Question about Plumbing
Trying to take apart to find the leak
Have a Price Pfister Parisa RT6-amcc.
Got the set screws out but not sure how to take off part # 941-37
The fauset is dripping and a small amount of water is coming out above the 941-037 part number.
Any ideas?
Thank you from Hawaii!
Marty
  • 1 more comment
  • martykimball Dec 14, 2008
    How do you remove diverter?
  • sperezllc Feb 02, 2009
    Im having the exact same problem. I know where to buy the parts however the faucet was installed in a roman tub that has no access. There is no way to get underneath the tub.
    Im afraid if I start to take the faucet apart that it might fall underneath the tub.
    1. Would that happen?
    2. if not, how do I go about taking it apart?
  • dclovis95 Mar 01, 2009
    I have a price fister 34 series kitchen faucet in my motorhome.  I have never seen the type of hardware that is under the sink.  There seems to be a long rod attached to a horseshoe looking bracket which appears to hold the faucet in place.  Does the rod turn to release the faucet?
    Thank you.
  • 101 Answers
Turn off water supply, if its a single handle there should be only 1 set screw then diverter is screwed down. After you remove the diverter there is a small rubber washer or o-ring ..let me know which it has.Thankyou.
All Price Pfister Parisa Collections products are backed by the Pforever Warranty, which guarantees both finish and function for the life of the product.
Posted on Dec 14, 2008
How to disconnect the quick connect spray hose in a Price Pfister Parisa
I also needed to remove the "hidden" flow restricters from my Price Pfister Parisa Kitchen Pull out faucet. The hot water side had never flowed the same as the cold side. Now both sides are flowing the same as should have been all along.
Nov 30, 2012 | Price Pfister Marielle Kitchen Faucet with...
Price pfister chane
There should have been a new rubber seal with the purchased replacement. If not you need to contact the supplier and let them know it was not in your package.
Nov 25, 2012 | Price Pfister Plumbing
Price pfister pull out kitchen faucet starting leaking suddenly and profusely at base, from joint segments along handle base, directly under handle and possibly at base of faucet. Understand I need to...
Most likely it is under the label , it is normally put on with light adhesive. That is where the set screw is most cases. As far as leak goes, your on right track with 0 rings/gaskets. Be careful however, some time you can just get one at hardware store ( whole unit) already together almost as cheek as repairing this unless it is just a couple 0 rings.
May 27, 2011 | Price Pfister Plumbing
I have a Price Pfister Traditional Chrome Roman Tub Faucet Model #WR2700C. It is a brand new faucet, just installed it. I'm getting a very slow drip from the faucet. What can I do to stope the leak...
There could be debris wedge in the cartridge of the faucet. If you have tried pulling the cartridge out to see, and you are still having these issues, more than likely it is a defective cartridge; in which case it should still be under warranty. If you haven't tried this, then I would recommend doing so. Just be sure to turn water off to your faucet first.
Nov 15, 2009 | Price Pfister RT6-E0XC/HHL-ELBC/0X6-040...
How do you take apart the price pfister 533 50?
On the under side of the handle is a plastic plug its either red and blue or its a logo about 1/4" dia., remove that and there is a set screw that attaches the handle. Loosen that screw just enough to pull the handle off. Then you can disassemble the faucet for repairs. Price Pfisters have a lifetime warranty, if the cartridge is bad you should contact them for a replacement part.
Sep 16, 2009 | Plumbing
My shower is running cold water only, the rest of house has hot water
sounds like you have a single lever shower, in this case the valve stem which mixes the hot and cold has a clogged hot side , you'll need to remove and replace the cartridge or valve stem
Sep 12, 2009 | Price Pfister RT6-E0XC/HHL-ELBC/0X6-040...
Trying to remove cowell from Roman tub faucet
The Price Phister Roman tub spout needs to be tightened from beneath.
If you do not have a removable skirt on the tub it will be a bit difficult to tighten.
Should you have crawl space under the tub and are careful to locate the dead space between the tub and the skirt you can cut a hole beneath the valve and spout location and reach up from below to tighten the spout.
If you have tile as a surround and no access from below you will have to remove some of the tile in order to gain access.
You may want to call in a proffessional plumber to handle this.
Hope this helps,
sanray
Dec 27, 2008 | Danze D302521 Antioch Roman Tub Faucet...
Plumbing Logo
932 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
