Question about Alpine Car Audio & Video
The little scroller that dimmes my dash lights shuts off my radio... y
    Problem Solver:
  • 14 Answers
Whoeva installed your head unit has most probly connected the red or yellow, to the wrong wire. use a voltmetre to find a constant hotwire connect to yellow then turn on ignition and find an acc wire.
Posted on Dec 14, 2008
2005 dodge stratus traction control light is popping on and the radio shuts off and on when this happens, what is wrong?
You probably have a cold (bad) solder joint in the dash compartment that also control the radio.
Mar 02, 2015 | 2005 Dodge Stratus
My 2004 dodge neon will not start head lights and radio work no dash lights.
Start from scratch, check all the fuses. Have someone with a little knowledge check all the wiring harness multi pin plugs. As some things are working I get the impression a harness plug either in the engine bay or under the dash is not fully engaged.
Feb 22, 2015 | 2004 Dodge Neon
Dash lights dont shut off after installing a new radio can someone help me?
installed new radio n now my dash lights stay on even when key isnt in the ignition.
Oct 02, 2012 | 1992 Buick LeSabre
2004 trailblazer lt battery light on dash is dimmly lit off and on no pattern to when it comes on what is the problem?
SOUND LIKE ALTERNATOR,FIRST CHECK ALTERNATOR DRIVE BELT MAKE SURE BELT NOT LOOSE AND DAMAGE AND BELT TENSIONER BAD,CHECK THE ALTERNATOR WIRES FOR DAMAGE.CHECK ALTERNATOR VOLTAGE WHILE ENGINE IDLING SHOULD BE 13.5 - 14.5 VOLTS. IF NOT ALTERNATOR VOLTAGE REGULATOR FAILING. FIRST TURN OFF RADIO IF YOU DISCONNECT NEGATIVE BATTERY TO REPLACE ALTERNATOR BECAUSE THAT WILL KEEP YOU FROM LOCKING OUT RADIO AND LOSING THE PLAYING CODE.
Jul 30, 2011 | 2004 Chevrolet TrailBlazer
2000 Chevy S10 Instrament cluster lights for gauges do not iluminate at night. Radio displays durring daylight, not after dark dimmer reostat dimms and brightens head light switch, cant find a fuse. Whats...
There is an illumination fuse located in the dash fuse box. It is typically a 5amp fuse. Pull the fuse out and see if it is blown. Try replacing the fuse and see if it blows again, if it does there may be an additional problem.
Good luck.
Jan 07, 2011 | 2000 Chevrolet S-10
My dash lights are not working the gauges fuse is
good be dimmer switch, but only if all dash lights are out,like radio heater control, cig light,if those still work then i would say its bulbs.
Oct 03, 2009 | 1990 Chrysler Imperial
Dash lights are out.
Are you also noticing this in the daytime hours? Most vehicles have an auto dimmer function on the radio lights for night-time driving and when you shut the headlamps off the go back to the original daytime brightness.
Jul 23, 2009 | 2005 Scion xB
Headlights, dome lights, and radio shut off on my 1990 bronco!
possibly the dimmer switch on the floor? happened on my 91 half ton dims didnt work but brights did and then they cut out altogether. a little water goes a long way
Nov 24, 2008 | 1987 Ford Bronco II
1994 Jeep cherokee am/fm radio backlight lamp is out and AC/Heat dash lamp is out
There is a tiny little peanut shaped light bulb inside the radio that provides the light for the dial, it is replaceable, you will need to remove the radio, then pull the top cover off the radio chassis, the bulb is under the cover.
Nov 07, 2008 | 1994 Jeep Grand Cherokee
Car Audio & Video Logo
26 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
