Question about Logitech Z-2300 Computer Speakers
Right speaker doesn't work
Hi, ive had my logitech Z-2300 system for about 1.5 years now. My right speaker randomly didnt have sound, so i tried plugging it into the left speaker outlet on the subwoofer and suddenly it worked. so i kept unplugging and replugging, and suddenly my right speaker worked again for like a minute, then it stopped working, no sound. And the sound wont come back.First i thought maybe dust or something but ive cleaned it, and i have all necessary drivers. Is my subwoofer defect? Can i fix it my opening it up? Please help, Alex
  • 1 more comment
  • Matsdh Jan 11, 2009
    I'm not sure if this is your problem, but I had the same .. first the right speaker stopped working but worked sometimes and then the left one began having the same problems ..
    The problem with my z-2300 was that my volume console cable "Loose cable/broken cable" So maybe your problem is with the cable that is plugged in into your mp3/laptop/dvd player.
  • syamalan Jan 27, 2009
    I noticed my right speaker not working, but after some fiddling around I realised that it wasnt the speaker that was the problem but the RIGHT OUTPUT from the sub (the right speaker worked fine plugged into the LEFT OUTPUT)
    What can I do to solve this problem. The system is less than a year old and I always make sure the sub never gets too hot.
  • Anonymous Mar 06, 2009
    Just to add that I had similar problem, one channelwent out, some months later, the other went out.
I had this very same problem and I had my system for about 2 weeks. I have seen a lot of similar posts on this site so it seems that this problems happens a lot. For some reason my right speaker just stopped working so i came to this site for help. I looked at alot of posts and nothing fixed the problem. when i switched the right speaker to the left input it started to work so I knew the speakers were fine. So i finally decided to unplug everything and restart my laptop. Once my laptop rebooted I plugged the sub back into the wall after about a minute of it being not plugged in. Then I plugged all the the wires and volume control back into the sub and turned the switch back on. Make sure the volume control is down when you plug everything back in. Then plug the wire into the device, which in my case was a laptop, and start to play some tunes. Right away everything was working perfectly fine again and no problems ever since...for me atleast.
HOPE THIS HELPS
Posted on Feb 18, 2009
    Problem Solver:
  • 6 Answers
The fix is don't monkey around. Simply reverse the cable leads from computer to the box.
Posted on Jan 06, 2012
I just had the same problem minutes ago. The right speaker is out. I searched google for answers then I chose one of the results which is this page. Amazingly, I tried the solution #1 by pyro. and guess what? the right speaker went on again. But what did cause this problem? It is better that we know so we can avoid it from happening again, it might truly broke the speakers... BTW. Thank you very much!!!
Posted on May 27, 2010
My right side was out and I almost broke it down. I went on this site read for about three minutes tried the input jack to my computer and solved my problem.
Good job people!
Posted on Mar 31, 2009
I had the same problem, except with my left speaker. I tried Pyro5389's suggestion, and now everything works perfectly!! Thank you so much!!!
Posted on Mar 21, 2009
    Problem Solver:
  • 7 Answers
You will need to take the speaker apart and with an ohm meter or continuity tester, measure the resistance of the speaker, at the two terminals at the rear of the speaker magnet, to see if that circuit is "open" ("open" is a reading of no resistance, or no continuity). If it is open, you have no choice but to replace the speaker. If instead the speaker measures a low resistance, or the meter indicates continuity (a meter might indicate continuity with a beeping sound), then do the following: measure the resistance/continuity of the wires which lead from the speaker magnet, to the output terminals on the outside of the speaker "box". Also, some speaker manufacturers install small fuses inside their speakers. Even if the fuse does not look "blown", test it for resistance/continuity. Good Luck!
Posted on Mar 30, 2007
I have actually lost my satellite speakers that came with the Logitech Z-2300. I am wondering what my best option is. I can't seem to find anyplace that sells these kind of speakers separately. I...
Hi
http://www.livedigitally.com/2005/09/05/logitech-z-2300-speaker-system/
It would appear you need 2 x 1/4 inch (3.5mm) jack to RCA cables, one for each channel and each speaker, left and right, rather than just the 1 cable ("..and a mini to RCA cord...") you seem to have bought.
The Yellow and Black RCA ports appear to be the Left and Right speaker channels respectively.
The output cable with a green jack that connects to the green jack on the computer's sound card seems to be tied in with the wired Remote Control.
I would have recommended getting a pair of passive 40W RMS Logitech Stereo Speakers.
As long as the speakers you have match in terms of Wattage and Impedance, you should be okay.
I hope this helps.
Aug 26, 2011 | Logitech Z-2300 Computer Speakers
Hi there, ive got logitech speaker system z523, ive had them for around 7 months now haven't had any problems with them, all of a sudden my 2nd speaker just doesn't seem to work, and i've tested them but...
first of all you should try with a different audio source to make sure that the problem resides in your speakers. Then you could try to move the left speaker's cable to see if that is causing the problem and fix it if you have some good soldering skills, otherwise you can just send them back in assistance since they have a 1 year long warranty.
Hope it helped,
Franz
Mar 24, 2011 | Logitech Z523 2 Speakers
Hey ive just bought Logitech Z506 surround sound speakers and im just wondering how do you connect it to your T.v ive tried and the rear left works, rear right works, the front left doesn't work and the...
you will probably have to buy some 2 to 1 input plug adapters and set them up
i cant see your television so im not sure of its speaker set up
hope this will help you
Mar 07, 2011 | Logitech X-530 Computer Speakers
My one speaker sounds scratchy and doesn't have as good sound quality as it did when I first bought the system about a year ago. there is a 2 year warranty, will Logitech replace the speaker?
Hi, Thanks for using fixya.
Logitech Is a very good company and I am sure they would.
1-800-231-7717. Monday - Friday, 6:00am - 6:00pm PST ...
Terry
Feb 17, 2011 | Logitech Z-2300 Computer Speakers
Z-2300 left speaker not working
First try to setup your operating system sound setting in control panel. check if drivers are installed properly or try updating them.
if problem still there may be the plugs to the woofers is not working correctly.
If it is warranty period change them as fast as you can.
Dec 10, 2010 | Logitech Z-2300 Computer Speakers
Can I turn the Logitech z-2300 to a 4.1 speaker system?
You will need a separate pair of powered speakers to do that, plugged separately. The quality of the sound will remain the same on the front ones, the overall quality will depend on the new ones.
Jul 17, 2010 | Logitech Z-2300 Computer Speakers
I have upgradded my Laptop operating system to
Use the ones for Windows Vista. Vista Drivers work for 7.
Now considering these speakers plug in via headphone jack you dont need drivers for your speakers. You should be looking for sound drivers for your laptop.
Plug in headphones see if they work if they do then there is no reason why your speakers should not.
Apr 25, 2010 | Logitech Z-2300 Computer Speakers
My left speaker doesn't sound but when I press the movable part of it this sounds again. Can be fix it?
Hi there bud,Theres a lose wire thats not correctly placed in , In this case , you would have too take it back to shop and inform them,, do not open it ,otherwise your warranty will expire...Hope you come right bud :D
Happy new year
Dec 26, 2009 | Logitech Z-2300 Computer Speakers
Z-2300 Left Speaker and port dont work
did you try plugging in the other speaker into the yellow output. If you can hear music doing that then its only your left speaker that is the problem. Try tapping the faulty speaker into the palm of your hand while connected. There might be a faulty contact to the actual cone of the speaker. I had to open mine up because i had the same problem. It turned out that it was the wires that weren't making contact. I scrapped and moved them around connected the speaker and it worked. I hope that i made some sense out of this. good luck.
Sep 06, 2009 | Logitech Z-2300 Computer Speakers
Right speaker on the logitech z2300 sound system wont play.
Make sure the PAN control is centered in your mixer control panel.
Sep 05, 2009 | Logitech Z-2300 Computer Speakers
Logitech Z-2300 Computer Speakers Logo
5,278 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
