Question about HP Scanjet 7400c Flatbed Scanner
Hp 7400c haze on INSIDE of scanner glass
I would like to know if it is possible to clean the inside of the scanner glass--it is causing a bluish haze on scans
I figured this one out.
There is a language panel on the front (that tells you what each button does). The original instructions mentioned putting the panel on but not taking it off. If you use a small, thin screwdriver or thin, dull knife from underneath, you can work your way across the bottom edge, popping off the language panel. When you remove the panel you reveal three screws, one rather tiny one in the center toward the bottom, and two medium sized ones to the sides closer to the top. Slide the glass cover up and off. There are two more medium sized screws near the slots for the cover. Remove all five screws. The assembly with the glass comes right off, allowing you to clean both sides.
Posted on Aug 11, 2009
Clean inside glass door jenn-air jmc8130dd
follow your instruction manual, download from or www.
God bless you
Dec 09, 2013 | Jenn-Air JMC8130DD Microwave Oven
How to clean the glass underside of the hp scanjet g3010
working with computers since 1964 (yes, there were computers even then...), with consumer scanners since 1988, servicing hp equipment and scanners since 1998, for saving my life - i never, ever see any smudging on internal surface of the glass... could you kindly elaborate how you get smudging there?
there is no consumer serviceable parts inside, these are "disposable" scanners and never intended to be repaired or serviced inside.
Apr 24, 2012 | HP Scanjetâ„¢ G3010 Flatbed Scanner
How can you clean the glass on a Canon 8600F
Got this from The foggy haze on the glass is actually an anti-glare treatment that has been intentionally applied to the underside of the scanner glass. This treatment lessens the glare from the lamp under the glass and provides better image quality. This haze may not appear uniform because of the shape of the scanner base and the components under the glass. However, the anti-glare treatment has been uniformly applied and the haze is as expected.
Feb 07, 2010 | Canon CanoScan 8600F Flatbed Scanner
I need a driver for apple max os 10x
Check but dont shoot the messanger as some of there drivers cost a whopping $2.95 cents but i did say some so it may not pertain to you, you can also check the HP website and Thanks
May 25, 2009 | HP Scanjet 7400c Flatbed Scanner
Background has a bluish tint instead of white
the lens , glass inside your scanner is dirty with dust you need to clean this up and calibrate once again cheers
Nov 26, 2008 | Canon CanoScan 9950F Flatbed Scanner
How do I clean the INSIDE glass/platen?
You mean the inside of the scanner glass? (The platten is a part of the print unit),
You'll have to remove the sides and read cover. Unplug the scanner wires and remove the scanner assembly. Separate the document feeder from the scanner bed. Open the covers of the scanner bed (usually there are screws holding it together). Remove the glass and clean it. Reverse the process to reassemble.
Be careful. Canon multipasses are built a little like a Chinese puzzle box. There are little snaps everywhere as well as screws. Watch out you don't force anything and cause the snaps to break.
Nov 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Cleaning the Flatbed Glass
We cannot clean inside the flatbed scanner glass, it is not a removable part.
Jun 06, 2008 | HP Photosmart C6100 All-In-One Printer
Clean inside of printer glass
NOTE: The underneath side of the scanner glass cannot be cleaned on any product. This is unlikely to be necessary and should only be done by an authorized service provider.
This note is found on that website. For an authorized service provider near you: (in Canada)
(in USA)
May 23, 2008 | HP PSC 2210 All-In-One InkJet Printer
How do you clean the INSIDE of the scanner GLASS???
Here is the step-by-step for taking the glass out of the printer. I think I will take mine to a shop to have it done!
Nov 07, 2007 | HP Photosmart 2410 All-In-One InkJet...
HP Scanjet 7400c Flatbed Scanner Logo
659 people viewed this question
Ben Johnson
