AHCI I bought an ASUS Mainboard P5B-VM and installed XPSP2. The MB supports SATA and my HDD Seagate is SATA2 80GB/7200/3GB/s. In the ASUS CDROM accompanied, there is a software AHCI/RAID but I can't find AHCI in the BIOS. I use software HD Tune to monitor the HDD, the disk is operating in UDMA-5, it reads 58MB/s instead of 3GB/s as manufactured. My question is if I instal XP and press F6 to instal AHCI, SATA2 is activated? Besides, can you provide any solutions to acivate AHCI in my present PC which is already XP?. I appreciate your assistance rendered to me
  • locpham43 Dec 14, 2008
    Your help is rated as helpful.
  • 781 Answers
Choose RAID mode.. that should enable AHCI. (as per wikipedia) on your motherboard so that means.. that if you're installing the os on this hdd you may want to use the raid driver for it which is likely what's in the ASUS cd you got so your os get to use the hdd as it's meant to be used.
you may also want to make sure you're using the right sata connector on your motherboard: check page 33
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5B-VM/e2642p5b-vm.pdf
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5B-VM
the problem could laso lay in your cables.. it's know the average may be affected by faulty SATA cable or faulty SATA power cable (powersupply issue)
you may also want to run a backup of your data and then run a defrag and a checkdisk on the drive, and it's probably also worth it to rung Seatools (download from this page: http://www.seagate.com/www/en-us/support/downloads/ ) to check the health of your hd.
Also try to update the SATA controller drivers or the motherboard chipset
lastly, post the results of your tests here on fixya or better yet: in here: http://forums.seagate.com for further follow up.
try each recommendation one at a time and then test the speed of your hd to see if there's improvement.. make sure you back up before you do anything drastic.
good luck (it took me 2 hours to pos
Posted on Dec 14, 2008
Unable to use S-ATA on Asus P5LD2-VM
in the BIOS set the SATA controller to IDE this should fix the problem. And try with AHCI selected.
Apr 16, 2013 | ASUS P5LD2-VM Motherboard
Audio driver for atx in xp
http://support.asus.com/Download.aspx?SLanguage=en&m=P5B-VM
Dec 22, 2012 | ASUS P5B-VM SE LGA775 Micro-ATX Intel...
Hello, My my motherborad is ASUS p5rd1-vm;RAM1GB and hard disk is PATA 80 GB but the HDD is having some kind of problem and the windows have shown a warning about it several times. Now i want to buy a...
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted.
Or install Vista or 7 instead of XP, the have support for SATA disks
Jul 28, 2011 | ASUS P5RD1-VM Motherboard
User guide for a p5b-vm many thanks rob selsig
heres a link to the support site http://support.asus.com/download/download.aspx?model=P5B-VM&SLanguage=en-us
You can then click on manuals and choose the manual in which ever language you require
heres a direct link to the English version of the user manual http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5B-VM/e2833_p5b-vm.pdf
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | ASUS P5B-VM Motherboard
HDD problemon asus motherboard p5rd1-vm
You need to install the SATA drivers that belog to your specific motherboard.
When you are installing Windows thru your Windows CD, there is a moment at teh beginning of the process that you will be asked to press F6 if you want to install 3rd party drivers.
That is your call.
Once the SATA drivers are installed, you will be able to continue with your Windows installation.
Don't forget to rate this answer if it helps.
Dec 11, 2009 | ASUS P5RD1-VM Motherboard
P5b-vm se asus driver
You can download the drivers for your motherboard from asus here:
http://support.asus.com/download/download.aspx?modelname=P5B-VM SE&SLanguage=en-us
just select your operating system
Mar 31, 2009 | ASUS P5B-VM SE SKT775 G965 MATX...
2 Sata Hdd not supported
Hi rafiqbrush, let me go over a few things for the P5B MB.
There is a total of 5 serial ATA SATA drive ports on the board & one ATA IDE/PATA port.
The 4 main SATA ports are numbered, 1 - 4. Your primary SATA drive must be connected to SATA port 1. Your second SATA drive must be connected to SATA port 3. See page 2-26 in your manual.
All SATA drives are seen as master drives. Once the two SATA drives are connected (As per manual), boot to the bios main menu.
At the main bios menu make sure your bios shows both SATA drives. Than go to the bios title "Boot". Make sure your primary SATA drive 1 is listed in the boot order. Save & exit the bios. (SATA drive 1 must have windows installed on it).
Link to Asus P5B web site;
http://support.asus.com/download/download.aspx?modelname=P5B&SLanguage=en-us
Good luck rafiqbrush!
Thank you for using fixya.
Mike
Dec 10, 2008 | ASUS P5RD1-VM Motherboard
Sata hdd detected but problem with booting&installation
i have sata hdd 160 gb of seagate and hdd detected in raid channelbut when start installing window it shows message press enter for fresh installation "no hdd found please check power card,bios configuration
Jun 30, 2008 | ASUS P5RD1-VM Motherboard
I can't use HDD sata on mainboard ASUS P5RD1-VM
Things need to be turned on in your bios patrohi. This is why windows didn't boot to the SATA. You need to use your manual & make sure the, Serial ATA Controller is [Enabled]
Within the Advanved menue under SouthBridge Configuration.
At the Main menue the SATA drive should be listed.
Boot settings need to change as well. At Boot Settings Configurations. Make sure your SATA drive is listed.
Boot order should list like, Floppy 1st, CDROM 2nd, SATA 3rd. The SATA will not list as a SATA but the model number of the SATA drive. Once all these settings are set save & exit. Your drive should show up for work & the windows CD should load.
Feb 20, 2008 | ASUS P5RD1-VM Motherboard
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
677 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
