktop?
if so, how? Will that change effect the other laptop users in my home that use this router?
thank you so much for your help!
    Sergeant:
  • 320 Answers
Thanks for choosing fixya.com
Changing to "mixed" mode should not cause any problems with your other system. It simply tells the router to transmit and receive using both B and G.
First you will need to log into the routers web interface. If you have the manual it will help greatly in doing this.
Otherwise it is usually default of 192.168.1.1 or 192.168.0.1. Some routers use alternate ip's the exact model would let me look up more information.
By putting one of those ip's in the address bar of your web browser your should be taken to your routers web interface. From here you can change all the settings you'll need.
You will want to find and click the "Wireless" tab at the top of the page. In here it should have a drop down menu for B-Only, G-Only, Or "mixed".
Set it to "mixed" and press save.
Here is a link to a screenshot of what the page should look like
http://i303.photobucket.com/albums/nn133/techiedesign/wireless.jpg
I hope this helps you.
Jei
Posted on Dec 14, 2008
Forgot password to router how do i reset it is a linkys wrt110
Hook up the router via Ethernet.
In your web browser type
192.169.1.1
username=blank
password=admin
In this page you will be able to go to the wireless setting and wireless security which are where you can find the password change tool
May 22, 2011 | Linksys WRT110 Wireless Router
Dir-655 works with XP and Mac which can connect
Go to 192.168.0.1 and login. Then go for the 'Setup' tab on the top and look for the 'Wireless Settings' tab on the right.
You can now automaticly setup your WLAN connection and afterwards you can go to the 'Manual Wireless Network Setup'. Over there you can change the 802.11 mode.
  • 802.11b only
  • 802.11g only
  • 802.11n only
  • Mixed 802.11g and 802.11b
  • Mixed 802.11ng and 802.11g
  • Mixed 802.11n, 802.11g and 802.11b
Go for the last one that uses n,g and b and you will be sure your computer can connect :)
Dec 14, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Ugrade 3com router 3CRWDR200A-75
The first thing I would check would be in the configuration (point your web browser to 192.168.1.1 when you have a wired connection) panel, under:
Wireless settings > configuration
If the 'Wireless mode' is set to 'SuperG', this may be your problem. The SuperG setting will only work with SuperG enabled wireless adapters. First change this setting to 'Mixed 11b/11g'; if it still doesn't work switch down to '11g' then to '11b'.
Do all your wireless testing with a laptop or PC as close to the router as possible - same room at the very least.
If all other settings are correct (double check them), this is the only thing I can think of that can instantly make a difference.
If you feel the firmware may be faiilty, note that although 3.0.1 is the 'newest' on the 3com website, even in their own knowledge base they refer to newer versions. These newer versions are available at:
http://3crwdr.googlepages.com/
You could try using one of these (at your own risk), if you feel it is the firmware itself that is causing the fault.
Mar 24, 2009 | 3Com OfficeConnect Wireless Router
WiFi not connecting to cisco router
most likely the Palm "listens" on another frequency.
Make sure your cisco is running the Wireless b standard as that is what the Palm Tx needs.
Mixed mode is another option (b and G at the same time)
Let's say your router is supporting the b standard. Knowing the cisco APs a bit, it is also possible to have a channel selected that an older device cannot see/or it is set for another region (which in fact is the same, as frequency ranges are different for each continent).
There are many tools for WIFI analysis, many are free. They will tell you what your router is transmitting at, etc... withouth having to go into the cisco IOS.
Jan 01, 2009 | Palm TX Handheld
Changing router settings from 802.11G to mixed w/802.11B
Switching the wireless mode is easy, and, if you choose "mixed," the other computers in your home can continue to use the G mode unaffected. How you adjust the mode depends on the brand of router. Since Linksys is the most common, here is how it works on a Linksys router:
1) Open your web browser (IE, Mozilla, etc.)
2) Type the web address 192.168.1.1 (default for Linksys routers).
3) You should be asked for a username and password. The default for Linksys is username "admin" and password "admin" OR username "admin" and password [blank].
4) You should then see the Linksys setup screen. The tabs across the top include Setup, Wireless, Security, etc. Click on Wireless.
5) Pull down the menu next to "Wireless Network Mode" (which shold be set to "G -Only" and choose "Mixed." Then click "Save Settings."
This should allow your B-capacle Palm to use the network without a password while still allowing your encryption-capable computers to use the G mode.
I hope this helps - please let me know if I can be of any further assistance.
H2H
Dec 14, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Repeater function
you make a device into ap mode you can get it
Jun 09, 2008 | SMC EZ Connect g SMCWEBT-G
Palm tx
Does your linsys router have MAC filtering turned on in the WI FI settings?
Apr 06, 2008 | Palm TX Handheld
How do I change wireless settings on the router?
In the routers web-interface -> click on login -> Advanced setup -> wireless -> enable -> apply -> channel and SSID -> Set the following values: SSID : Set it to your name SSID broadcast : Enabled wireless Mode : Long range Mixed (11b + 11g ) Transmission rate : 11/ 54/ 108 Mbps Channel : 6 g-nitro : disabled
Feb 19, 2006 | SMC Barricade 7004
Feb 19, 2006 | SMC Barricade 7004 Router
Open Questions:
See all Linksys (WMP54GS) 802.11g/b Wireless Adapter Questions
Linksys (WMP54GS) 802.11g/b Wireless Adapter Logo
61 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
