Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
QuietPower 3, water seeps into unit,fills the base once per week.
The water spilled onto the floor through the bottom of the door this morning, and the dishwasher wasn't turned on.
  • 71 Answers
I need more info but I would check the drain connection under the sink to make sure that it goes up after leaving drain , to keep the sink from draining into the dishwasher.
Posted on Dec 14, 2008
I have a magic chef French door refrigerator. Water under the freezer becomes ice and when this melts water seeps onto the floor. Sometimes enough water to completely soak a couple of towels
Lower the setting to your FREEZER this may be defrosting too often and the drip pan is over filling, or stop leaving the doors open too long .
Oct 04, 2014 | Magic Chef Refrigerators
Dish washer spills suds on floor
Sounds like door seal. The rubber seal ends at the bottom of both sides. examine the ends to see if they look the same. some have a plastic insert. it may fallen out. cheap part to order.
Apr 14, 2014 | Whirlpool Gold WDT910SAYE Fully Integrated...
Water is collecting in the bottom of refirigerater, spilling out on floor. Leak in drain pan was caulked by repair man, but water is now statring to appear in the bottom of unit again. Can this be normal...
Hi!!
Check temp. settings and try to lower it 1 click, this will keep the unit working a little less, ddiminishing the condensatino.
Also try relocating the unit to a cooler spot, ie. away from the door.
Keep me posted!! Rate this post!!
Aug 12, 2010 | Kenmore Refrigerators
The drain pan at the bottom of the freezer side is overflowing.
If your water filter is " thru the kick plate , at the bottom , replace the filter . I have found several times now , where the filter rubber seals , have leaked into the drain pan , causing it to over flow . You do not have to replace the filter housing , just the filter .
Nov 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Water seeps out of freezer side of fridg onto the floor, I have totally remover the water line going to the ice maker and it still has water seeping out. It builds up Ice on the bottom of the freezer and...
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 25, 2009 | Magic Chef Refrigerators
Washer fill with water when it is not on...
remove top 3 screws in rear of top panel..left rear corner water valve where hoses come in replace it not shutting off completely
May 19, 2008 | Kenmore Elite 45986 Front Load Washer
GE tFX26KR side by side leaks water onto floor
remove the back of the unit at the bottom where the compressor is, it is held in place with 5/16ths screws. locaate the drain tube going to the drain pan, it is held in place with a spring type clamp, remove the drain tube and run water through it till it is clean and not obstructed, reinstall all parts
Apr 11, 2008 | GE GSL25JFPBS Side by Side Refrigerator
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
209 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
