Question about Microwave Ovens
Microwave I have a KitchenAid over the stove microwave and am currently trying to uninstall it to replace it. I have removed the top screws from the microwave but can not get the microwave off the mounting plate.
  • Microwave Ovens Master
  • 9,098 Answers
You can download Kitchenaid/Whirlpool owner's manuals and installation instructions here.
They're very handy when uninstalling them too.
If you have a problem with your microwave, we may be able to guide you to an affordable repair.
If you're interested, please reply back with your brand and model number as well as your symptoms so we can help you.
Posted on Dec 15, 2008
How to uninstall an over the range Jenn-air microwave JMV8166BA
Remove two phillips screws from each side of the microwave. One at the very top and one at the very bottom. Remove the front cover. There will be a couple of other screws and metal stops under the microwave that will need to be removed also. After that, the back of the microwave will need to lifted and move forward just a bit to release the back. Pull the microwave forward and toward the left side, enough to be able to reach behind the right side of the oven and unplug the microwave. Remove the microwave. To reinstall, just reverse these steps. It might help to use a mirror and check out the 110v 60Hz socket in the top right corner of the oven that you will need to plug the microwave back into when you replace it.
Jul 17, 2014 | Jenn-Air JMV8166B 950 Watts Convection /...
How do I attach a microwave model #721.80413 to the wallI
if this is a above stove brand.. you have to open the top cabinet right on front lip of cabinet are three screws going into microwave... support unit and remove the screws that hold unit
May 26, 2012 | Kenmore 63662 / 63664 / 63669 Microwave...
Kitchenaid khms155lss4 microwave combo went dead what fuse should i check frist
Check to make sure you are getting power to the receptical, plug a lamp to confirm. Next unplug microwave oven and remove top, "several screws" now look inside where the keypad is, follow the wiring to the circuit board, there should be a small glass or ceramic fuse clipped in, before you take it out discharge silver rectangular capacitor with a screwdriver across the points to make sure all voltage is removed. Now unclip the fuse and test, if open replace with the same current rating, if no change I recommend a technician to take it further. Please remember there is extreme high voltage when unit is plugged in and running making it lethal, put the top back on for safety sake.
Mar 02, 2012 | KitchenAid KCMS145J Microwave Oven
I need detailed instructions on how to change light bulb on Kitchenaid microwave KBMC147HSS0
Please check the details of how a microwave works which will help you identify before the panel is removed and the lamp replaced.
The top cover of the unit can be removed after the screws can be removed with the power cord removed. The lamp can be seen fitted on the front side with the light to shine into the chamber, you can remove the buld from holder and replace with the same type .
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
Oct 27, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
Replace the buttons on a kitchenaid microwave Khhs179lss-5
First, you need to uninstall the microwave (MW) from the cabinet by removing the screws that hold it in place at the top. Open the cabinet doors above the MW to locate the screws.
You will need someone to help you at this point in removing the screws and dropping the MW down. Be sure and unplug the MW before you remove the screws.
Next, you need to take the cover/shell off by locating and removing screws A/R. They are mostly across the back and side bottom.
From there on out, you should be able to methodically find and locate the various fasteners that will get to the button pad.
Dec 16, 2009 | KitchenAid KHHS179LSS Convection /...
How do you remove a microwave above the stove
Take the glass tray out and unplug it. Remove the 2 or three phillips screws in the top of the cabinet going into the micro. They should be towards the front. Hold up on it while removing screws. When all screws are out, let it tilt forward and lift it up off of the hooks. Some require help, so be carefull and put blankets on your stove to set it on when it first comes out.
Apr 10, 2009 | Kenmore 63762 Microwave Oven
Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Mar 26, 2009 | KitchenAid Microwave Ovens
How do I uninstall an old Sharp R-1450 Carousel over the stove microvave oven? I removed the screws from the top that it hangs on and it still won't move. Help and Thanks.
You need to remove the grill above the door to find two more screws that go straight to the back wall plate. They will be on the left and right side. That is the only other way that they mount to the wall.
Good Luck
Dec 18, 2008 | Sharp R-1480 Microwave Oven
KitchenAid KCMS185JSS1 Door Removal
On most new MW ovens, the door will lift off the hinges once the top grille is removed. There are two screws on the top that hold the grille in place.
Mar 12, 2008 | KitchenAid KCMS145J Microwave Oven
Microwave Ovens Logo
138 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
