Question about Ruud Heating & Cooling
Ruud Achiver series Furnace issue
I have a Ruud AC/Furnce that was here when I moved in, so I do not know the model. The problem I'm having is that when the hearter turns on, the gas ignites, but doesn't stay lit, and making it so that the heater never fully turns on. The a/c side and fans work.
Any help you can givre is appreciated.
  • Ken Bledsoe May 11, 2010
    Does it cycle like 30 seconds or so and goes off?
    Problem Solver:
  • 12 Answers
Sounds like it may be a bad flame sensor. After the ignition, the flame sensor needs to send 24v back to the gas valve to indicate the the ignition took place. If it does not do this, the gas will shut of as a safety precaution. The flame sensor can often be cleaned up with a piece of sandcloth to fix this problem, or it may be replaced.
Posted on Dec 16, 2008
Condensate Pump
no it will cause your furnace not to run at all if the condensate pump fills up
Jan 26, 2014 | Diversitech Condensate Removal Pump
Ruud achiever 90 plus
Check the exhaust condensate trap to see if anything came loose when servicing.
Dec 15, 2013 | Heating & Cooling
Ruud gas furnace burners won't ignite
Remove the stat cover and jump out the red and white wires. If the furnace still doesn't come on, it is your t-stat. Replace it.
Mar 12, 2017 | Heating & Cooling
What is the blink code for Ruud 2 stage ac/furnace
on the board itself or on the schematic there is a legend that will tell you what the blinks mean. start there. its just a diagram that gives you the fault according to the number of blinks
Sep 29, 2012 | Ruud Heating & Cooling
All my other AC Units have had a drain directly to the sewer system...usually connected under a sink. Does my Ruud unit only have the drain to the outside of the house? Usually, when the AC is draining...
If you have a CENTRAL air unit, you should have an overflow to a drain in the furnace area. So I don't understand what you are saying about a connection to the drain under the sink!
Do you have the make and model correctly listed? Because with your question it does not agree what I know about the Ruud Central air that you listed.
Aug 08, 2011 | Ruud UBHC Air Conditioner
I have a 90 plus Ruud furnace that will work when I light the furnce with a match when the furnace is calling for heat
Sounds like the ignitor. Your unit most likely has a hot surface ignitor. The hot surface ignitor is located in front of your burners and usually has two white wires leading you to it. It is a wear-and-tear item that can be expected to need to be replaced every couple of years or so. It would not hurt to keep a spare near your unit at all times.
How to test a hot surface ignitor
Mar 29, 2010 | Heating & Cooling
MY furnace is brand new i turned it on the first time and the carbon dioxide alarm start beebing i want to know whats wrong with my furnace i installed it myself.thank you serial no. m1a090701348 model....
Review the installation instruction and codes for the proper venting of a furnace of this type, Maybe ask a Furnce Contracter to do a service call on your installation.
Oct 18, 2009 | Heating & Cooling
Looking for a ruud achiver 90 plus manual
Go to Ruud or Rheem web site ask click tech support and the manuels download what you need. Rus
Oct 17, 2009 | Heating & Cooling
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Heating & Cooling Logo
116 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
