Question about Optoma EP737 Multimedia Projector
Blinking Temp Light on Optoma EP737
Have an Optoma EP737 that I've had about 3 years with casual use attached to a ceiling mount. I replaced the bulb in October with a new Optoma brand bulb.
I turned the projector on this week and the TEMP light blinked for a few seconds and the projector turned off. Have tried several times to no avail.
Have a call in to Optoma and waiting to hear back, but know they'll ask me to send it in. Anyone have any suggestions on a "do it yourselfer" to fix the problem? Thanks!
  • 14 Answers
SOURCE: Upside down projection
Download the latest display driver for your video card. If you are using ATI vc's then download and install the Catalyst Application which will allow you to rotate the screen orientation .
Posted on Jun 20, 2007
SOURCE: How can I check the used hours of the lamp?
press buttons up-up-left to go into service mode, there you see the lamp hours, succes
Posted on Apr 02, 2009
  • 2237 Answers
SOURCE: Just mounted my Optoma EP732B projector on the
go into the menu settings, and look for image. should say "front", you'll want to change it to "ceiling"
Posted on Nov 16, 2009
  • 2237 Answers
SOURCE: on my optoma H77 I am replacing a burnt out bulb
clean out the projector with canned air to get rid of the dust that could be causing it to overheat. also make sure the fans are spinning. if it still blinks, replace the temp sensor. if it overheats alot, the sensor will wear out from excessive heat.
  • 144 Answers
SOURCE: I have and optoma h31 projector and i put a new
Posted on Jan 31, 2010
Optoma ep728 bulb warning light on after bulb replaed
Try just doing a search on the Internet for: user manual mx490 . I usually always find a useable link that way
Dec 23, 2017 | Optoma EP728 Projector
Purchased 2006. Ceiling mounted. Just stared overheating after approx 10 minutes after last bulb replacement in March of 2010. Floor fan pointed at projector helps. Tried cleaning. Running right side...
Yes, if bulb was low price and was installed in old lamp casing then it is bulb that is not good and creating too much heat that exhaust fan can't throw out to make projector cool enough so temp sensor activates and send over heat signal to system control chip thus projector shuts down.
Please install original lamp that comes with casing to solve this issue.
If lamp was original then check exhaust fan that might be running slowly due to stiffness in bearing so temp sensor finds over temp in projector.
Hope these info will help you.
Dec 18, 2010 | Optoma EP1690 DLP Projector
Can the Optoma EP739 be ceiling mounted and projected upside down? what are the steps to do so? also, what would be the best mount for said projector?
Mine has been in place for about three years. Because the ceiling was open I was able to create a connection for a tripod head on the ceiling and then using a STRONG tripod head and some small bolts (longer than the originals) I mounted an external base and with the tripod head fitting dttached to the projector it just became a matter of running the various connector cables from the sources I use that require projection to my wall.
Dec 02, 2010 | Optoma EP739 Multimedia Projector
Blinking tem light on optima ezpro 737
Its likely to be one of the fans at the front of the projector thats running slow or not at all. I had to take mine out and soak in WD40 dry and replace - all works now. The light will come on even if the projector is cool if it detects a slow running fan.
Oct 21, 2010 | Optoma EP737 Multimedia Projector
High temp light on when powering up
Remove the screws and check out the fan's working state.
EP759 have one big 92mm fan for the lamp, and three small, near 40mm, fan's for the optics.
Power of the bulb is very high, so just 1 broken fan can make that situation.
Apr 25, 2009 | Optoma EP759 - HDTV Compatible DLP...
Projector will not turn on no fan no light
Here is a link to the "Troubleshooting" part of the manual to Optoma H56 Projector. Hope it will help!
Troubleshooting Optoma 56 User Manual Page 27 of 32
Jan 04, 2018 | Optoma H56 Multimedia Projector
Feb 18, 2008 | Optoma EP737 Multimedia Projector
Optoma ep 753 will not light
you can just open the lamp and see the condition of the inner tube only. otherwise you have to replace the lamp and run it.
Nov 17, 2007 | Optoma EP737 - DLP PROJECTOR - 1500 LUMENS...
Optoma H56 - turns off just after start up.
It's not a short, the blub is near the end of it's life ~ the optoma is designed to detect when the blub is about to blow and shuts itself down. Turning the projector upside down or right side up usually only gives you a brief reprieve (some have reported a modest amount of extra time gained) on the blub ~ but in the end it's on it's way out and the projector will shut down again.
Oct 14, 2007 | Optoma H56 Multimedia Projector
Optoma EP737 Multimedia Projector Logo
144 people viewed this question
Top Optoma Office Equipment & Supplies Experts
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
