Question about Lexmark Z1300 InkJet Photo Printer
I need to program in the new ink cartridge - Lexmark Z1300 InkJet Photo Printer
    Sergeant:
  • 320 Answers
Thanks for choosing fixya.com
New ink cartridges should be auto detected by your printer once installed.
To install a new cartridge depends on the specific brand/model of your printer. Most time you can (with the printer on) open the plastic door in the front and the cartridge tray will move into position. Remove the old cartridge, remove the tape or plastic protector from the bottom of the new cartridge and put it into the ink carriage.
If this does not work for your printer it may have a button or menu option to move the carriage over. You should be able to find a down loadable manual at the printers manufacturer website.
E.G. Lexmark.com
Hope this helps, if not please ask further.
Jei
Posted on Dec 14, 2008
Why is power button light blinking green on Epson SX200 printer?
Regarding your recent inquiry about the Epson T071 ink cartridge error message ("Ink Light is red", "Cartridge Not Recognized", "Replace Cartridge", "Installed ink cartridge is expended." or similar cartridge/printer alert message) associated with your Epson SX200 printer, the cartridge probably has a mis-programmed smart chip...
NOTE: If you had the cartridge refilled, the cartridge chip must be reset. Re-programming, which typically yields a green light to show success, it does not always result in correct smart chip reprogramming. It is also possible they may have forgotten to re-program the ink cartridge. If a compatible/clone cartridge, it could be a reprogramming issue or defective chip (which is common). Or, such a failure could be an electrical failure of the ink cartridge itself*. Unfortunately there is nothing you can do from home....the chip(s) need to be re-programmed (at refiller) or replaced with a new cartridge from vendor.
*OTHER POSSIBLE CAUSES OF FAILURE:
Either the external chip or internal ink sensor is electrically bad (the internal ink sensor detects if cartridge is really out of ink). If you return the cartridge to your retail refiller and they re-program the cartridge(s) a 2nd time but the "replace cartridge" message, or similar blocking message persists, then this is the likely cause and the cartridge will need to be replaced with a new one.
1) Confirm if this is just a nuisance/annoyance alert (i.e. "non-genuine" cartridge ) vs. an actual 'unrecognized cartridge' alert (i.e. Red X's on printer display / Windows pop-up message). Please visit the following Inkjet411 support page which will help you delineate the difference: http://inkjet411.com/?page_id=73
2) On some Epson printer models you may need to scroll thru the menu options AT THE PRINTER'S CONTROL MENU (i.e. right arrow key) to help determine which specific ink cartridge is actually causing the 'Unrecognized Cartridge' error condition. On the other hand, for general 'non-genuine' cartridge alerts, typically you can bypass these errors by clicking thru the acknowledgement prompts or via the arrow keys: http://inkjet411.com/?page_id=1939
3) We suggest you remove all the ink cartridges, inspect the smart-chips condition (on rear side) and ensure there are no cuts/gashes or ink residue present on the micro-chip surfaces. To be sure we suggest you clean the micro-chip surfaces; click here to see 2 different pictures of this along with cleaning instructions: http://inkjet411.com/?page_id=1939
4) If the error continues (following ink tank re-programming a 2nd time), then we suggest you install a new genuine Epson ink cartridge into the printer to verify the permanent PRINTHEAD is functioning ok. Here is how the PRINTHEAD works: http://inkjet411.com/?page_id=2054
NOTE 2: Following refilled cartridge installation, your printer/computer may display an ink alert message such as "non-genuine cartridge" or "you have not installed genuine Epson ink cartridges" - these are COMPLETELY NORMAL alerts when using refilled ink cartridges. Press proceed/continue/accept/yes/OK to dismiss the prompt. In some cases you may have to scroll over using the arrow keys to dismiss the alerts. Additional alerts may be displayed the first time you go to print or copy - dismiss the alerts accordingly to resume normal print operations. For more information on Epson ink cartridge alert messages please visit: http://inkjet411.com/?page_id=1939
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors or permanent PRINTHEAD damage (especially for 3rd party inks which contain volatile organic compounds or VOCs). We do NOT suggest refilling these types of ink cartridges.....refilling of Epson original/genuine ink cartridges is only suggested!
Epson T068 thru T130 Ink Refilling Services & Additional Cautions: http://www.youtube.com/watch?v=Jp575rE9y0Q
NOTE 3: If, after replacing the cartridge(s), with brand new Epson Original ink cartridge(s), is the only solution which corrects the problem, then you likely have a defective cartridge (internal ink level monitoring circuit), unrelated to the refilled cartridges. If, after replacing the cartridge, or cartridges, with brand new Epson Original ink cartridges, does NOT correct the problem, then you may have a defective PRINTHEAD (i.e. permanent electrical sub-assembly which the cartridges plug into). For more information please visit our support page which explains the natural degradation of PRINTHEADs over time: http://inkjet411.com/?page_id=2934
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Sep 03, 2014 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
HOW CAN i CLEAN THE HEADS AND RESET THE NOZZLES.
How to Clean Print Heads
Method 1 of 5: Self Clean Program for Windows XP/Vista Users
1 Open the control panel menu and select "printers."
2.Choose the printer to be cleaned and right click. Select "properties" in the drop-down menu.
3. Choose the tab for cleaning. Various printers might have it listed under different names such as services, cleaning or maintenance.
4. Select the nozzles that should be cleaned, if applicable to your printer, and run the printer's cleaning program.
5. Print a test page and check results. Repeat cleaning 2 to 3 times if needed.
Method 2 of 5: Self Clean Program for MAC Users
1.
Click on "system preferences" and select "open print and fax."
2. Choose the printer that needs to be cleaned and open "Open Print Queue" or "Print Queue."
3. Click the utility icon for the applicable printer and select "maintenance." Select "cleaning" from the pop-up menu and click "OK." You might have to choose the tank you want to have cleaned.
4. Run the head cleaning program and print out a test page. Repeat cleaning 2 to 3 times if needed.
Method 3 of 5: Manual Cleaning
1.
Check your printer's owner manual for the location of your print head. Refer to the directions below if the head is in the printer and not part of the individual ink cartridges.
2. Remove the ink cartridges and dab hot water or isopropyl alcohol onto a cotton swab.
3.
Rub the swab against the print head to loosen dried ink. You can also use a dropper to drip 7 to 10 drops of the isopropyl alcohol into the ink receptacle if your print head is deep in the printer.
4. Run the printer's own cleaning program 2 times and then let the printer sit overnight. Repeat the self-cleaning utility the next day.
Method 4 of 5: Cartridge With Print Head
  1. 1Soak the ink cartridge in a bowl of hot water overnight if your print head is inside the cartridge.
  2. 2Remove the cartridge from the water and dry it thoroughly with a paper towel.Put it back into the printer and run the cleaning program. Repeat 1 time if it does not work.
  3. 3Place the ink cartridge into a bowl of isopropyl alcohol and let it soak overnight if the hot water soak did not work.
  4. 4Remove the cartridge and wipe it off with a damp towel before drying it.Attempt the self-cleaning program again. If it does not work this time, you probably need a new cartridge
Method 5 of 5: The Vacuum method
  1. 1I replicated the way the printers themselves try tho clean the cartridges
  2. 2Using a Vacuum cleaner hose
  3. 3attach the printer cartridge to the vacuum cleaner hose with the cartridge upright, nozzle down using plasticine or blu-tack
  4. 4for no more than a few seconds at a time turn on the suction , regulate using the suction or curtains regulator on the vacuum cleaner.
  5. 5Repeat if necessary
  6. 6if the print cartridge is cleaned , ink will be visible , if its a multicolour cartridge the resultant ink will be black if all 3 jets are clean
  7. 7wipe off the residue ink with tissue or toilet roll .
  8. 8Refit & print test page as per other comments .
  9. 9This definitely worked for me and has no know side effects apart from the odd inky finger !
Tips
  • Print a page every 2 weeks or so and turn off your printer when it's not in use to keep the print heads from clogging.
Oct 25, 2011 | Lexmark Z640 InkJet Printer
I have a Lexmark Z2390 inkjet printer and have just purchased new ink cartridges but do not know how to change them can you help ?
hello,here is how to replace or change ink cartridges: 1. make sure the printer is turned on. 2.lift the top cover or access door. sayurisan20_19.jpg
3.press down on the cartridge level to raise cartridge lid. sayurisan20_20.jpg
5.for new inks,remove the tape from the back and bottom of cartridge before you install it.DO NOT REMOVE NOR TOUCH THE COPPER CONTACTS OR NOZZLES ON THE CARTRIDGE. sayurisan20_23.jpg
6.insert black cartridge in the left slot and the color in the right. 7.close the lid and make sure it is closed properly. sayurisan20_24.jpg sayurisan20_25.jpg
you can align them to improve print quality by clicking on start,all programs or programs and then click on the lexmark folder,click maintenance,align cartridges,then print.
Jun 09, 2011 | Lexmark Office Equipment & Supplies
How do I install the printer cartrige? I do not have the booklet...
  1. Turn on your printer.
  2. Open the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
Dec 17, 2010 | Dell Inkjet 720 Printer
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
Lost my manual, need to change the ink cartridge, help
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
Black ink cartridge.
the printer only prints with all ink cartridge inside, back and color (use only original ink spares)
Dec 29, 2009 | Canon PIXMA iP1200 Photo Printer
Epson c70 problem
Re: Epson C70 Problem by Denny Conway (12/18/03 9:05 AM) reply + / - Aspah:A Service Error where all LED's/Lights are blinking at the same time,is normally a Maintenance Request Error, which is actually a Waste InkPad Overflow Error...JUST SO YOU WILL KNOW: On most Epson's, while theprinter is in this error condition, it disables all operations,including data communication. Normally your remedy is to replace theWaste Ink Pad/Pads with a new one/ones and then reset the InternalWaste Ink Pad Counter. If you just reset the counter and don't replacethe pads, then your printers old pads will eventually overflow andnormally start leaking ink out the bottom of your printer. You may wantto try doing a general search on the "fixyourownprinter.com" printerrepair site, under WASTE INK PADS or WASTE INK COUNTER RESET PROCEDURE.You should be able to find quite a few references listed in the lastsix months and most included web-site links, for possible help on thereset procedure. Some also list links where you can purchase a SERVICEMANUAL, in case you want to try and do the service yourself...GoodLuck! Denny Conway...P.S. THIS INFO POSTED BY "WES" MIGHT HELP: Wes12/07/2003 13:57:30 To see what's involved in servicing the waste inkpads try this http://www.epsonhelp.web1000.com/wip.html ...IF you just want to reset the wate ink counter you can use this program http://inkjetprinterhelp.us/epsonSSC.html.Resetting the ink counter will stop the lights from flashing butcleaning/replacing the ink pads is recommended. ...OR... Tim H12/10/2003 2:46:24 Subject: Epson Reset Program Download Location.after a long search for a reset program for waste ink, without paying,i found it. goto: http://inkjetprinterhelp.us/sscserve.exe ...please check that your printer is compatible goto: http://inkjetprinterhelp.us/epsonSSC.html ...p.s: this program has other features as well.
0.gif Re: Epson C70 Problem by Jim (12/21/03 4:10 PM) reply + / - I have just installed colour cartridges and a black cartridge into my C70.
Myproblem is that the black cartridge is not being recognised and I aminformed by the printer that there is insufficient ink in the cartridgeand a need a new replacement. The black cartridge that I have used is agenuine epson cartridge.
I have been informed by epson help linethat either I need to install a new new cartridge or that my printerneeds to go to Epson for a maintenance check.
I cannot afford another new ink cartridge nor can I afford the return charges and maintenance bill from epson.
Can you help?
0.gif Re: Epson C70 Problem by Wes t.gif (12/21/03 4:47 PM) reply + / - Theonly two option I can think of is to return the ink cartridge asdefective or you can trick the printer into accepting the cartridge.
Youwill need to download the SSC Service Utility and click on the "ResetCounters" tab and then click the "Reset Black" tab to reset the blackink cartridge. The only problem is you will need to reset or freeze theink cartridge.
You can get the SSC Service Utility here http://inkjetprinterhelp.us/epsonSSC.html
I hope this gets your printer going again.
Jan 02, 2009 | Epson Stylus C70 InkJet Printer
C60 says full cartridge is dry
You could try taking out the new ink and putting in the old. Then uninstall the program, delete all reference to Epson in Regedit, then reinstall the program.
Change the cartridge when prompted.
Of course, having messed about with the jet, it may not work now !
Jun 05, 2008 | Epson Stylus C60 InkJet Printer
Colour Ink
1. On your PC, go to Start, Programs (Windows XP: All Programs), Lexmark series.
2. Select the Solution Center.
3. When the Solution Center appears, click on the Maintenance button.
4. Select the option to Install a new print cartridge. The carrier should slide over at this point and allow you to insert and/or remove cartridges.
5. Make sure the correct cartridges are installed inside the printer first, then inform the software which cartridges have been installed. Note: This applies also to installation of a single cartridge.
6. Print the Print Alignment page to ensure the print quality is satisfactory.
7. Close the Solution Center.
Mar 23, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark Z1300 InkJet Photo Printer Logo
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
