Question about Dometic Rooftop RV Air Conditioner
Overloaded generator I have a Dometic CAL 130 A/C which operates perfectly on 240V Mains supply, but when using a Honda EU20I generator the A/C puts the generator into overload mode after operating for 10-20 minutes. Using a clamp meter the A/C runs at 4.6 amps but when the problem occurs the meter amps up to 14.6 amps and the generator goes into overload mode. I was advised to change the thermostat which I have done, and it made no difference, i still have the same problem. Can someone please advise whats going on, as Dometic can't help me. The generator and the A/C have operated okay for the past 8 years, until this current issue.
  • 96 Answers
Check a see if it is when the unit is starting up when the over load happens if so you need a hard start kit
Posted on Dec 14, 2008
Why can't i run my a/c with honda 3000is generator
This generator will run an a/c unit up to 13500 btus and is good for 2800 watts. This is a small generator, the nameplate rating numbers need to jive before overloading the energy supply.
Jun 03, 2017 | Honda Electrical Supplies
Need an owners manual [booklet form only] for honda EU20i.
Honda EU20i owners manual is readily available on line I just did a search and came up with one.
Kevin H>
Aug 27, 2014 | Electrical Supplies
Stops generating and just idles
Check if there any alarm on monitor by pressing button several times. It has code like E-number. Replace spark plug, fuel filter. Clean carburator, spark arrester. Check wiring of thermosensor.
Mar 28, 2017 | Honda EU6500iS Inverter Generator
The device clearly states "AC ~ 220-240v", but is it safe to use a 250v cable? We lost the original cable.
A cable rated UP TO 250v (for it's a maximum rating, not a target) will be perfectly safe with a machine operating at between 220-240v
Aug 08, 2013 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hi,i have chescold rt50 fridge freezer,older model,colourbond brown colour,recently i have replaced the 240v element and the fridge work perfect again,at last camping trip i used on gas and work icy...
try disconnecting thermistor let run if cold replace thermistor if not bad board or cooling unit look for yellow stains on cooling unit or if you smell ammonia
Oct 13, 2017 | Dometic Refrigerators
I need to buy a generator for power. What is the watt power of a 32 inch ilo tv.
Hello A 32" TV sill draw about 175W from mains supply. So it is best for you to buy a generator having a rated power of at least 1000W, so that you can use the excess watts for some other purposes too, and the generator will not get overloaded with the use of TV only. Ok
Oct 27, 2010 | iLO IWT3206 TV
Honda EU30001 generator causes erratic pellet stove operation.
Ok Motors and the like generally DO NOT really go all that well from a generator, what load does the Stove use?, You must add up the cumlitive "Wattages" of ALL things connected, see your generator is about 3000 Watts, 3KW, How much "headroom" is there between the two? Whats supplied versus whats being used? Purely inductive loads, like Motors etc, are less responsive than electronic loads. I suspect that your generator is NOT providing enough current to the Stove, especially when "Other" things are connected. also. Look, if the, any, generator is 3000 Watts really you should only load it up to a couple of KW's, 2.5KW being about maximum. To do what you are doing would require, IMHO, at least, 5KW, to get the "Headroom" of current drawn over current able to be delivered by the generator. Also inductive loads loose heaps of power and actually cause a higher draw. So that your answer, you must use it well, inside it's rating, not right up to the limit.
Feb 26, 2010 | Honda 6370C - Parallel Power Kit For ...
AC puts generator into overload mode
ac conpressor load has increased, or the air handler, i would check the blower motor first.
Dec 13, 2008 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
300 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
