Question about DeLonghi TRD0715T Oil Filled Radiator Heater
Won't heat I have an oil filled heater, my dog knocked my heater over and it fell on a sleeping bag. I didn't even know it fell, so it didn't fall on a hard floor. So i picked it up and turned it off and unplugged it. I tried to turn it back on and the lights come on, but now it won't heat. It has only been used for 1/2 a season, so it's almost new.
  • 3 Answers
Try calling delonghi america at 1800 322 3848
Posted on Dec 15, 2008
Bag falls off after a few sessions..
try going to the shop where you bought it and see how to attach the bag properly
Dec 23, 2017 | Miele CatAndDog700 Bagged Canister Vacuum
Won't heat my studio - even on "HIGH"
Does it get hot? If so, that is all you will get! It is not made to heat a room of 20 X 15 X 8 feet high. That is 2400 cubic feet of air space that may or may not be insulated. You need a quartz heater or two that are designed with fans to heat larger areas (see the specifications on them). The oil filled radiator is to put next to your rocking chair or under your desk near your feet!
Jan 01, 2013 | Comfort Zone CZ7007 Oil Filled Electric...
Will my down-filled sleeping bag get ruined if it gets wet?
If your down-filled sleeping bag gets wet the only thing that will be ruined is a good nights sleep. If the insulation gets wet, you should throw it in the dryer on low heat for about 30 minutes.
Aug 05, 2012 | Camping, Backpacking & Hiking
My dog knocked something heavy onto my heater and broke two of the wheels. I need to know what material the wheels are made of (what type of plastic) so I can try to fix them. I think they can be glued...
ok well you shouldn't need any special material should be able to glue back or find four wheels that bolt to a tall toolbox which should be cheap at any hardware or lowes, homedepo store drill a hole where ever is not the oil tank, preferably where the tires use to be u know like where the old wheels useta be bolt down an good to go
Feb 11, 2011 | DeLonghi 6507L Oil Filled Radiator Heater
Heater was knocked over. now will not come on
try tipping unit over to reset the safety switch that was activated when it fell. u may have to do this a few times.
Jan 05, 2011 | Honeywell HZ-709 Oil Filled Radiator...
I switch it on and with in ten mins its smokeing, whats the best way to get it fix it
Hey how's it goin'?
I had the same problem too.
There's a couple reasons the heater will do that, neither of them are good.
One reason is the heater has developed a leak and you can't fix that. The units are oil filled and if it was dropped or the dog chewed a hole in it ( I had a pretty mean dog ) then you can't seal it, it's time for it to go.
How the heater works;
Oil inside the unit heats up, expands and holds heat while you're getting warm. If the unit is leaking oil, you might even smell something like motor oil burning. That would be a gigantic tel-tale sign.
One other reason, and I had this problem too, is the wiring is getting tired and the wire jackets are getting too hot.
There's a couple reasons for that too, but unless you're a wiring expert or electrician, you're outta luck again.
Once the jackets of these heaters wiring starts to burn, there's no turning back. You need to replace all the wiring and terminals or solder new wiring inside. Special wiring, terminals the whole nine yards.
Rewiring one of these baby's is a job for an expert, even I might shy away from one. And I've been in the industry for 35 years.
The final question is this;
Is your dog's life worth saving $20 at a garage sale?
I know, I know, it can be a toss up.
But make sure and DO NOT USE A HEATER THAT SMOKES.
TURN IT OFF
UNPLUG IT
TAKE IT OUT OF SERVICE TILL REPAIRS ARE MADE
IF YOU WONT FIX IT, DISPOSE OF PROPERLY
Good luck.
Russini
Oct 30, 2010 | DeLonghi 6507L Oil Filled Radiator Heater
Heater fell over while transporting in car,now it will not heat up even though the on lights come on to set power..
with heater unplugged, check all connections with an ohm meter, sounds like something got jarred loose. also check heating elements for resistance. if no ressistance, probably a broken heating element.
Jan 19, 2010 | Lakewood Oil-Filled Electric Radiator...
My heater won't turn on.
There really isn't anyway to give a difinitive answer to your problem. it requires some trouble shooting. Did you blow the breaker on the circuit feeding the outlet you had your heater plugged into? Is there a power indicator light on your heater? If so, when the dog tipped the heater over was it still working (ON)? If no indicator the problem gets more tedious and techy.
Oil heaters are great and simply designed. They are closed systems with heating elements that connect to the other end of the wire that plugs into your wall. The switch is in between the two to allow current to pass or not. If any of those connections was shaken loose by the fall it would cause your heater to malfunction. That's something you (or a service person) can only verify by opening the unit up. Hope this has helped...:-)
Jan 09, 2009 | Lakewood Oil-Filled Electric Radiator...
DeLonghi TRD0715T Oil Filled Radiator Heater Logo
413 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
