Question about Polaroid PLA-4250A 42 in. HDTV-Ready Plasma Television
Where do i find the codes to program my remote to the cable box
Hello i have a cable box and wish to program my tv remote to the cable box but where do i find the codes to do it?
    Novelist:
  • 152 Answers
You can do a auto progrom
first you turn tv on
on the cable remote you have the io button and the tv button you press them both down at the same time for 3 secounds the io button will light up while it is lite you press the channel button up or down till the tv turns off then you press tv again it should blink twice to confirm the code then you will be able to use the remote with your tv if it dosent work take your time when it goes off dont hit the channel button to fast or again or you will load the next code if it dosent work try it again slowly till the tv turns off
Posted on Dec 14, 2008
How do I program a charter remote to a rca converter box
Charter 1060BC2 and 1062BC3 - Setup
www.urcsupport.com/html.php?page_id=762
SETUP. The Charter 1060BC2 and 1060BC03 Remote Controls are preprogrammed to operate the cable box (converter) provided by your cable system, an RCA TV, a Toshiba DVD player, and a Pioneer audio receiver. To control devices other than the default brands, perform the following steps; otherwise skip this section.
Program the Digital Cable Remote Control
mscharter.custhelp.com/app/.../program-the-digital-cable-remote-control
Dec 10, 2013 - Highlight or write down the codes and device you wish to programbefore moving on to Step 2. On the remote control, press a device key once (i.e., AUX, DVD , AUD, TV or CBL); it will blink once. Then, press and hold SETUP until the selected mode key blinks twice, then release SETUP.
Charter.net Charter Remote Controls - 1060BC2/1060BC3
www.charter.net/.../charter-remote-controls-106...
Charter CommunicationsProgramming Codes: Select the manufacturer of your device from the list. The codes will appear beside the list boxes. Not all manufacturer brands listed may be ...
Charter.net Charter Remote Controls - OCAP-4
Jan 21, 2016 | RCA Televison & Video
How to program a rcr804bfdr to a sanyo tv
Programming the RCA RCR804BR or RCR804BFDR Series Remote Control
Programming with Direct Entry:
To program your remote to control up to four components, follow these steps:
  1. Manually turn on the component you wish to program the remote to operate.
  2. Find the four-digit code for your brand of TV, VCR, DVD, satellite receiver, cable box, or digital TV converter in the enclosed code lists.
  3. Press and hold the CODE SEARCH key until the indicator light turns on.
  4. Release the CODE SEARCH key.
  5. Press and release the TV, VCR or SAT·CBL·DTC key. The indicator light blinks and then remains lit. Note: DTC references digital TV converter. To program the DVD·AUX key: Press the DVD·AUX key. To control a DVD, press the VCR key. To control a TV, press the TV key. To control a satellite receiver, cable box, or digital TV converter, press the SAT·CBL·DTC key. The indicator light stops blinking and remains lit.
  6. Enter the four-digit code, using the numeric keypad. After the code is entered, the indicator light turns off. Note: If the indicator light blinks multiple times, you've entered an invalid code. Start from step 2 again.
  7. Aim the remote at the component and press the ON·OFF key. The component should turn off. Note: If your component does not respond, try all the codes for your brands. If the codes do not work or your brand is not listed, try the Code Search Method that follows.
Programming with Code Search:
If your TV, VCR, DVD, satellite receiver, cable box, or digital TV converter does not respond after you have tried all the codes for your brands, or if your brand is not listed, try searching for your code via the Code Search Entry Method. To program your remote via the Code Search Entry Method, follow these steps:
  2. Press and hold the CODE SEARCH key until the indicator light turns on.
  3. Release the CODE SEARCH key.
  4. Press and release the component key you wish the remote to control- TV, VCR or SAT·CBL·DTC key. The indicator light blinks once and remains lit. Important: Find the ENTER key on your remote (don't press it yet). You will need to press this key quickly in step 6 below. To program the DVD·AUX key: Press the DVD·AUX key, followed by the component key you wish the DVD·AUX key to control. For DVD, press the DVD·AUX key, followed by the VCR key. For an auxiliary component, press the DVD·AUX key, followed by the corresponding component key ( TV, VCR, SAT·CBL·DTC ).
  5. Press and release the ON·OFF key until the component turns off. Important: You may have to press the ON·OFF key up to 200 times.
  6. As soon as the component turns off, press the ENTER key within 4 sec- onds. The indicator light turns off. Note: If you wait longer than 4 seconds to press ENTER, the remote goes to the next code-you will need to start the code search from step 1 again.
Dec 24, 2014 | RCA Televison & Video
Why won't television turn on with remote control?
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 12, 2014 | Sanyo DP26640 LCD TV
Need to program a symphonic tv with a oneforall remote urc-4021boo
Hello
Setup codes for Symphonic TV with One for all URC 4021 remote control are:
0180, 0171
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
before starting step 2.
[2] On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY
OK
Jul 26, 2011 | One For All URC-4021 Remote Control
I have One For All URC-4063 remote control. How do I program it to my orion TV
Hello
The codes for Orion TV with One for all URC-3021 are
0236, 0463
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to
NOTE: If the device does not have a POWER key, press PLAY.
Mar 20, 2011 | One For All URC-3021 Remote Control
I need to know how to program a RCA universal remote RCU404N
Hello
Programming method for your remote control follows:-
In order for the 4 component universal remote to control your DVD player or auxiliary component, you must program it with the code that matches your component. The DVD•AUX key can be programmed to operate a DVD player or a second TV, VCR, DBS or cable box. These instructions explain the preferred method of programming the remote-the Direct Entry method.
1. Manually turn on the component you wish to assign to the DVD•AUX key (TV, VCR, DVD, DBS System or cable box).
2. Locate the enclosed DVD code list, or the
corresponding code list for the auxiliary component (TV, VCR, DBS, or cable box).
Note: If your brand isn't listed, use one of the Code Search methods to program this remote control (See Code Search on page 9).
3. Press and hold the CODE SEARCH key until the INDICATOR LIGHT illuminates, then release the CODE SEARCH key.
4. Press and release the DVD•AUX key. The INDICATOR LIGHT will blink.
5. To program for DVD, press the VCR key. For an auxiliary component, press the corresponding component key (TV, VCR, DBS•CABLE). The INDICATOR LIGHT will blink again, then remain lit.
6. Use the number keys on the remote to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off.
Note: If you enter an invalid code, the LED will flash rapidly for 2 seconds. Start over at step 3.
7. Aim the remote at your component and press the ON•OFF key. If your component turns off, you have found the correct code.
8. Enter the code in the box provided on this page for future reference.
9. If your component doesn't turn off, repeat steps 3-7 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote (See Code Search on page 9).
Mar 18, 2011 | RCA Televison & Video
Hot to program the remote for a mitsubishi tv
Hello
Codes for Mitsubishi with one for all URC 4220 are:
0093, 0150, 0178, 1250
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, aMotorola cable
box, and an RCAVCR.To control devices other than the default brands,performthe
following steps; otherwise skip this section:
applicable, insertmedia (e.g., cassette or disc).
2. On the remote control,press a device key once (i.e., VCR/PVR,
DVD,CBL/SAT,or TV).
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
volume,andVCR functions.
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
then release SET.
4. Use the Manufacturer's Codes (starting on page 36) to
5. Aimthe remote control at the device and press POWER
6. Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
code in the following boxes:
OK.
Feb 26, 2011 | One For All URC4220 Remote Control
Hi. Can you please tell me the correct code for the Curtis tv for Cablevision Remote? We have two remotes now, the cable remote cannot operate the volume or the power on/off tv, must use Curtis remote.....
Hello
Codes for Curtis TV with Cablevison remote control are:-
070 004 101 127 236 011 072 081 120 164
*Tip: The iO button will light on for 20 seconds. The
next step must be entered while the iO button is
on.
STEP2 Press the [INFO] button.
The iO button will blink number of times indicating the
number of each digit of the code number. Each digit is
separated by a 1 second interval of the iO button being
turned off.
Example :One blink, three blinks and eight blinks with
an interval of 1 second of iO button being
turned off, indicates the code number 138.
Note :Ten blinks is equal to the number 0.
D. Program the Volume Controls.
By following the steps below, the user can program
the volume controls (Volume UP, Volume Down and
MUTE) . The default volume control settings on the
remote control is TV volume control. If you wish you
can control the volume via your CABLE box, use the
following steps.
STEP1 Press the [CBL] button and the [SEL] button
simultaneously for 3 seconds. The iO button
will turn on.
*Tip : The iO button will light on for 20 seconds.
The next step must be entered while the
iO button is on.
STEP2 Press the [VOL +] button.
STEP3 Press the [CBL] button.
The iO button will blink twice to confirm the
programming.
To return to original state:
If you wish you can control the volume via your TV,
repeat the above steps by pressing [TV] in STEP3 .
OK.
Dec 23, 2010 | Curtis CM13102 13" TV
Programming a sanyo tv with rcu403a remote and
Hello Jeffro
Programming a device using the Code Lists:
1- Sanyo 017,021,039,056,057,058 (codes)
2- Press and "HOLD" CODE SEARCH.
3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH.
6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists
Hope this helps you out.
Cheers Little Dish Fitter
Oct 09, 2009 | RCA RCU403 Remote Control
Need remote codes for emerson lc320em9 so can program cable remot
If you only wish to power the TV off/on with the remote, there is an alternative. Plug the TV into the outlet on the back of the Comcast box. In the Setup Menu for the Comcast box there is an option to make the outlet switched or unswitched. Select SWITCHED then the TV will turn on/off with the Comcast box. The
LC320em9 will maintain the previously selected input.
Jan 16, 2009 | Televison & Video
Televison & Video Logo
196 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
