Question about Sharp FO 760 Plain Paper Thermal transfer Fax
How do you send a fax with a fo 760? - Sharp FO 760 Plain Paper Thermal transfer Fax
It asn't my fax, I as doing it for a freind. I own mainly HP products and I gotta tell you the online help from HP is very good, after tying to find out just how to fax a peice of paper from sharp I would never buy a sharp machine.Regards Paul.
Posted on Dec 14, 2008
Sharp FO-2081 clear memory full
enter simulation mode using # * c * after you are in run test command 66-10
Apr 08, 2014 | Sharp FO-2081 Copier
Fo-2081
I am a tech that Services Sharp. Enter simulation mode using # * c * after you are in run test command 66-10 This problem happens from you getting a bad fax mostly from noise or interference to the line. if it happens a lot to you then try getting a power filter with network and fax ports.
Dec 13, 2013 | Sharp FO-2081 Copier
My fax can receive but is unable to send. Message is COMM ERROR 2
Your machine failed to communicate diring the initial protocol. This is the handshake that tells the receiving fax that you are what you are. IMPORTANT Check that your fax ID is entered in the fax, as some countries require that if it is not present to reject it. This can also be set on any receiving fax to reject junk fax. So Both the TTI and the CSI must be entered in your fax to work.
Oct 06, 2010 | Sharp FO 760 Plain Paper Thermal transfer...
Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
It's gone forever, once your machine received a EOT (end of transmission signal), your fax machine thinks it was received OK and clears it from memory.
Oct 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Need operation manual for Sharp FO-1460. Can
Turn your fax off then back on. If the problem persist try a memory clear. Press function 9 * 8 # 7 then press start , then keep pressing your # key until you see memory clear then press start. You will lose #'s that are stored. If the problem still persist try another phone line(analog line). This problem will not be in your owners manual, but if you still need one I would do a google search.
May 17, 2009 | Sharp FO 1460 Plain Paper Thermal transfer...
Can send but can't receive faxes.
Make sure its on standby auto not manual.
Dec 15, 2008 | Brother IntelliFAX 4100 Laser Fax
Problem with Sharp FO-1460
What happens when you make a copy?
If that is blank, you have a bad scanner.
Jan 09, 2008 | Sharp FO 1460 Plain Paper Thermal transfer...
Sharp FO-4450 errors when sending to Brother Intellifax 475-0E
Tell me more. What model Brother? Did you call them and make sure the Brother is set to auto receive?
Aug 09, 2007 | Sharp FO 4450 Laser Fax
Sharp FO 760 Plain Paper Thermal transfer Fax Logo
115 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
